Dustin's 2000 Impala Build Thread - Chevy Impala Forums
Old 03-01-2016   #1 (permalink)
dustin.frisbie's Avatar
I am planning on fixing up a 2000 Impala I recently acquired. So I wanted a thread to sort of document the progress as I go.
The Before Details: (Things that don't work/need replacing)
Steering wheel buttons
Auto Dim rear view mirror
Map Lights
Heater/AC Control Unit
Cigarette Lighter
Wheel Speed Sensor / Wiring Harness
TCC / Solenoid / wiring
Side View Mirror adjustment control
Steering Column shroud
Headlight housings
Dents pulled
Minor Rust removed
Wheels / Rims
Blinker Intermittent Operation
The Before Picture:
Sent from my LG-VS985 using Tapatalk
dustin.frisbie is offline   Reply With Quote Quick reply to this message
Old 03-01-2016   #2 (permalink)
Interested to see the progress! Sounds like most of the issues you have are pretty minor and easy to address.
Old 03-01-2016   #3 (permalink)
Yeah today I knocked out the heater/ac control unit... Vacuum line was broken in the engine bay. I also fixed my blinker issue, which I forgot to put in the list of stuff to do, and my cigarette lighter.
Old 03-02-2016   #4 (permalink)
Found the issue today with my auto-dim mirror and map lights. The plug on the back of the mirror has a little bit of play while fully inserted which vibrations and what not will cause it to loose power. Fixed it by pulling the plug out blowing both ends out with air, then instead of fully inserting I put it in till right before the clip locks in place. It is tight enough to not jiggle loose and maintains its connection.
Old 03-03-2016   #5 (permalink)
Fixed the issue with my Trac Off and ABS indicator lights coming on... It was as simple as just removing and cleaning the connectors on the brake pump and the 2 front wheel speed sensors!
Old 03-03-2016   #6 (permalink)
You may need to replace the speed sensor harnesses in the future. Keep an eye for it to return. This issue likes to be intermittent.
Old 03-03-2016   #7 (permalink)
Yeah I was actually planning on replacing the harnesses, but I figured what the heck, might as well try to just clean them. The harnesses actually looked really good, the sensors however looked pretty old.
Old 03-07-2016   #8 (permalink)
Sanded the few rust spots along the bottom of the doors and on the fender and primed them. Also removed all the rust from the wheels.
Old 03-08-2016   #9 (permalink)
So I bought some paint that is a match to my impala and lightly went over my primer spots today, doesn't look the greatest but better than rust or primer. I also smoked the fog lights and the headlights a little.
Old 03-09-2016   #10 (permalink)
Fixed side view mirror adjustment problem, my switch and the one I got from junk yard were bad. Ordered a new one put it in today, now the side mirrors can be adjusted in all directions instead of just up.
*Edited for spelling.
Old 03-11-2016   #11 (permalink)
Replaced my clock spring today... What a pain in the ass that was! Nothing wanted to go easy!... Lol Now my radio buttons on my steering wheel work, haven't tested cruise control yet. However my airbag light is still lit up on my dash. Does the 2000 impala have a weight sensor for the front passenger so if there isn't enough weight it deactivates he passenger airbag?
Old 03-17-2016   #12 (permalink)
Front right outer CV Boot got replaced today.... Only a thousand more things to fix!... Lol
Old 03-18-2016   #13 (permalink)
Fizzy's Avatar
Quoted: 29 Post(s)
I know all about that never ending "to do" list. At least I don't have an old lady handing me her version of one!
96 Impala SS - Powerdyne supercharger, Comp Cams 1.6 Ultra-Golds & top-end kit, Clear Image TRI-Y ceramic coated headers, Accel ignition, BBK 58mm TB, SVO injectors, March Serpentine, PCM4Less (dyno tuned), Hurst Roll Control, Borla SS full exhaust, Stage II trans TCI Streetfighter, Inland Empire aluminum driveshaft, Eaton 3:42 Posi, Hotchkis suspension and sway bars, Bilstien shocks - Faster than a Honda with a fart can
Fizzy is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Fizzy For This Useful Post:
dustin.frisbie (03-18-2016)
Old 03-18-2016   #14 (permalink)
gp9c1's Avatar
hey dustin, is the auto dim rear view mirror also exist in a 2002 impala with onstar? ive thought that my car might have that but never noticed anything. 2002 LS 3.8 impala here
gp9c1 is offline   Reply With Quote Quick reply to this message
Old 03-18-2016   #15 (permalink)
gp9c1's Avatar
ive experienced this too. dealer says its a issue with the wiring harness that would cost 3k to replace. they only replace the whole thing at the dealer. My mechanic did some work on my wiring harness and claims its good but I have problems with abs and trac not working.
Buick Lucerne Super FE4 Struts on Impala SS and other suspension mods. hatzie 8th Gen Suspension 8 06-12-2019 08:19 AM
2000 Impala Engine Swap DvS503 7th Gen Engine Performance 9 05-08-2019 07:51 PM
2000 Impala LS turn signal problem dandyd Chevy Impala 7th Gen Discussion 1 10-15-2018 06:53 PM
2000 Impala, I think it's a blown head gasket rjpeek Chevy Impala 7th Gen Discussion 0 10-13-2018 02:00 PM
2000 Impala LS Auxiliary Input Sullivan Sellers Audio, Video, and Electronics 1 10-05-2018 09:49 AM
--------2018 OIL CAPCITY...
2 Weeks Ago 11:12 AM
Last post by RobHazmat
3 Hours Ago 05:06 PM
15 Replies, 361 Views
Tools
05-06-2018 09:54 AM
Last post by hatzie
3 Hours Ago 04:30 PM
285 Replies, 7,514 Views
02-10-2011 08:15 PM
4 Hours Ago 04:02 PM
33 Replies, 858,320 Views
What did you do to your...
09-25-2012 08:03 AM
by Joe
Last post by vndin
5 Hours Ago 03:07 PM
7 Replies, 433,705 Views
2014 loud front...
09-18-2019 08:40 AM
Last post by Rnungaray08
8 Replies, 223 Views
2014 Impala 2lt...
08-27-2018 09:14 PM
Last post by Cleatus1
10 Hours Ago 09:56 AM
9 Replies, 2,034 Views
Finally went LED on the...
05-27-2019 06:53 PM
Last post by rjayl
17 Hours Ago 02:33 AM
61 Replies, 2,958 Views
Spark plug change, 2003...
07-28-2019 06:25 AM
Last post by gcrawdad
1 Day Ago 07:53 PM
9 Replies, 322 Views
Impala 9th gen(2009)...
10-15-2019 08:13 PM
Last post by camaroz28
1 Day Ago 06:42 PM
17 Replies, 562 Views
2016 Impala front end...
1 Week Ago 10:19 AM
1 Day Ago 06:38 PM
9 Replies, 205 Views
