The transformation of my RYD - Page 40 - Chevy Impala Forums
Like Tree35Likes
Old 05-02-2018   #586 (permalink)
Dave_N's Avatar
Quoted: 64 Post(s)
Maybe going with a smaller caliper would have been a better route?
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline   Reply With Quote Quick reply to this message
Old 05-02-2018   #587 (permalink)
Quoted: 930 Post(s)
While I too liked the SS wheels better, it's really not about what *we* prefer - after all, it's not *our* car! :-)
Jeff should do what *he* wants to do and what *he* likes! Obviously, he felt it was time for a change. It's all good!
hatzie likes this.
RYD SLO (05-02-2018)
Old 05-02-2018   #588 (permalink)
Quoted: 101 Post(s)
The fact of the matter is, I wanted the car to stand out a little bit more than what it did. And the car DOES do that now. But there were other reasons for wanting them at this point, including the need for new tires on the SS rims, and my desire to change to a slightly larger wheel. I was aiming for a set of 19s, but came across a great deal online for these brand new 20s with brand new tires that was only slightly more than my budget for a used set of 19s, so I bit the bullet.
RYD SLO is online now   Reply With Quote Quick reply to this message
Old 05-02-2018   #589 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
Did you calibrate the speedometer?
And how does it ride with the thinner tires on it?
I have some time left with my tires and Iím thinking about wheel stuff. IDK as of yet. It takes $$$ thatís for sure
~Joe~
04 Impala LS
Engine: ZZP PCM, ZZP Downpipe, Xcelerator Resonator, Dual Xcelerator Mufflers, 4" Stainless tips, 180į t-stat, Shorter Dogbones, Mount Spacers, Optima Red Top Battery
Interior:
04Imp38 is online now   Reply With Quote Quick reply to this message
Old 05-02-2018   #590 (permalink)
Quoted: 101 Post(s)
No. Never calibrated it with the taller tires on the SS wheels either. It's close enough.
As for the ride, well, you definitely feel bumps more. and being lowered doesn't help. But on good roads the handling is far better. Probably has more to do with the summer compound than anything else.
Yeah, I was looking and my tires were getting pretty worn. They were just to the wear bars and starting to crack. I probably could have gotten another summer out of them, but it was time.
Old 05-07-2018   #591 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
Happy to hear about the coilovers @RYD SLO !
BC Racing? And how does it ride/handle?
Canít wait for pics too
~Joe~
04 Impala LS
Interior:
Old 05-07-2018   #592 (permalink)
Quoted: 101 Post(s)
No, I wish I had gone with the BCs. I went with the eBay coilovers just to see how they were. For $220 I didn't expect much, and while they do have their shortcomings (mainly the rear height adjustment and the lack of a pillow ball front mount or bearings to keep the springs from making noise as you turn), they are actually not bad.
That being said, the ebay coilovers would be good for someone who wants to slam their car to the ground for cheap. My aggressive offset means that I'd scrape if I were to have them adjusted to anywhere but all the way up, but on higher offset wheels and removal of the fender liners, they'd certainly allow you to go very low. Just don't expect the performance or adjustability of the BCs.
04Imp38 likes this.
Old 2 Weeks Ago   #593 (permalink)
Quoted: 101 Post(s)
Well, haven't updated here in a while.
I did end up changing over to the BCs after some bad experiences with the ebay coilovers that left me with some minor body damage. Bought the BCs and installed them along with new engine/trans mounts, the mount spacers, and fresh ZZP axles. Stance is excellent now, however I had to address the rubbing-on-the-rear-quarterpanel issue.
Started by rolling the quarters, however the double-walled design didn't allow for much movement. With the other body issues, including the aforementioned damage from the ebay coilover incident, some other minor damage from before I owned the car, and the rusty rockers, I decided it was time for a full refresh from a paint/body point of view.
Spent a few months taking my time, fixing the rust in the rockers, cutting the quarter panels for maximum tire clearance, and straightening all dings, dents, scrapes and scratches. Finished it off with a fresh coat of Galaxy Silver Metallic, and gloss black for the pillars, tail lights, and c pillar emblems.
I have some pictures of that process that I may post up later, however a few weeks after finishing the project, I was on my way home from a car show a few hours away, and while doing a quick pull on the highway, the CEL started flashing and the engine started missing on cyl 3. Pulled the plug, and the gap had closed to 0. Went in with a borescope and determined that something (unknown what at this time) came apart in the top end, and bounced around inside cyl 3, chewing up the piston and valves, scoring the cyl wall, and closing the spark plug gap before being ejected. I replaced the spark plug for shits and giggles, and she actually runs great, but there is a tapping coming from the top end, and I'm sure the scored walls are allowing for a decent amount of blow-by.
In any case, haven't pulled the car apart yet to determine exactly what happened, but I DID go out and purchase another 2000 Impala LS for $500 that has an 85k engine and 90k transmission in it. Drove it the 2 hours home, runs like a top. Will be pulling the driveline out of that car, going through it and refreshing it as necessary, before dropping it into mine.
04Imp38 likes this.
Old 2 Weeks Ago   #594 (permalink)
Quoted: 101 Post(s)
Pic dump incoming:
Old 2 Weeks Ago   #595 (permalink)
Quoted: 101 Post(s)
Old 2 Weeks Ago   #596 (permalink)
Quoted: 101 Post(s)
Old 2 Weeks Ago   #597 (permalink)
RobHazmat's Avatar
Quoted: 33 Post(s)
Looks sick man!
2015 2LT
Sunroof & Spoiler Package
19" Chrome Wheels
LT Leather Package
LT Convenience Package
LT Entertainment Package
Advanced Safety Package
Driver Confidence Package
Hikari Ultra LED Headlights
LTZ LED Fog Lights
RobHazmat is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #598 (permalink)
Quoted: 101 Post(s)
Originally Posted by RobHazmat View Post
Looks sick man!
Thank you. Took quite a bit of work but I have so much more pride in the car now for having done it.
On to fixing the engine
Old 1 Week Ago   #599 (permalink)
04palaSS's Avatar
Quoted: 54 Post(s)
Dude that looks so amazing!
RYD SLO likes this.
Project 2004 Impala SS - Restored summer daily
Project 2004 Indy SS - In progress (sold)
Project SS #3 - Winter daily (sold)
Project Finally an 05 SS - New winter daily (sold)
2004 Impala SS - Parts car (RIP)
2004 Impala SS - Parts car #2 (RIP)
2014 Impala LTZ (sold)
2006 Impala SS- Cheap LS4
2004 Impala SS- Yes another one
2004 Trailblazer - The Parts Rig
04palaSS is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #600 (permalink)
Quoted: 101 Post(s)
Thank you! Trying to get on your level man!
Tools
05-06-2018 08:54 AM
Last post by plano-doug
2 Hours Ago 03:34 PM
250 Replies, 6,261 Views
List your Impalas
4 Days Ago 09:34 AM
Last post by 62BillT
4 Hours Ago 02:21 PM
12 Replies, 170 Views
My reintroduction
1 Week Ago 10:18 PM
by !Tommy
Last post by !Tommy
5 Hours Ago 01:07 PM
25 Replies, 355 Views
10 Hours Ago 08:18 AM
33 Replies, 835,293 Views
USB on 2016 Impala
12-08-2017 03:54 AM
Last post by Pat Currie
10 Hours Ago 07:33 AM
6 Replies, 3,073 Views
Automotive Discussion...
10-24-2012 04:38 PM
Last post by sheila
11 Hours Ago 07:24 AM
26 Replies, 10,474 Views
Rear view window mirror...
1 Week Ago 10:42 PM
by Verzace
Last post by Fred_06Impala
1 Day Ago 04:44 PM
6 Replies, 97 Views
Winter Wheel Package for...
11-11-2017 04:26 AM
Last post by donmateo
1 Day Ago 04:26 PM
14 Replies, 1,152 Views
Missing LED strip
1 Week Ago 02:08 PM
Last post by RobHazmat
1 Day Ago 11:51 AM
6 Replies, 174 Views
What did you do to your...
09-25-2012 07:03 AM
by Joe
Last post by kbz1960
1 Day Ago 11:49 AM
7 Replies, 427,612 Views
