Programming a new remote - Chevy Impala Forums
Resource Center This forum contains valuable information for the Chevy Impala and similar Chevrolet. You'll find part resources, Do It Yourself guides, plus much more. Threads for this forum are nominated by moderators only.
 2Likes
post #1 of (permalink) Old 05-28-2009 Thread Starter
kermone's Avatar
Smile Programming a new remote
Hi, new to this forum. Joined because I purchased a used 2004 Impala. Needed a new remote and purchased one from an online dealer. Thought I would pass along his programming instructions in case you might have lost your manual. This only works if vehicle has OEM keyless entry and factory radio.
1. Turn Ignition on and turn radio off
2. Press and hold DISPLAY on the radio until SETTINGS is displayed.
3. Use SEEK , scroll until FOB PROG appears
4. Press Prev or Next till BEGIN is displayed
Press DISp till PUSH FOB flashes, then
5. Press and Hold both LOCK and UNLOCK on the remote till beep or chime is heard
6. Repeat 4 and 5 for each remote to be used. All remotes must be programmed in this same programming sequence for them to work
7. Scroll until EXIT appears, and press DISP to exit programming. A chime will sound to verify.
This should work on 2001- 2005 Chevy Impala and Monte Carlos.
Look forward to belonging to this forum.
kermone is offline
The Following User Says Thank You to kermone For This Useful Post:
tonyc712000 (02-22-2013)
post #2 of (permalink) Old 05-28-2009
cbmikey's Avatar
Send a message via AIM to cbmikey Send a message via MSN to cbmikey Send a message via Yahoo to cbmikey
Originally Posted by kermone View Post
Hi, new to this forum. Joined because I purchased a used 2004 Impala. Needed a new remote and purchased one from an online dealer . Thought I would pass along his programming instructions in case you might have lost your manual. This only works if vehicle has OEM keyless entry and factory radio;
Thanks Kermone and welcome to the forum!
cbmikey is offline
post #3 of (permalink) Old 03-27-2013
Lentzjj's Avatar
will this work if the remote was already attached to a differant car?
Lentzjj is offline
post #4 of (permalink) Old 03-27-2013
TSS
TSS's Avatar
Quoted: 78 Post(s)
Yes
2009 Impala SS (sold 3/2012)
2014 Impala Limited LTZ 3.6 V6
TSS is offline
post #5 of (permalink) Old 04-02-2013
jbarnett13's Avatar
I just got an Overkill tune and the remote start no longer works. All other buttons on fob work, should this fix the remote start?
2007 Impala LT
Overkill Tune
K&N Drop-In Filter
Plastidipped Wheels,Emblems,Lower Grill, and Door Pillars
Resonator Delete
Weathertech Floormats
2 10" Kenwood Subs
1000 Watt Amp
LED Reverse Lights
LED Switchback Strips
Soon to come
SSC Lowering Springs
HID Headlights/Angel Eyes
jbarnett13 is offline
post #6 of (permalink) Old 04-02-2013
Back in Black
12ltz's Avatar
was remote start working before, if yes then you have a code set by the new tune, try clearing code
_________________________
2012 Impala LTZ 72,000 miles
12ltz is offline
post #7 of (permalink) Old 04-02-2013
OEM LOL
Ejbiers's Avatar
You can't just reset the code.
You need to get a case relearn.
After the case relearn it will work again.
2016 Mustang GT PP Premium
Know the truth
http://infowars.com
Ejbiers is offline
The Following User Says Thank You to Ejbiers For This Useful Post:
jbarnett13 (04-02-2013)
post #8 of (permalink) Old 04-08-2013
mrbill1956's Avatar
key fob programming
go to www.remotesremotes.com
click on your year and make and model all instructions are there for all makes/models.
* 2011 & 2012 gm vehicles must be programmed by the dealer.
hope this helps someone out there.
Bill
mrbill1956 is offline
post #9 of (permalink) Old 07-25-2014
GET_ARMED's Avatar
Very informative and they have tutorials for many vehicles.
https://www.youtube.com/watch?v=BeYd06hoyS4
GET_ARMED is offline
post #10 of (permalink) Old 07-29-2014
Quoted: 39 Post(s)
Thanks for the additional information, gents!
donmateo is offline
post #11 of (permalink) Old 07-29-2014
darkeyce02's Avatar
I was hoping to do this on my own cause I have a fob from my old impala that was new. But after market deck :/ what could I do in that case guys?
2005 Impala SS
darkeyce02 is offline
post #12 of (permalink) Old 07-31-2014
2002impalaLS's Avatar
i believe the only 2 ways are tech 2 and stock radio, i put my stocker on the shelf just for this reason
2002impalaLS is offline
post #13 of (permalink) Old 09-22-2014
g25racer's Avatar
I did a stereo relocation harness. That's the best way
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #14 of (permalink) Old 12-15-2017
Lorrent's Avatar
How do i Program a Keyless Remote for a 2013 Chev Impala?
Lorrent is offline
post #15 of (permalink) Old 12-15-2017
Quoted: 917 Post(s)
My understanding is that with the 2012+ Impalas, there is no way to program the remotes anymore and that you have to take it to a dealer to be programmed... You could program them yourself with earlier models, but not with the 2012+...
Programming remote key for 2018 with push button impala thaiban Autocare and Maintenance 8 11-30-2018 08:22 PM
Programming a remote viper15162002 Chevy Impala 8th Gen Discussion 2 10-25-2018 11:06 AM
Programming remote key for 2018 with push button impala thaiban Chevy Impala 9th Gen Discussion 0 04-05-2018 10:59 PM
