1 in a million... struck by lightning - Chevy Impala Forums
Like Tree11Likes
Old 08-14-2018   #1 (permalink)
A1_Imp's Avatar
Quoted: 4 Post(s)
Hello all, its been a while since I have posted.
My impala was struck by lightning earlier today. The car was off, parked, and suddenly bang! then came the smoke, the lights were on full (high, low, hazards), the horn blaring, the windshield wipers going full speed and the washer fluid spraying everywhere. Everything electrical was on and the remotes didn't work. The force of the strike blasted my trunk open and lowered the driver side window an inch as well as popping my tire. Tried to start and it won't crank, nothing happens other than a few lights and the electronics go haywire.
No idea what the insurance company will do. If it were totaled, should I consider buying it back and changing out the PCM/BCM or whatever? Opinions? Suggestions? Thanks.
I bet this is the way it would have wanted to go, however.
07 Impala LT Red Jewel Tintcoat
Mods List:
SS-style color-matched spoiler
Pioneer AVH-X2700BS Head Unit, back-up camera
Powerbass ASA 400.2x Amp
2 10" Sony Xplode subs in ported box
Leather-wrapped steering wheel w/ audio controls swap
Leather seats
10% tint, 6% eyebrow
6000K 55w HID Kit
Color-match front bowtie/trunk bowtie delete
Color-matched steering wheel bowtie overlay
Full LED conversion
17" factory LTZ rims upgrade, color-match bowties
Dorman sway bar/Moog endlinks
A1_Imp is offline   Reply With Quote Quick reply to this message
Old 08-15-2018   #2 (permalink)
Quoted: 917 Post(s)
Wow - that is crazy!! Did you actually *see* it get struck? Too bad you didn't get that one on video!
Personally, I wouldn't buy that thing back if they total it. Electric-related issues are some of the toughest issues to find and correct and that lightning strike could have damaged every electronic device in the entire car. You may get lucky and only need to replace the main computer - or you may get unlucky and have to keep replacing electronic part after electronic part (or keep having new electronic parts being blown after you replace them).
Just my opinion, of course....
A1_Imp (08-15-2018)
Old 08-15-2018   #3 (permalink)
Quoted: 81 Post(s)
07 Impala is basically worth nothing and the labor to track down and replace a huge amount of the electronics in the car is going to be substantial.
It is going to be a lot more than PCM/BCM, would expect months of weekends to try and DIY repair. Just let her go.
plano-doug and Bill58 like this.
Dwayne J is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Dwayne J For This Useful Post:
A1_Imp (08-15-2018)
Old 08-15-2018   #4 (permalink)
A1_Imp's Avatar
Quoted: 4 Post(s)
Yes, actually I did see it. I caught it out of the corner of my eye, sounded like an airstrike and the blue flash was something out of this world.
Not sure if the car was directly struck or not, there is a sizable chunk of earth missing right next to it, though.
So both of you suggest that it could be more trouble than its worth?
Can a dealer or someone use a scan tool to tell me whats wrong exactly or will it be impossible for them to tell?
Thanks again guys
Mods List:
Leather seats
6000K 55w HID Kit
Full LED conversion
Old 08-15-2018   #5 (permalink)
Quoted: 223 Post(s)
Sounds like a potential nightmare in the making of electrical issues. When you get to thinking about all the potential electrical issues you may face, it probably just isn't worth it. Unless I had some kind of sure way of knowing it would not be a nightmare, I would let them total it and would not buy it back.
Good thing you were not in the car when it hit.
12 lt is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to 12 lt For This Useful Post:
A1_Imp (08-15-2018)
Old 08-15-2018   #6 (permalink)
Quoted: 331 Post(s)
I would expect it to identify _some_ of what has failed. And miss a lot of other stuff. So you would replace a few parts only to then find a few more that have failed. Then repeat that cycle.
And you could find yourself digging into giant wiring harnesses looking for issues there as well. And those wiring harnesses could require disassembling half the car.
If they give you a decent offer to total it, I encourage you to take it.
My house got hit by lightning a few years ago. Fortunately, the damage was not too extensive, but there was surely some excitement to go with.
The lightning hit near the chimney at one end of the house, traveled along the black gas pipe and to the flex pipe feeding the water heater at the other end of the house in the garage. It then arced across the gap between the flex line and the heater case causing the gas line to blow open and starting a fire being fed by the now-escaping gas.
The arcing also somehow blew a hole in the water line coming out of the heater creating a spray of water above the fire. That was a blessing as it kept the fire under control long enough for us to detect it before it had spread outside the heater closet in the garage. (If the kitchen lights hadn't tripped a breaker in the garage forcing me out there to reset it, I might not have found the fire in time. PTL.)
Anyway, it was quite an adrenalin rush that night. And I don't think Rube Goldberg could have invented a better fubar
Dwayne J and A1_Imp like this.
plano-doug is online now   Reply With Quote Quick reply to this message
A1_Imp (08-15-2018)
Old 08-15-2018   #7 (permalink)
A1_Imp's Avatar
Quoted: 4 Post(s)
WOW glad you and your family is alright! The best I can figure happened was the lightning struck a tree about 10 feet away, blew up its roots and arc-ed aross to a steel plow blade right behind the impala, arc-ed into the impala by the right rear tire (rupturing that tire and blackening the strut) which of course fried the car, then the lightning continued through the root system of the tree over to a trailer parked next to the steel-sided garage about 40 feet away. the force popped the hub cap off the trailer, made a crack in the concrete foundation of the garage, exploded the exterior lights and threw the main breaker. It then travelled into the house, through the wiring underground, tripped the main house breaker and ruined at least 2 GFCIs in the house. It knocked out the cable and phone, as well as fried 2 TVs. probably one of the most wild things I have witnessed
Dwayne J and plano-doug like this.
Mods List:
Leather seats
6000K 55w HID Kit
Full LED conversion
Old 08-15-2018   #8 (permalink)
Quoted: 248 Post(s)
honestly the 2012 or newer with limited body style is the way to go (3.6 and six speed trans) if you like the looks of your car still. or if you wanted more rear leg room go with the 2014 and newer body style. i would expect the car to be totaled and would probably fight to have it totaled since the electrical gremlins are going to be substantial as everyone else indicated.
i'm guessing bcm at the very least judging by what you described, but that's just my 02 cents.
Joes74challenger is offline   Reply With Quote Quick reply to this message
Old 08-15-2018   #9 (permalink)
Bill58's Avatar
Quoted: 44 Post(s)
Wow, that's messed-up!
Check fuses and a visual inspection of wire bundles. If the wiring harness got melted, everything is shorted to everything.
Bill58 is online now   Reply With Quote Quick reply to this message
Old 08-16-2018   #10 (permalink)
Quoted: 39 Post(s)
Let them total it. If you have farmers, you might end up as a commercial one day haha
Bill58 likes this.
Old 08-16-2018   #11 (permalink)
Quoted: 81 Post(s)
Neighboor's house suffered a minor hit, only electrical damage TVs and such no structure, the hot-tub repair shop was out literally 10 times, that is a relatively simple thing compared to a car.
The wife had a Mercury Topaz that had an alternator go bad and start cranking out over 15volts at idle and began eating lightbulbs till I figured out what was wrong. Electrical gremlins forever after that and that was a1993 few less electronics.
Old 08-16-2018   #12 (permalink)
Carbide's Avatar
Quoted: 161 Post(s)
Run, Forest, Run!
Carbide is offline   Reply With Quote Quick reply to this message
Old 08-16-2018   #13 (permalink)
2014LTDLTZ's Avatar
Quoted: 35 Post(s)
Sorry to hear about your troubles, but save yourself the aggravation unless you are a masochist. Do your own due diligence checking the obvious things within your skill level (fuse blocks, exposed wiring harnesses, etc.), but don't expect miracles. Highly doubtful this is an easy fix. Way too many places wires could have been shorted together, insulation burnt, modules fried, and the list goes on. Dealership diagnostics are fairly dependent upon a relatively intact wiring harness, which you have no guarantee of knowing you still have.
On the plus side, the lightning didn't hit you.
2014LTDLTZ is offline   Reply With Quote Quick reply to this message
Old 08-20-2018   #14 (permalink)
A1_Imp's Avatar
Quoted: 4 Post(s)
Guys, the insurance company offered $250 to buy it back. So for now, Ill attempt to change the PCM/BCM and see if it will make it run, and if I can't get it to work right, I can always sell it and/or scrap it. Just hate to let it go for $250, and I could part it out
Mods List:
Leather seats
6000K 55w HID Kit
Full LED conversion
Old 08-20-2018   #15 (permalink)
Quoted: 223 Post(s)
If they gave you enough for totaling it, then $250 to buy it back sounds great. However it ends up working out, good luck.
1 high and 1 low Delco Remy 1960's car horn Impala Chevelle Olds Pontiac 12 volt RSS Bot Impala Diecast Toys Cars on eBay 0 11-06-2018 07:30 AM
1 high and 1 low Delco Remy 1960's car horn Impala Chevelle Olds Pontiac 12 volt RSS Bot Impala Diecast Toys Cars on eBay 0 11-04-2018 07:50 AM
Electrical help please... car got struck by lightning A1_Imp Autocare and Maintenance 1 08-24-2018 02:31 AM
1968 Chevrolet Chevy Impala 2 Door Body Side Molding (1 Piece) 777-3110 1 RSS Bot Impala Diecast Toys Cars on eBay 0 07-26-2017 09:21 PM
34 Minutes Ago 11:28 AM
33 Replies, 800,948 Views
What did you do to your...
09-25-2012 07:03 AM
by Joe
Last post by Stockcar10
1 Hour Ago 10:17 AM
7 Replies, 414,924 Views
1977 impala street...
04-03-2018 08:19 AM
1 Hour Ago 10:14 AM
43 Replies, 1,562 Views
1977 impala th400 swap
03-01-2018 09:01 AM
2 Hours Ago 09:19 AM
27 Replies, 889 Views
Help!!! Throttle body
1 Day Ago 09:44 AM
Last post by Erockstrobez08
5 Hours Ago 06:09 AM
9 Replies, 67 Views
Finally went LED on the...
3 Weeks Ago 05:53 PM
Last post by Tesla
6 Hours Ago 05:12 AM
31 Replies, 883 Views
New here.
1 Week Ago 04:48 AM
Last post by Linacruise1467
14 Hours Ago 09:38 PM
9 Replies, 120 Views
2008 Impala SS w/insane...
5 Days Ago 09:47 PM
Last post by tony1679
16 Hours Ago 07:38 PM
8 Replies, 114 Views
Impala 3.5L with Check...
3 Weeks Ago 10:18 AM
by RShea
Last post by sidemouse
17 Hours Ago 06:29 PM
7 Replies, 169 Views
key will not work
11-15-2016 12:02 PM
by landon
17 Hours Ago 06:09 PM
17 Replies, 928 Views
