Impala_9c1 Mod Thread (WITH SURPRISE!) Pic heavy - Chevy Impala Forums
Home Forum Garage Register Garage Community Active Topics Today's Posts Advertise
Old 02-27-2016   #1 (permalink)
Impala_9c1's Avatar
Talking Impala_9c1 Mod Thread (WITH SURPRISE!) Pic heavy
Hey all who get to own such an awesome car. I want to show you my my progression.
Here is my 2007 9c1 on the day I bought it:
Here it is with the mods. (New lower bumper with police brake air intake, LED spotlight, onstar antenna, new upper and lower grille)
Here it is with my new 2012 Impala LT (also my last day at owning the 9C1!)
Here is my new 2012 LT. I plan on adding LED Spyder Tails and possibly halos, maybe a spoiler and still thinking about a bumper and grille swap like i did with my 9C1! ANy other ideas for mods?
Impala_9c1 Mod Thread (WITH SURPRISE!) Pic heavy-906095_1057228494301853_3945954632379051438_o.jpg   Impala_9c1 Mod Thread (WITH SURPRISE!) Pic heavy-12507562_1106118236079545_8384782958849612932_n.jpg   Impala_9c1 Mod Thread (WITH SURPRISE!) Pic heavy-12227742_1066029816755054_7580702971860545820_n.jpg   Impala_9c1 Mod Thread (WITH SURPRISE!) Pic heavy-12705718_1116191315072237_7738713706617474618_n.jpg
Impala_9c1 is offline   Reply With Quote Quick reply to this message
Old 02-27-2016   #2 (permalink)
Majestic9C1's Avatar
Quoted: 21 Post(s)
half the pics arent working
2007 Impala 9C1.. Lowered, KYB, ZZP, DR, K&N, JBL... etc.etc.
2000 Camaro Z28..
Majestic9C1 is offline   Reply With Quote Quick reply to this message
Old 02-27-2016   #3 (permalink)
carbon_x's Avatar
Quoted: 10 Post(s)
The pics at the top are the same as the attached images.
Looks nice! Keep up the good work, and keep up on the pics!
2013 Impala LT - Click the picture to check out my build thread!
carbon_x is offline   Reply With Quote Quick reply to this message
Old 02-27-2016   #4 (permalink)
Quoted: 21 Post(s)
oohhh I get it now
2000 Camaro Z28..
Old 02-27-2016   #5 (permalink)
Breathe Easy
Bud54's Avatar
Congrats on the 2012 LT! Good looking car!
Bud54 is offline   Reply With Quote Quick reply to this message
Old 02-29-2016   #6 (permalink)
Impala_9c1's Avatar
Ordered a nice honey comb grill set in black (stock) off eBay for $60 shipped!
Old 03-01-2016   #7 (permalink)
Congrats! nice 12
Old 03-15-2016   #8 (permalink)
Impala_9c1's Avatar
Received my used spyed headlights today!
very excited, but there are some issues with them looking for help.
What works:
High beams
Side LED and halo rings
right parking light
both signal lamps (parking lights do work when activated by signal!)
Whats not working:
left parking light
daytime running lights
headlights
Any ideas? Thanks. The guy spliced into the harness.
Old 03-15-2016   #9 (permalink)
Quoted: 932 Post(s)
How are they wired? Did they come "pre-wired" and you just connected them to the stock connectors? When new, they are not "plug and play" - you have to wire LED's and Halos separately. But the low-beams should work - unless the bulbs are bad (if that's even possible - not sure if the H1 bulbs can work as high-beams, but not low-beams).
Daytime running lights are just low beams (different intensity, I guess). Just wondering if the issues are all bulb-related...
Were they sold as "working"? If so, depending on what you paid, I might fight with the seller... You can get them brand new for $240....
jtrosky is online now   Reply With Quote Quick reply to this message
Old 03-15-2016   #10 (permalink)
KG2014's Avatar
Quoted: 59 Post(s)
I would say the guy hooked them in wrong, what size bulbs do they use? I doubt both low beam bulbs are dead. Make sure they are hooked up, should be the green wire, also check the fuses.
Yeah I got a few mods.......
Check out my mod thread here
Check out my garage here
KG2014 is offline   Reply With Quote Quick reply to this message
Old 03-15-2016   #11 (permalink)
Impala_9c1's Avatar
So the parking light I figured out there are two separate coils in it. One for parking light and one for the signal functions. The parking coil burnt.
I bought these used off eBay for $100 the seller said works fine except for small crack in lense which doesn't affect usage.
The lights are scratched I can fix that but when I told the seller this he said sorry buddy for what you paid what did you expect?
Now everything works except low beam function. Both on automatic light mode and when controlled by the switch.
I looked at wiring. He had the Halo and Led hooked up to the parking light wire.
Everything with the low beams looks okay maybe I just didn't connect them all the way?
Fuses are good I'm running my original stock lamps now for safety reasons
Old 03-15-2016   #12 (permalink)
KG2014's Avatar
Quoted: 59 Post(s)
I would check over the wiring inside the housing for the low beams. I would try swapping a bulb just to check it.
Old 03-16-2016   #13 (permalink)
Impala_9c1's Avatar
One last question for when i go to auto zone, are the headlight bulbs replaceable? I tried to stupid remove one as you would a normal bulb and broke some soldering(between bulb and connector)... Which I fixed it, and plan to buy new headlight bulbs and connectors at auto zone tonight and then playing around with wiring.
These headlights I presume are spyder or eBay.. they say eagle eye on the lense.. TIA everyone wiring these isnt a porblem just determining if a bulb broke or something like that
Old 03-16-2016   #14 (permalink)
Quoted: 932 Post(s)
I just took a look at my spare set of Spyder CCFL halo headlights (black) and they actually say "Sonar" on the bottom of the lens (under the turn-signal bulb) - along with DOT info...
EDIT: Now that I look closer at yours, I believe that yours are NOT Spyder - but actually Spec-D halo headlights (I think that is the other brand). Completely different style (my turn-signal bulb area looks completely different).'
EDIT: Hmm, maybe they are not Spec-D (which is a good thing!). I see them listed as "Unbranded/Generic" and "Eagle Eyes" (like you mentioned). Definitely not Spyder though. I was wondering about the "NO HID" warning sticker as I've never seen that on my Spyder headlights.
Old 03-16-2016   #15 (permalink)
KG2014's Avatar
Quoted: 59 Post(s)
The bulbs should just twist out, unless held on with a little clip into the projector.
Tools
05-06-2018 09:54 AM
4 Hours Ago 02:05 PM
278 Replies, 7,347 Views
Electric Crate Engines...
2 Weeks Ago 08:51 AM
Last post by VladThe
4 Hours Ago 01:58 PM
27 Replies, 581 Views
02-10-2011 08:15 PM
5 Hours Ago 01:44 PM
33 Replies, 856,838 Views
Is an EGR valve used on...
07-14-2019 10:32 AM
by LouF
Last post by Fast Eddie
6 Hours Ago 12:11 PM
10 Replies, 273 Views
Low Fuel Warning
2 Weeks Ago 04:16 AM
by MarkTN
Last post by MACJUBZ
7 Hours Ago 10:59 AM
14 Replies, 425 Views
What car insurance do...
05-20-2018 04:20 PM
Last post by DavidLMorris
8 Hours Ago 10:43 AM
29 Replies, 961 Views
--------2018 OIL CAPCITY...
1 Week Ago 11:12 AM
Last post by 1954 Chevy
9 Hours Ago 09:07 AM
6 Replies, 182 Views
Rear Defroster Burnt...
07-04-2010 08:12 AM
Last post by TeeRev
12 Hours Ago 06:46 AM
302 Replies, 181,871 Views
Bouncing feeling coming...
2 Days Ago 03:41 PM
Last post by 1970cs
14 Hours Ago 04:08 AM
7 Replies, 77 Views
--Stock 19" Rims to 20"...
3 Weeks Ago 07:18 AM
17 Hours Ago 01:38 AM
9 Replies, 315 Views
