WickedGoat's Build/Maintenance Thread - Page 7 - Chevy Impala Forums
Like Tree42Likes
Old 07-22-2017   #91 (permalink)
Quoted: 932 Post(s)
Originally Posted by WickedGoat View Post
I am going to run the GPS to work tomorrow and see how that does.
Hey Matt - did you get a chance to test the GPS system? If so, did everything work ok? Any questions about the interface of the new skin? Don't hesitate to reach out if you have any questions!
Old 07-22-2017   #92 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
Everything seems to be good with it... Only 1 small issue I have... Just replied to your PM and gave you the details there... Don't think it is a Rosen issue...
2014 Chevy Impala LTZ Limited
- 5% Window Tint, Rosen GM1210 Stereo, Polk Audio Components and 6x9s, Pioneer, Kenwood amps and sub, Addco Rear Sway Bar, ZZP Strut Tower Braces, LED fogs and low beams, back up and interior lighting, SS dash, stereo and shifter trim.
2004 Pontiac GTO
- Quicksilver on Black 6 speed, garage queen
2004 GMC Yukon SLT
- The reliable back up... can't part ways with it!
2016 GMC Acadia Denali
- Quicksilver on Black, AWD, rear DVD, 2/2/3, nice...
WickedGoat is offline   Reply With Quote Quick reply to this message
Old 07-23-2017   #93 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
Time for a review of the stereo system... Flat out, it sounds great. I can't speak highly enough about the Polk Audio speakers... Great bang for the buck. They haven't broken in yet but they will sound better when they do. The Pioneer amp is feeding them 100 watts RMS each and is doing fine for a budget amp. The whole system is actually a budget install and it sounds great. I am going to buy a sound processor and most likely it will be the Kicker Front Row. The price is good, $190-$250 is where I have seen it. It is a 6 channel and will push 8 volts to the amps. The tuning features are good enough for an amateur such as myself and will really wake up what I feel is a good system.
I need to add some sound deadening to the license plate and the trunk lid... Noticed a little rattle when I filled it up with gas on Friday night. I will do the rear doors eventually just to get the same feel the front doors now have.
The Rosen is just a great stereo for the system. It does have its quirks, and it is just a few tweaks away from being perfect, but since Rosen is pretty much done with these stereos, it is what it is. The 1210 has a fair amount of tuning built into it and gets it done. Still happy I made the choice to buy it and not another brand.
I am on the fence with wanting more bass. The Kenwood sub and amp does well, but sometimes I feel like I want more. I may sell it and go after a 12", 500 watt RMS Kicker 2 ohm sub and supporting box. The Kenwood amp I have now will push 500 watts RMS at 2 ohms so it will work fine. Overall, I am happy with it and now the commute to work is even more enjoyable. So if anyone is looking for a budget upgrade, $350 will get you 2 pair of Polk speakers and a Pioneer amp to run them. You can add some bass for another $350, add your amp wiring and upgrade your stereo and you should come in under a grand doing the work yourself and not spending too much on a new head unit. The Impala is very easy to take apart and run wiring and both my amps fit under the front seats. So the only thing in the trunk is the box and while it is highly unlikely, I can take it out if I need the space. Also, not sure if many people are aware of this, in our trunks, under the carpet close to the back seat, is an access cover for the fuel pump. The fuel tank does not have to be dropped to replace the fuel pump. Just pull back the carpet, unscrew the access cover and bam... You can get right at the pump and replace it quickly. This was something I thought of when deciding to torture myself putting the amps under the front seats.
Lastly, buy a good amp install kit. I thought Stinger was decent but they apparently are falling apart. KnuKoncepts is the way to go. I chased a problem longer than I should have and it came down to a faulty, brand new fuse. Anything can be new or rebuilt and be faulty, but be diligent when chasing problems and buy good stuff in the first place.
Next up on the mod list is tail lights and bowties. I have trans fluid ready and awaiting, oil change is due shortly. Need to check the air filter and I think I am going to change the spark plugs in 5,000 miles which will be 50,000 on the car. I get the whole 100,000 mile plug change concept. But since these plugs can be removed without pulling the intake, why not? It won't hurt anything other than my wallet for a brief moment. Eight months of ownership and I am still happy with my decision to buy this Impala... Fits the bill perfectly for my needs as a commuter.
jtrosky likes this.
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 07-31-2017   #94 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
Changed the oil and trans fluid yesterday. Went with a Mobil 1 extended filter and Mobil 1 synthetic. I used the Castrol Transmax Dex 6 again. It came out pretty good color wise, so I will push the trans drain and fill out to maybe a once a year deal, doing it twice at 5 quarts at a time. Seems reasonable to me and gives me good piece of mind. I still have nightmares over 2 Grand Prix trans rebuilds... Still makes me throw up in my mouth a little, not that y'all really needed to know that...
I am waiting for a good weekend to do my bowties and tail lights. My daughter has a swim meet this coming weekend, regional championship, so this one is out. Maybe the following weekend.
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 09-24-2017   #95 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
Nothing much to write about today. Haven't had much time to do anything other than a recent oil and trans fluid change. In fact, it is due for oil again soon. Other than wash it a couple of times, no new mods or changes. I am going to change the spark plugs soon as I am getting close to 50,000 miles. No way I am waiting to 100,000. $40 or $50 on spark plugs and my time is worth it to me.
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 10-29-2017   #96 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
Boring update... Just an oil change, along with air filter and cabin air filter changes. Like I said, boring... I think mods are going to wait until spring, although I have been looking at LED headlamp and foglamp replacements. Anyone have any suggestions?
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 01-27-2018   #97 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
Farting around with picture uploading, you know, since PhotoBucket f$#ked us all over... F you PhotoBucket...
WickedGoat's Build/Maintenance Thread-vzm.img_20161103_163530_zpsuiqh0pxb_edit_1480116198879.jpg
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 01-27-2018   #98 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
That was my day one purchase pic, still sitting at the dealership, bone stock... Now that I got this picture uploading thing kinda sorta figured out, I can post pics of stuff again.
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 04-07-2018   #99 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
Not too much to update... I dipped the Bowtie emblems black finally. I also started the woodgrain to techno steel interior trim swap. The dash piece is swapped and I am awaiting the stereo and console surrounds to arrive. I know it will be hell finding the door panel pieces by themselves so if I can't find them I will do something with mine.
I will be replacing the tires soon and I want to go to 245/45-18 so that will necessitate a wheel swap. If I can pull the trigger on new wheels, my stock LTZ 18s will be for sale.
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 05-15-2018   #100 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
I got the stereo surround and console trim pieces installed a couple of weeks ago. Only thing left to do is the door panel pieces. Looks so much better with the techno steel.
Did an oil change and switched over to E85 to see if it will help or hinder me... Thread started in 8th gen forum.
Lastly, replaced my front bumper on Saturday because someone decided to back into it a few weeks ago. I ordered one already painted and ready to install. Install was really simple, aside from the foglamp mount rings... they were a b*tch to remove. Paint match was spot on.
Time for tires and possibly wheels. If I do get wheels, there will be a set of near mint LTZ 18s for sale shortly.
04Imp38 likes this.
2004 Pontiac GTO
2004 GMC Yukon SLT
Old 05-15-2018   #101 (permalink)
mwilson62000's Avatar
Quoted: 9 Post(s)
^^where did you buy the prepainted bumper?
2012 LT - Silver Ice Metallic
mwilson62000 is offline   Reply With Quote Quick reply to this message
Old 05-15-2018   #102 (permalink)
TeeRev's Avatar
Quoted: 124 Post(s)
Hah. I replaced my bumper last year after someone backed into it... only to have someone scuff it again less than a year later.
And not even a note. Le sigh.
I can't speak for WickedGoat but I got mine off of eBay, seller mbiauto. Just search for "2006 Impala bumper cover". I was actually very impressed by how well the paint matched. I can't speak for the quality of the paint since it's only been on a year or so, but it's held up really well. The bumper fits like OEM too. (That's actually it in my profile picture)
mwilson62000 likes this.
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
LED headlights / fog lights
Stant locking gas cap
GM molded splash guards
McGard locks
TeeRev is offline   Reply With Quote Quick reply to this message
Old 05-15-2018   #103 (permalink)
Quoted: 9 Post(s)
Thx. Been debating a while on switching mine to a ďfogĒ bumper cover, but wasnít sure of the quality of those. Appreciate the feedback on mbiauto. I also noticed a small crack developing in mine right above license plate. Itís not very noticible, but if it gets worse it will definitely make me want to replace.
Old 05-16-2018   #104 (permalink)
DanielSapp's Avatar
I’m interested in your LTZ 18s if you do put them up for sale
DanielSapp is offline   Reply With Quote Quick reply to this message
Old 05-16-2018   #105 (permalink)
WickedGoat's Avatar
Quoted: 142 Post(s)
I got it off eBay...
https://rover.ebay.com/rover/0/0/0?m...2F321135337304
2004 Pontiac GTO
2004 GMC Yukon SLT
The Following User Says Thank You to WickedGoat For This Useful Post:
mwilson62000 (05-16-2018)
The Wiring Diagrams Thread battleship7 Mechanical and Electrical Problems 10 12-07-2018 09:28 AM
2016impalalt's build/mod thread 2016impalalt Recent Mods/Weekly Updates 15 06-04-2018 01:05 PM
Not Receiving eMail Notifications of Thread Replies JerseyHarold Impala Forum Site Issue Forum 1 11-13-2017 08:46 AM
2018 Impala LT engine...
2 Weeks Ago 05:49 PM
Last post by Z71
1 Hour Ago 07:47 PM
15 Replies, 527 Views
02-10-2011 08:15 PM
1 Hour Ago 07:33 PM
33 Replies, 864,207 Views
Tesla Truck
1 Week Ago 09:41 AM
by VladThe
Last post by Dwayne J
6 Hours Ago 02:45 PM
27 Replies, 362 Views
2014 Impala LT - winter...
2 Days Ago 08:49 PM
by Yury
Last post by greed
13 Hours Ago 07:07 AM
5 Replies, 144 Views
Squeaky Left Turns
04-06-2017 04:40 PM
Last post by Buttnaked22
14 Hours Ago 06:26 AM
6 Replies, 1,514 Views
Oil Pan Gasket Change
02-18-2016 06:02 PM
by 4t65e
Last post by Flying Trunk Monkey
20 Hours Ago 12:23 AM
8 Replies, 7,031 Views
Back with another Impala...
1 Week Ago 09:02 AM
Last post by tonyc712000
2 Days Ago 10:27 AM
6 Replies, 156 Views
67 SS Owner
2 Weeks Ago 05:16 PM
2 Days Ago 10:25 AM
7 Replies, 116 Views
2006 LS power door...
03-15-2013 05:06 AM
by TaylorS
Last post by LiamBouchard
2 Days Ago 07:58 AM
8 Replies, 5,886 Views
2012 LTZ, brake...
3 Weeks Ago 02:01 PM
2 Days Ago 07:54 AM
6 Replies, 191 Views
