The transformation of my RYD - Page 39 - Chevy Impala Forums
Like Tree35Likes
Old 10-25-2017   #571 (permalink)
I don't necessarily agree than they're needed on every car. I personally think my Escalade looks better with the amber bulbs, but I also added an LED strip to the headlights to give it a more modern look.
Old 02-25-2018   #572 (permalink)
I did my front brake upgrade yesterday. I got a good deal on the upgrade kit from ZZP on black friday. I went with the Camaro calipers over the more expensive CTS-V calipers, because the only difference is the powder coating, and I was going to be painting them anyway. I already had the stainless steel brake lines from when I ordered the turbo kit, so those went on as well.
One thing of note, these brakes will NOT fit under stock wheels without at least 1/2" of spacer.
On to the all important pictures!
Before!
some paint:
After!
Old 02-25-2018   #573 (permalink)
hatzie's Avatar
Quoted: 159 Post(s)
11.9" or 12.7"?
I'm updating my 09 SS to the 12.7" front setup... DTS calipers and brackets (no core charge) with Raybestos Advanced Technology Cop rotors and Raybestos AT Cop pads.
I've read I can use the 09 11.9" Raybestos AT Cop rotors/pads with my Gen8 SS dual piston calipers/brackets on my Gen7 SS.
What I'd like to know is... Will the stock 17" Gen7 SS wheels fit over the 11.9" rotors and Gen 8 calipers?
If not I'll probably be swapping to the Gen8 18" SS wheels. They make the car look more substantial. I'll probably do it anyway and put the Gen7 wheels in the attic for when I eventually sell it but I'm wondering how deep a hole I'm digging myself.
2009 Impala SS
hatzie is offline   Reply With Quote Quick reply to this message
Old 02-26-2018   #574 (permalink)
04palaSS's Avatar
Quoted: 54 Post(s)
That looks amazing!!! How do you like them?
Project 2004 Impala SS - Restored summer daily
Project 2004 Indy SS - In progress (sold)
Project SS #3 - Winter daily (sold)
Project Finally an 05 SS - New winter daily (sold)
2004 Impala SS - Parts car (RIP)
2004 Impala SS - Parts car #2 (RIP)
2014 Impala LTZ (sold)
2006 Impala SS- Cheap LS4 (sold)
2004 Impala SS- Yes another one
2004 Trailblazer - The Parts Rig
04palaSS is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to 04palaSS For This Useful Post:
RYD SLO (02-26-2018)
Old 02-26-2018   #575 (permalink)
Originally Posted by hatzie View Post
11.9" or 12.7"?
13.6" This uses the CTS-V rear 4 piston Brembo (also found on the Camaro with different powdercoating) with CNC'd brackets.
As far as clearance goes, I couldn't tell you without mocking up the setup. I know in my case, the Brembo calipers stick out much farther towards the outside of the car (being that they are 4 piston instead of 2), and interfere with the inside of the face of the wheel. As far as clearance towards the outside of the rim, there is plenty. A 17" wheel would still likely fit, but would be a tight squeeze.
hatzie likes this.
hatzie (02-26-2018)
Old 02-26-2018   #576 (permalink)
I literally have not driven on them other than to move the car off the lift. So I can't really comment. But I'm sure they're amazing.
Old 02-27-2018   #577 (permalink)
04palaSS's Avatar
Quoted: 54 Post(s)
Do they fit under your 18's?
Old 02-27-2018   #578 (permalink)
Yes and no. They do fit, but you'll need at least 1/2" of spacer to clear the front of the caliper (since it's a 4 piston design, it sticks out farther).
Old 03-18-2018   #579 (permalink)
Man oh man, I'm gunna wait to post pictures of all the stuff I've been doing until I'm all the way done. The new wheels are the big one, but I've been busy.
Over the past week and a half, I've been working on rewiring my stereo top to bottom. I did the big 3 upgrade, ran new wire to the trunk, ran 3 new pairs of RCAs from the headunit to the trunk, and swapped in a pair of new subs to replace the two that were blown. I used KnuKonceptz 0 awg OFC cable for the big 3 and through the car to the distribution block in the back which splits it to 4 awg to each amp. I used all InstallGear accessories for my install and was quite impressed with the quality of the pieces especially for the price. Nice hefty construction. The ring terminals were very hefty and well made, but are nearly 1/4" thick where it gets bolted down. I had to use a pair of longer battery bolts from Advance, which worked out very well. I also used shrink wrap on the rest of the terminal to reduce the risk of shorting. Everything was ran under the carpet and tucked nicely.
Yesterday, my task was to get the steering wheel controls working. When I first installed the double-din, a couple years ago, I used an ASWC-1 harness to retain the steering wheel controls. It worked for about 20 minutes, and quit. Back then, I spent about 3 hours messing with it trying to get it to work to no avail. I was determined to get it to work this time, so I bought a new ASWC-1 (not exactly cheap), and it still wouldn't program. It wasn't detecting the wire that comes from the radio harness for the steering wheel controls. So I went to tracing the wires to see if there was a problem. There was no visible damage to the exposed wire and harness for the ASWC-1, so I started testing continuity backwards, up the steering column. Well, it was good all the way up, so I checked the harness, and boom, no continuity. With no visible cracks or burning/melting, no pushed back pins, and the wire still attached, somehow, the plug for the ASWC-1 went bad on that one wire. So I put the new plug in, and voila, they work.
The one up-side was that since I had the steering wheel apart and the airbag out, I took the opportunity to finally LED retrofit the cruise control buttons on the steering wheel. So my entire interior is finally 100% LED and 100% working (had a few burned out bulbs elsewhere that I fixed).
I still have a few minor things I need to do (run a ground cable on the RCAs and run a new 3.5mm cable for the input on the center console) but its essentially done. Last thing to do is re-tune everything using the distortion detector to make sure I'm not clipping so I don't blow out any more equipment.
I also have one more mod coming that I've been wanting to do for a long time. When that's done, I'll post up a bunch of pictures and walk-around videos.
04Imp38 likes this.
Old 04-28-2018   #580 (permalink)
Well, I know I promised pictures and stuff a while ago. And I did finish with that last mod, but of course, being who I am, decided on one more mod, so you're just gunna have to wait. But I'll post a little bit of a teaser for you
04palaSS and 04Imp38 like this.
TSS (05-02-2018)
Old 04-28-2018   #581 (permalink)
Quoted: 932 Post(s)
Hmm, I have to be honest, @Ryd - I'm not a fan of the wheels. To me, they look overly large on the car - and is that some negative camber I see going on in the rear (I think that's what it's called when you have to angle the wheels to fit when they are too large for the car)???
I always liked your car for the clean OEM look - but it seems that you're going a different route now...
Of course, in the end, it's more important to do what *you* like, but just giving my two cents. :-)
Old 04-28-2018   #582 (permalink)
I can't blame you @jtrosky, I am not giving you much of a picture to go off of. But no, there is no negative camber on the rear. My quarters are rolled to keep the tires from scraping, but no negative camber at all.
Old 04-28-2018   #583 (permalink)
Quoted: 932 Post(s)
Ok, it must just be the came lens causing it to look like that. :-)
Looking forward to some better pictures. I typically like 5-spoke wheels, so maybe it's just the picture.
Old 04-30-2018   #584 (permalink)
Dave_N's Avatar
Quoted: 64 Post(s)
I think the SS wheels look better on your car Jeff.
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Dave_N For This Useful Post:
TSS (05-02-2018)
Old 04-30-2018   #585 (permalink)
@Dave_N I've had em on my car for nearly 5 years. I got tired of them. Plus, the wouldn't fit over the Brembo calipers without spacers, and you couldn't see the Brembos behind them anyway.
02-10-2011 08:15 PM
4 Hours Ago 02:01 PM
33 Replies, 864,557 Views
2014 Impala LT - winter...
3 Days Ago 08:49 PM
by Yury
Last post by Bowtie396
6 Hours Ago 12:24 PM
9 Replies, 229 Views
--------2018 OIL CAPCITY...
4 Weeks Ago 11:12 AM
Last post by retiredpauly
8 Hours Ago 09:37 AM
23 Replies, 599 Views
2015 Impala LT V6 code...
10-20-2018 09:09 PM
by cbsaf
Last post by sheila
1 Day Ago 03:58 PM
23 Replies, 4,299 Views
Trunk light will not...
10-12-2019 10:28 PM
by Z71
Last post by mdubyk
1 Day Ago 09:32 AM
5 Replies, 210 Views
My Defrost won't work in...
08-20-2015 11:01 AM
Last post by Goostoff
1 Day Ago 09:18 AM
20 Replies, 6,002 Views
2014 loud front...
09-18-2019 08:40 AM
Last post by adabiri2
1 Day Ago 07:42 AM
10 Replies, 296 Views
2010 Overkill EFILive...
09-08-2019 01:14 PM
Last post by Joes74challenger
1 Day Ago 09:05 PM
7 Replies, 265 Views
2018 Impala LT engine...
2 Weeks Ago 05:49 PM
Last post by Z71
1 Day Ago 07:47 PM
15 Replies, 568 Views
Tesla Truck
1 Week Ago 09:41 AM
by VladThe
Last post by Dwayne J
2 Days Ago 02:45 PM
27 Replies, 381 Views
