what code reader???... - Chevy Impala Forums
post #1 of (permalink) Old 08-12-2014
DiGiacomo
DiGiacomo's Avatar
Quoted: Post(s)
Question what code reader???...
I think that i have enough horses under the hood........but i would like to see if they are getting the proper care.......
i would like some recommendations on a code reader.......i see them listed from high dollars to 14.95............what do i need......... i just want a good product that i can load up on my computer, tablet, or smart phone......
i have a 2013 ltz
thanks a lot.........seems like a good bunch of people on this forum.........that is rare...
post #2 of (permalink) Old 08-12-2014
Quoted: 100 Post(s)
If you have an android tablet or phone, get the Torque Pro app ($5). You'll need an OBDII bluetooth adapter ($10) too. It will not only read and clear codes, but you'll be able to monitor a variety of gauges that were never available from the factory.
Precision 6262 Turbo, ZZP Z3, CXRacing intercooler, ZZP 3" Cat-back, Muffler delete, Bosch 42.5# Injectors, Bosch fuel pump, CTS-V Brembos, Stainless lines, BC Racing coilovers, Dorman solid sway bar, SPEC-D LED headlights, LED heads and fogs, Quad tails, C5 reverse lights, All LED interior, LED 6 gauge cluster retrofit, LED puddle lights, LED underglow, Debadged, Dipped emblems, Color-matched trim, Kenwood DDX271, Polk Audio dxi6500 components, Polk Audio db690, Hifonics GLX100.4, 2x Polk Audio db1240 in custom box, Hifonics ZRX1800.1D, KMC District, Nitto NT555G2, SS tail covers, SS spoiler, SS Lip, 20% tint, Black mesh grille
RYD SLO is offline
post #5 of (permalink) Old 08-12-2014
Quoted: 100 Post(s)
RYD SLO is offline
post #6 of (permalink) Old 08-13-2014
Quoted: 929 Post(s)
Most of the OBD-II adapters are just no-name clones and work the same. In my opinion, the biggest decisions to make when buying an OBD-II adapter are:
1. Size (some are VERY small, which is nice)
2. Color - just to blend into the interior, especially if you plan on leaving it connected most/all of the time. Some of the transparent blue adapters would just stick out like a sore thumb - especially the larger ones.
3. Power switch - some have a power switch that disables the adapter (or at least the bluetooth signal) - again, nice if you want to leave it connected all of the time - can just turn the power on/off when needed.
Otherwise, they're basically all the same...
I purchased this one myself, which I love:
It's $17, but it also includes the Pro version of Torque Pro. Not sure if it's a 'valid" version or not. I purchased the app anyway, just to get the app updates easily and to support the application author.
Also, some of the real cheap no-names adapters don't support the "Faster communications" setting in Torque - this setting allows the gauges to refresh more often. I'd try to stick with an adapter someone else recommends, just so that you KNOW it'll work properly with Torque (most will) and if it supports the faster communication settings, etc....
jtrosky is online now
post #7 of (permalink) Old 08-13-2014
DiGiacomo
DiGiacomo's Avatar
Quoted: Post(s)
Thanks jtrosky,
that is a good way to do it, buy a mated pair, eliminate arguments
i will leave it in place, so i like the on off feature also.......color matches black interior...
there seemed to be a little controversy over in the Torque forum
Forums — » Torque OBD ECU Scanner » Torque Discussion / Ideas » Clone adapters - Currently many that dont' work on CANBUSTorque
i'll report back, ......
post #8 of (permalink) Old 08-13-2014
Quoted: 929 Post(s)
That's kind of what I mean - there are some adapters out there that don't seem to work properly with Torque - by getting one that someone else already has and has already tested, you may save yourself some headaches.... Like you, I have a black interior and wanted to keep the OBD-II adapter connected at all times, which is why I went with the OBD-II adapter that did. It's black color and small size make it so you don't even know it's there.
post #9 of (permalink) Old 08-13-2014
DiGiacomo
DiGiacomo's Avatar
Quoted: Post(s)
I ended up getting the ..........
Vgate ELM327 Bluetooth Scan Tool OBD2 OBDII Scanner for TORQUE APP ANDROID
off of ebay because it said " would be shipped from the U.S.".........i'V waited for that slow boat in the past and some times it sinks...
i went to google download apps for the torque pro........google has a good rep for original apps......thought that would be my best choice.......
thanks again..............now i wait.......i hate that.....;-)
post #10 of (permalink) Old 08-13-2014
That Guy!!
worthirt's Avatar
Quoted: 36 Post(s)
I did that same thing for something else, ended up coming from China. Took about a month for it to get to me. It was a CONSULT cable for my Sentra.
1996 Caprice Classic
worthirt is offline
post #11 of (permalink) Old 08-13-2014
DiGiacomo
DiGiacomo's Avatar
Quoted: Post(s)
The seller gets some very bad feed back if that happens........and they don't like bad feedback
post #12 of (permalink) Old 08-13-2014
Quoted: 100 Post(s)
I got that same one from Amazon using prime. 2 day shipping FTW!
RYD SLO is offline
post #13 of (permalink) Old 08-13-2014
Quoted: 929 Post(s)
I must say - I did enjoy Amazon Prime when I used a free trial with it. Just can't see paying $100/year for that benefit! I know you also have access to stream videos, but I use Netflix for that (and i'm not interested in switching), so it's just not worth the cost to get free 2-day shipping to me... Besides, one of the 4 or 5 things I ordered didn't get delivered within 2 days anyway, so it kind of left a bad taste in my mouth. Free 2-day shipping - unless it's late! :-)
post #14 of (permalink) Old 08-13-2014
DiGiacomo
DiGiacomo's Avatar
Quoted: Post(s)
my son has prime and we were set up to order,but the 'prime ship' did not show up on the order, so we canceled, thinking it would be a 'slow boat ship'..
post #15 of (permalink) Old 08-13-2014
Quoted: 929 Post(s)
I don't think I've ever had any Amazon order come directly from China, like you see on Ebay often. Could just be a coincidence though... Does Amazon even have items that ship directly from China??
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 08-28-2018 08:20 AM
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 07-14-2018 07:30 PM
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 05-07-2018 10:01 PM
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 11-01-2017 11:30 AM
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 08-31-2017 07:40 PM
