-   PCM and Technical Tuning (https://www.impalaforums.com/pcm-and-technical-tuning/)
-   -   ecu reset (https://www.impalaforums.com/pcm-and-technical-tuning/331125-ecu-reset.html)
countryrunner 09-20-2012 03:50 PM
ecu reset
hey guys i just did some mods to the stock intake and i need to reset the ecu so the computer can re-learn with the new mods. i tried to disconnecting the battery for 15min and that did not work because the radio presets where still there. any suggestions?
463 09-20-2012 04:42 PM
When you pull the battery cables tape them together with the + to the -. Then turn the key to the run and turn on light switch. This pulls all the stored power out. So after 15 to 60 min turn off all the switches and reconect your cables. Then you have the computer reset.
impala2004supercharger 10-31-2013 05:18 PM
2004 impala ss ecu reset
463 is this what you do on a 2004 impala ss
463 11-01-2013 05:20 PM
If you would like to have a master computer reset then yes. The computer is reset to the factory setting and the will relearn as you drive. :ok3:
jimmyfaught78 10-26-2015 10:52 AM
is this procedure universal or year & model specific?
I ask , does this procedure work on a 2008 impala ss. And what's test procedure to diag if pcm/ecu are operating within perameter or need replacing? Thank you...
