Wanting to install subs Newest Impala 2016 lt - Chevy Impala Forums
Home Forum Garage Register Garage Community Active Topics Today's Posts Advertise
Like Tree1Likes
Old 03-04-2018   #1 (permalink)
Cmaxim@me.com's Avatar
Hi all I was hoping somebody could please give me links and/or advice on the best way to add a sub to my car. I never have done this before but Iím sure itís something I can do. I just want to make sure I purchase everything I need beforehand. Iím planning on getting a powered 10Ē sub ( Iím not looking to shake the neighbors windows but want to give my factory head unit some punch)
I just need a bit more base to make everything sound better.
Thanks!!
Cmaxim@me.com is offline   Reply With Quote Quick reply to this message
Old 03-24-2018   #2 (permalink)
Will any LOC work? Any suggestions?
Old 03-24-2018   #3 (permalink)
Lettermark's Avatar
Quoted: 4 Post(s)
Crutchfield.com has lots of information and articles and of course, products to sell. Go to that web site and enter your vehicle information and it will return recommendations on what works to add an amplified sub for your Impala.
Generally, most amps (including amplified subwoofers) accept high level inputs (i.e. direct speaker output from your radio) so a LOC (line output converter) is not needed. You should be able to tap into the rear speaker wires and feed that to your amplified subwoofer*. These units can sense when audio is playing and turn on automatically so that saves you from running a turn-on wire or a switch. You will of course have to supply the amp with power, which means running a fused power cable from the battery to the trunk. A not-too-expensive amp wiring kit should have everything you need.
*Some factory radios apply equalization that eliminates some of the bass for the stock speakers. In this case a better approach is to use a product that acts like a line out converter, but restores the missing bass.
Lettermark is offline   Reply With Quote Quick reply to this message
Old 03-26-2018   #4 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
Thanks!!
i got this,
go to my garage photos, I have pics of the subs I put in
I highly recomend using the audio control LC2i, i had a regular LOC and it sucked
Car audio specialist.
tjhenry77 is online now   Reply With Quote Quick reply to this message
Old 03-26-2018   #5 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
and problem is with our car, the seats are so thick you need to have a bit of a more powerful system or you wont be able to hear it well with the seats up.
I recomend a 12" rockford fosgate P3D2-12 sub ($130 or so), with an external amp, the rockford fosgate prime 1200-1d ($240) works perfect with this sub, and that audio control device. GO TO AN AUDIO SHOP and have them make a box custom fit for your car and get it ported and tuned for that subwoofer (this will be around $130 or so). 4 awg wire kit for the battery run to the trunk,
you'll also need a fuse adaptor to tap into factory fuse holder for remote turn on signal.
Old 03-27-2018   #6 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
the factory signals are separated if you have bose in the car for sure. you are 100% correct here. on the rear deck speakers you will find a wire harness connecting them. one for tweeter sound and one for bass sound. MAKE SURE you tap into the bottom set of wires on the wire harness. you can also tap into the wires by the amplifier. I have a diagram in my garage photos that shows at the amplifier what speakers are were. tapping into either the front door or the rear deck speakers will get you that bass signal you're looking for.
***side note*** metra is soon to come out with a t-harness that will bypass the amplifier all together. I will be getting one when they release them. this will pick up a full range signal before it hits the amplifier and you'll have a MUCH better signal. I'm told this piece will be around $400 or so. I'll put something up when this comes out (the part number for this is AX-DSP-MOST1)
Old 03-27-2018   #7 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
Hereís some photos of my amp wiring for reference
63belairboy likes this.
Old 03-27-2018   #8 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
Hereís the wire harness layout for the Bose amp
This is on my 2015 2Lt with Bose. You can tap the wires at the factory amplifier, itís in the trunk passenger side, itís silver, and the wiring plugs you want are on the trunk side of the amp.
Old 03-27-2018   #9 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
Hereís the amp location behind the carpet in the trunk, silver unit only is what youíre looking for
Old 04-05-2018   #10 (permalink)
63belairboy's Avatar
That looks really good
63belairboy is offline   Reply With Quote Quick reply to this message
Old 04-05-2018   #11 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
Thanks buddy :-)
Old 04-05-2018   #12 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
Hereís the subs themselves
Rockford fosgate power t1 12Ē dual 4 ohm
Old 04-10-2018   #13 (permalink)
tjhenry77's Avatar
Quoted: 50 Post(s)
Another cool idea,
Add an iPad to your stereo using a cup holder mount
Old 09-06-2018   #14 (permalink)
todd1972's Avatar
Can someone tell me which wire to cut to get rid of active noise canelation. It’s in my 2017 Impala non Bose system. Thanks
todd1972 is offline   Reply With Quote Quick reply to this message
Old 09-06-2018   #15 (permalink)
Quoted: 926 Post(s)
Another cool idea,
See, to me, that is exactly the type of thing that I want to avoid... I want to be able to do everything via my headunt touchscreen without special "add-on" mounts or devices. Isn't that the whole point of a touchscreen head-unit? Although, the newer cars are at a major disadvantage here since you can't easily just replace the head-unit itself with a unit that does exactly what you want, which sucks. I hate that head-units are becoming so "specific" to the car. While it may be cool when the car is new (assuming it does everything you want), you are stuck with that head-unit forever, even after the tech is outdated... I wish GM went back to more "standard" type head-units so that people could easily install whatever head-unit they wanted...
Air Cleaner Bolt for 2016 Impala LT w/ Flex Fuel V6 Paul Weber Chevy Impala 9th Gen Discussion 0 10-29-2018 08:04 PM
Problem wiring up aftermarket amplifiers to my 2016 chevy impala lt Chevyboy8890 Audio, Video, and Electronics 8 09-07-2018 04:58 PM
Engine Air Filter 2012 2013 CHEVY IMPALA LS LT LTZ 2014 2015 2016 IMPALA LIMITED RSS Bot Impala Diecast Toys Cars on eBay 0 05-18-2018 09:10 AM
Engine Air Filter 2012 2013 CHEVY IMPALA LS LT LTZ 2014 2015 2016 IMPALA LIMITED RSS Bot Impala Diecast Toys Cars on eBay 0 05-03-2018 01:50 PM
Engine Air Filter 2012 2013 CHEVY IMPALA LS LT LTZ 2014 2015 2016 IMPALA LIMITED RSS Bot Impala Diecast Toys Cars on eBay 0 03-07-2018 09:20 AM
Last post by sheila
56 Minutes Ago 06:32 AM
33 Replies, 818,519 Views
Intro
3 Weeks Ago 08:28 PM
by TORQ
Last post by TORQ
10 Hours Ago 09:13 PM
6 Replies, 116 Views
Possible start of...
3 Weeks Ago 06:41 PM
Last post by $hortOak
14 Hours Ago 04:35 PM
11 Replies, 224 Views
2014+ impala Bose stereo...
03-09-2018 08:14 AM
Last post by GearHeadPeter
15 Hours Ago 03:57 PM
57 Replies, 6,810 Views
Hey all, purchasing a...
2 Days Ago 02:59 AM
Last post by Jeremy Stovall
16 Hours Ago 02:46 PM
7 Replies, 95 Views
A/C blows warm air...
3 Days Ago 05:19 AM
by A Sonny
Last post by 1999 White C5 Coupe
17 Hours Ago 02:15 PM
11 Replies, 178 Views
Buying used....waiting...
6 Days Ago 06:25 PM
by wiz-car
Last post by sidemouse
21 Hours Ago 10:07 AM
16 Replies, 410 Views
My Impala saved my life
02-20-2017 07:02 PM
Last post by jbmann
22 Hours Ago 09:03 AM
15 Replies, 2,639 Views
New SoCal Chevy owner
1 Week Ago 08:05 PM
Last post by USN24
1 Day Ago 03:05 AM
5 Replies, 74 Views
New to the forum
1 Week Ago 07:30 AM
Last post by sheila
1 Day Ago 08:29 PM
5 Replies, 83 Views
