JT's 2012 Impala LT Mod Thread - Page 3 - Chevy Impala Forums
Like Tree67Likes
Old 11-27-2014   #31 (permalink)
Quoted: 917 Post(s)
I've seen some REALLY nice chrome mustang wheels for pretty decent prices - thanks for mentioning that they would fit - they are very similar to the Cragar style that I like.
Regarding the hub-centric rings, what size would I need to buy if I moved forward with the mustang wheels?
These are the type of mustang wheels that I'm considering (although since I just bought an HP Tuner device, I'm most likely going to put the wheels off now and go for the Overkill tune first!):
EDIT: Hmm - just noticed that the offset is listed at 45mm for the one wheel type - so they wouldn't work at all?
JT's 2012 Impala LT Mod Thread-1417086725887.jpg   JT's 2012 Impala LT Mod Thread-1417086735553.jpg
Old 11-27-2014   #32 (permalink)
Quoted: 917 Post(s)
And this is basically the look I'm going for - this is from the CarID simulator app (which is AWESOME!) with American Racing wheels. The only problem is that these particular wheels (for example) are about $600 *each*! :-)
Old 11-27-2014   #33 (permalink)
Quoted: 99 Post(s)
45mm offset should definitely work. it appears that the hub bore is 72, so you'd need hubcentric rings with an outer diameter of 72 and an inner diameter of 70.3
*2001 Impala Ls - 134k
Precision 6262 Turbo, ZZP Z3, CXRacing intercooler, ZZP 3" Cat-back, Muffler delete, Bosch 42.5# Injectors, Bosch fuel pump, CTS-V Brembos, Stainless lines, CM GP springs, Dorman solid sway bar, SPEC-D LED headlights, LED heads and fogs, Quad tails, C5 reverse lights, All LED interior, LED 6 gauge cluster retrofit, LED puddle lights, LED underglow, Debadged, Dipped emblems, Color-matched trim, Kenwood DDX271, Polk Audio dxi6500 components, Polk Audio db690, Hifonics GLX100.4, 2x Polk Audio db1240 in custom box, Hifonics ZRX1800.1D, KMC District, Nitto NT555G2, SS tail covers, SS spoiler, SS Lip, 20% tint, Black mesh grille
*2005 GTO - 72k
LS2/6SPD FOR SALE
*2014 Impala LT Limited - 35k
jtrosky (11-27-2014)
Old 11-27-2014   #34 (permalink)
Quoted: 917 Post(s)
Still looking into different wheels... I originally thought that my existing wheels were 7.5" wide, but they are actually 6.5" wide. So would a 8" wide wheel still work with 225/55R17 tires?
Here are the specs for my current wheels (assuming this is correct - these are for replicas):
12 2012 Chevrolet Impala Wheel Action Crash
Retail Price:
$609.00
Sale Price:
$135.73
Quantity:
(>12) In Stock
Product SKU: ALY05071U10N
Product Note: ALLOY WHEEL; 17 X 6.5; 47MM OFFSET; 5 DOUBLE SPOKES; 5 LUG; 115MM BP; NEW REPLICA; MACHINED WITH SILVER
The problem is that I kinda need to be 100% sure that 17", 8" wide wheels with a 45mm offset and a 114.3 bolt pattern will work before I actually order them! :-)
Does anyone know of an easy way to check to see if a certain wheel will work with a certain car/tire combination? Again, this is really something that I need to be 100% sure of before ordering since we're talking about a lot of money here! :-)
Thank you!
Old 11-27-2014   #35 (permalink)
Quoted: 99 Post(s)
The 225 tire is probably a little skinny for an 8" wide wheel. I'd talk to your local tire shop about the potential fitment.
As far as the mustang wheels physically bolting up, many people have done it successfully. So I'm confident that you won't have any problems putting the wheels on the car. But the tires might be a little "stretched" in order to fit
*2005 GTO - 72k
LS2/6SPD FOR SALE
Old 11-27-2014   #36 (permalink)
Quoted: 39 Post(s)
Can't believe I missed this thread! Looks great, JT! I need to do the chrome come warmer weather.
Old 11-27-2014   #37 (permalink)
Quoted: 917 Post(s)
Found a nice little chart that shows the max wheel width for different sized tires and it looks like 225/55R17 tires will work with an 8" wheel... Good news. I really like the Mustang wheels I posted above. At least now I know that they would work with my existing tires. Just may have to bid on them! :-)
Here's the chart - pretty handy:
http://customwheelsmarket.com/rimwheelwidth1.html
RYD SLO (11-27-2014)
Old 11-27-2014   #38 (permalink)
Quoted: 99 Post(s)
Good info
*2005 GTO - 72k
LS2/6SPD FOR SALE
Old 11-30-2014   #39 (permalink)
Quoted: 917 Post(s)
So I found a really nice set of chrome Mustang Bullit wheels on Craigslist for a great price. Only issue is that they are +30 offset...
Anyone know if +30 offset wheels would work on an 8th gen? I have seen both +30 and +45 Bullit wheels, no really not sure if the +30's would work.
Thanks.
Old 11-30-2014   #40 (permalink)
Quoted: 99 Post(s)
How wide are they?
*2005 GTO - 72k
LS2/6SPD FOR SALE
Old 11-30-2014   #41 (permalink)
Quoted: 917 Post(s)
8"...
Still not positive if my stock wheels made 6.5 or 7.5" though - see conflicting info... I guess I could go measure them, eh? :-)
EDIT : stocks are 7.5".
Old 11-30-2014   #42 (permalink)
Quoted: 917 Post(s)
I just can't image a 17mm offset difference making *that* much of a difference (especially since it would just push the wheels out as opposed to closer to suspension parts, etc...). I mean 17mm is between .5 and .75 inch. Surely, they would still fit?
They look really nice in the picture and are only $200 to boot (and are chrome)! :-)
EDIT: Never mind - they're already gone anyway...
Old 12-01-2014   #43 (permalink)
Quoted: 917 Post(s)
What do you guys think of these wheels? They've been for sale for a while, so I could probably get them for $200/$250...
http://lancaster.craigslist.org/pts/4754619873.html
Wheel width is 7.5" (same as stock), so they should fit without issue.
Just not sure if I should go for these or just hold out for another set of chrome Bullitts...
Also, here is a great site that lets you put in old and new wheel sizes and tells you if they should fit or not. Pretty cool...
http://www.rimsntires.com/specspro.jsp
Old 12-01-2014   #44 (permalink)
Quoted: 99 Post(s)
Not a huge fan of those wheels...
Cool website though!
*2005 GTO - 72k
LS2/6SPD FOR SALE
Old 12-01-2014   #45 (permalink)
Quoted: 917 Post(s)
Yeah, I've found that it's almost impossible to determine if wheels looks good on a car until you actually see them on the car. Wheels that I think look great on their own just don't look right on the car... I did see a few pictures of mustangs with those wheels and they looked great - but that is a mustang... Not sure what to do - I think I'll hold out and just end up getting exactly what I want though. I've found places selling the Bullitt wheels brand new for $159 shipped, so I may even do that eventually... Can also get "new take off" (less than 5 miles on them) Bullitts for $600-$650 shipped on Ebay.
LinkBack to this Thread: https://www.impalaforums.com/recent-mods-weekly-updates/572514-jt-s-2012-impala-lt-mod-thread.html
JT's 2012 Impala LT Mod Thread - Page 5 - Chevy Impala Forums This thread Refback 01-12-2015 05:02 AM
JT's 2012 Impala LT Mod Thread - Page 3 - Chevy Impala Forums This thread Refback 01-12-2015 05:02 AM
JT's 2012 Impala LT Mod Thread - Page 2 - Chevy Impala Forums This thread Refback 01-12-2015 05:02 AM
JT's 2012 Impala LT Mod Thread - Chevy Impala Forums This thread Refback 01-12-2015 05:02 AM
2012 Impala LT Stereo Replacement reesem_2018 Audio, Video, and Electronics 19 02-23-2019 02:46 PM
Need help with Flowmaster 40s 2012 Impala LT Mitch Hamlin Recent Mods/Weekly Updates 2 09-28-2018 04:23 AM
2012 Impala LT power port question DaleB Audio, Video, and Electronics 3 06-10-2018 02:58 AM
Front and Rear Brake Rotors & Ceramic Pads 2011 2012 2013 CHEVY IMPALA LS LT LTZ RSS Bot Impala Diecast Toys Cars on eBay 0 02-14-2018 03:11 AM
2012 Chevrolet Impala LT RSS Bot eBay Cars For Sale: Impala 0 02-06-2018 10:40 AM
Auto Dimming Mirror Help
10-24-2017 03:01 PM
Last post by Pdmorris1$
1 Hour Ago 11:14 AM
9 Replies, 1,665 Views
Help!!! Throttle body
3 Days Ago 09:44 AM
Last post by plano-doug
4 Hours Ago 08:13 AM
27 Replies, 173 Views
Last post by kbz1960
5 Hours Ago 07:37 AM
33 Replies, 802,131 Views
Fuel issues
04-26-2019 02:07 PM
Last post by Joes74challenger
6 Hours Ago 06:00 AM
12 Replies, 295 Views
Understanding the...
1 Day Ago 10:48 PM
by RShea
Last post by hatzie
11 Hours Ago 01:17 AM
8 Replies, 99 Views
Finally went LED on the...
4 Weeks Ago 05:53 PM
Last post by Tesla
1 Day Ago 10:09 AM
32 Replies, 950 Views
2005 3.8 wide open...
1 Week Ago 06:50 AM
Last post by Ranger Rick
1 Day Ago 05:55 AM
6 Replies, 191 Views
What did you do to your...
09-25-2012 07:03 AM
by Joe
Last post by Stockcar10
2 Days Ago 10:17 AM
7 Replies, 415,248 Views
1977 impala street...
04-03-2018 08:19 AM
2 Days Ago 10:14 AM
43 Replies, 1,591 Views
1977 impala th400 swap
03-01-2018 09:01 AM
2 Days Ago 09:19 AM
27 Replies, 917 Views
