04Imp38 Mod Thread - Page 2 - Chevy Impala Forums
Like Tree71Likes
Old 05-02-2017   #16 (permalink)
David3800's Avatar
Quoted: 50 Post(s)
Originally Posted by 04Imp38 View Post
3,000 miles after the rebuild, I put on 2 rear hub bearings. Then proceeded to spin out on I-75 at 70 MPH into a ditch. Thankfully, my car was surprisingly unscathed. I had popped a bead off a tire, bent a rear trailing arm, and a rear hub bearing was loose. I'm so glad nothing worse happened. A couple hundred feet closer or farther, and I would have a different car.
After that ordeal, I replaced the radiator, the loose rear bearing, the passenger front bearing, both trailing arms replaced, tie rod ends, trans lines, rack boot, and an alignment. It sure handled a lot better and no more leaking trans lines!
Attachment 133946
Attachment 133954
Geez man, good to hear your alright! sorry to hear about what happened to your car!
it's also good to hear about the handling and the trans line improvements as well!
<--- They're holding Root beer! 'cuz I don't drink beer. Unless you want it to be beer...
Bunch o' drunks...
David3800 is offline   Reply With Quote Quick reply to this message
Old 05-18-2017   #17 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
04Imp38 Mod Thread
Brief break from posting about things I have done to post what I did today.
I switched over to synthetic 5w-30 5,000 miles ago. I figured since I had 185,000 miles it was sort of a gamble but it couldn't hurt so I did it. I knew I would leak more oil than I was, with the synthetic cleaning stuff out better.
I check the oil about every 500 miles maybe less depending what I'm under the hood for. I noticed in 1-2,000 miles that the oil level was decreasing rather rapidly, so I did some poking around. Sure enough, the engine mount bracket was full of oil; time for a front main.
I couldn't find any videos at all about replacing the front main on a 3800. My Haynes says just take the bolt off and pull the balancer out. Yeah right.
Bro got home with his good impact and the bolt came out no prob. Unfortunately, we couldn't get a puller on the balancer with the oil filter adapter in place. There is a small bolt behind the adapter that I took off and that allowed me to get my puller, affectionately named "Stone Age Puller" due to it looking like it came from that era, in there. It was only making contact on the edge of the balancer bolt, but it came out!! Such a good feeling when that happens
Popped the old seal out, didn't look too bad but after 190,000 it can't hurt to replace it. Put a little RTV on the side of the seal, minding not to put any on the bottom because there is an oil drain hole in the front timing cover there, and tapped it in place. Coated both balancer and seal lip with oil and drove the balancer back in. Tightened everything up, filled her up with oil, and we are good to go.
Took me about 2 hours including tire rotation so not bad for not seeing it done before. Now to see if the new seal does the same thing; shouldn't tho
Size_Atx02 and David3800 like this.
~Joe~
04 Impala LS
Engine: ZZP PCM, ZZP Downpipe, Xcelerator Resonator, Dual Xcelerator Mufflers, 4" Stainless tips, 180 t-stat, Shorter Dogbones, Mount Spacers, Optima Red Top Battery
Interior:
04Imp38 is offline   Reply With Quote Quick reply to this message
Old 05-22-2017   #18 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
04Imp38 Mod Thread
My steering wheel looked like pot as the pictures show. Let's fix it and replace the turn stalk as well
Got it pulled.
Gotta love that clear coat!!
Big thanks to ChrisFix and his vid on this. I used his tips and the products he recommended:
I had to cut and trim the leather which worked pretty good. First time doing this so it's not 100% but looks pretty darn good IMHO. I am really digging the clear coat on the wheel sides, airbag, and plastic covers. Really takes the quality up a notch.
Drove it today and it's so nice. Feels like a better car. I'm going to really like this fix!
plano-doug and David3800 like this.
~Joe~
04 Impala LS
Interior:
Last edited by 04Imp38; 05-22-2017 at 09:47 PM.. Reason: Fixed picture arrangement....again
The Following User Says Thank You to 04Imp38 For This Useful Post:
plano-doug (05-23-2017)
Old 05-23-2017   #19 (permalink)
04palaSS's Avatar
Quoted: 54 Post(s)
Nice job that wheel looks awesome!!!
Project 2004 Impala SS - Restored summer daily
Project 2004 Indy SS - In progress (sold)
Project SS #3 - Winter daily (sold)
Project Finally an 05 SS - New winter daily (sold)
2004 Impala SS - Parts car (RIP)
2004 Impala SS - Parts car #2 (RIP)
2014 Impala LTZ (sold)
2006 Impala SS- Cheap LS4
2004 Impala SS- Yes another one
2004 Trailblazer - The Parts Rig
04palaSS is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to 04palaSS For This Useful Post:
04Imp38 (05-23-2017)
Old 05-25-2017   #20 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
My radiator never really has had a good top mount situation. I've tried zip tying it but they always broke. Tried metal zip ties but they didn't secure hard enough.
Finally bought some speed nuts and bolts and fixed it right. 04Imp38 Mod Thread-img_4769.jpg04Imp38 Mod Thread-img_4770.jpg
Funny now most of my front end noise is gone
David3800 likes this.
~Joe~
04 Impala LS
Interior:
Old 05-26-2017   #21 (permalink)
David3800's Avatar
Quoted: 50 Post(s)
Got it pulled.
Duplicolor paint from amazon. GM Lt Neutral
Old leather New leather
All finished!
Hoo! Thats Awesome!!! So much better. The wheel looks almost original! Great job.
Bunch o' drunks...
The Following User Says Thank You to David3800 For This Useful Post:
04Imp38 (05-26-2017)
Old 05-30-2017   #22 (permalink)
Quoted: 39 Post(s)
Nice work! Looking great!
04Imp38 likes this.
The Following User Says Thank You to donmateo For This Useful Post:
04Imp38 (05-30-2017)
Old 06-07-2017   #23 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
04Imp38 Mod Thread
I love cleaning my car, but the more I clean it the more it needs to be painted Lol Check this out: 04Imp38 Mod Thread-img_4837.jpg
Too many scratches and scrapes to fix without repainting, but it still shines good
Also fixed my front door handles. Whoever the dingbat was that put them in didn't make sure the bottom was snapped in before tightening the bolts, leading to this:04Imp38 Mod Thread-img_4843.jpg I took the handles off and straightened everything out and they line up perfect now. Getting the driver handle out was fun due to the keyed lock getting in the way, but I figured it out.
~Joe~
04 Impala LS
Interior:
Old 06-08-2017   #24 (permalink)
Quoted: 101 Post(s)
That hood might could be saved with a good buffing.
If you don't have a good buffer, I recommend this one:
Significantly cheaper than repainting the hood, although by the time you buy the pads and compound, you'll be about the cost of a repaint. HOWEVER, you will now have a professional quality buffer and all of the materials needed to buff out anything you want for a LONG time.
David3800 and 04Imp38 like this.
Precision 6262 Turbo, ZZP Z3, CXRacing intercooler, ZZP 3" Cat-back, Muffler delete, Bosch 42.5# Injectors, Bosch fuel pump, CTS-V Brembos, Stainless lines, BC Racing coilovers, Dorman solid sway bar, SPEC-D LED headlights, LED heads and fogs, Quad tails, C5 reverse lights, All LED interior, LED 6 gauge cluster retrofit, LED puddle lights, LED underglow, Debadged, Painted emblems, Color-matched trim, Kenwood DDX271, Polk Audio dxi6500 components, Polk Audio db690, Hifonics GLX100.4, 2x Polk Audio db1240 in custom box, Hifonics ZRX1800.1D, KMC District, Nitto NT555G2, SS tail covers, SS spoiler, SS Lip, 20% tint, Black mesh grille
Old 06-08-2017   #25 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
Buffer
Significantly cheaper than repainting the hood, although by the time you buy the pads and compound, you'll be about the cost of a repaint. HOWEVER, you will now have a professional quality buffer and all of the materials needed to buff out anything you want for a LONG time.3M buffing system
Thanks for the info Ryd, I'll check that out for sure.
It's too hard to see in the pictures, but there's a ton of stone chips that are down to bare metal, and what looks like a nice big spot of bird doo doo corrosion that is starting to rust. I don't know how long I have before it's past saving, but I am willing to put a new hood on when it comes time.
~Joe~
04 Impala LS
Interior:
Old 06-08-2017   #26 (permalink)
Quoted: 101 Post(s)
Yeah, chips and the like can't be saved with buffing unfortunately. But a buffer is still a great tool to have around!
Old 06-09-2017   #27 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
So funny story here. @09_Impala_SS just bought BCRacing coilovers yesterday, and yesterday I had finally saved up enough to buy them. So here it is:
My shocks are doing pretty poor right now, so while I'm at it I might as well replace them with the best. I can't wait!! Will keep everyone updated, I plan to install them as soon as they come then get an alignment shortly thereafter.
David3800 and 09_Impala_SS like this.
~Joe~
04 Impala LS
Interior:
RYD SLO (06-10-2017)
Old 06-09-2017   #28 (permalink)
09_Impala_SS's Avatar
Quoted: 66 Post(s)
Lol that is funny. I see you bought them from ZZP. I purchased them directly from BCRacing. Not to be the barer of bad news. But I paid $1,020.00 at the BC site using a $30 off coupon. BC30OFF
IG: 09_impala_ss
09 Impala SS:
BC Racing Coilovers
Rohana RF2 19x8.5 +35
Hubcentric Rings
Pioneer AVH-X4700BS
Rockford Fosgate Prime R1653 6.5's
2 MTX 1200W Subs
Tinted Head/Taillights from VIPMotoz
07 Impala LT: T-Boned/Totaled
Milanni Force 457 18x7.5
Pioneer AVH-X4700BS
2 MTX 1200W Subs
Monroe Quick-Struts
CM 97-03 Grand Prix Lowering Springs
09_Impala_SS is offline   Reply With Quote Quick reply to this message
Old 06-09-2017   #29 (permalink)
04Imp38's Avatar
Quoted: 241 Post(s)
04Imp38 Mod Thread
I had noticed that but I wanted the new top plates for the rears so I ordered it with those too. That added $65 to the normal price.
~Joe~
04 Impala LS
Interior:
Old 06-09-2017   #30 (permalink)
Quoted: 66 Post(s)
Lol so did I. BC Racing sells them for $995 or $1,050.00 with the plates for the rear. Which brought it to $1,020.00 with the coupon. ZZP charged you more then the manufacturer. Which is understandable because they want to cover the overhead of employees etc.
IG: 09_impala_ss
09 Impala SS:
BC Racing Coilovers
Hubcentric Rings
Pioneer AVH-X4700BS
2 MTX 1200W Subs
Pioneer AVH-X4700BS
2 MTX 1200W Subs
Monroe Quick-Struts
The Wiring Diagrams Thread battleship7 Mechanical and Electrical Problems 10 12-07-2018 08:28 AM
2016impalalt's build/mod thread 2016impalalt Recent Mods/Weekly Updates 15 06-04-2018 12:05 PM
Not Receiving eMail Notifications of Thread Replies JerseyHarold Impala Forum Site Issue Forum 1 11-13-2017 07:46 AM
Weird Electrical No...
07-15-2019 06:25 PM
Last post by !Tommy
2 Hours Ago 10:35 PM
8 Replies, 127 Views
Last post by sheila
5 Hours Ago 07:16 PM
33 Replies, 831,920 Views
8th gen impala rust
03-12-2019 06:16 AM
Last post by !Tommy
5 Hours Ago 07:05 PM
12 Replies, 708 Views
My reintroduction
1 Day Ago 10:18 PM
by !Tommy
Last post by !Tommy
5 Hours Ago 07:00 PM
7 Replies, 81 Views
Forward Collision Alert...
1 Week Ago 11:00 AM
Last post by Locker Room Junk
7 Hours Ago 05:32 PM
9 Replies, 220 Views
Oil consumption 3.6
12-24-2017 02:20 PM
Last post by 12 lt
8 Hours Ago 04:27 PM
24 Replies, 5,366 Views
The transformation of my...
07-22-2013 05:37 PM
by RYD SLO
Last post by RYD SLO
8 Hours Ago 03:51 PM
601 Replies, 39,113 Views
09 Impala won't move...
1 Week Ago 06:50 PM
Last post by Bill58
12 Hours Ago 12:25 PM
5 Replies, 130 Views
What did you do to your...
09-25-2012 07:03 AM
by Joe
Last post by Stockcar10
14 Hours Ago 10:08 AM
7 Replies, 426,772 Views
Lets Try a LS4
10-20-2018 07:55 AM
Last post by 04palaSS
16 Hours Ago 08:01 AM
46 Replies, 2,774 Views
