Quotes and Words of Wisdom - Page 50 - Chevy Impala Forums
 44Likes
retiredpauly's Avatar
Quoted: 233 Post(s)
Tools and their descriptions
SKILLSAW: A portable cutting tool used to make boards too short.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh shit'. Will easily wind a tee shirt off your back.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
CHANNEL LOCKS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
HACK SAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for igniting various flammable objects in your shop and creating a fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. Very effective for digit removal!!
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut large pieces into smaller pieces that more easily fit into the trash after you cut on the inside of the line instead of the outside edge. Also excels at amputations.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PVC PIPE CUTTER: A tool used to make plastic pipe too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. Also very effective at fingernail removal.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door. Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. These can also be used to initiate a trip to the emergency room so a doctor can sew up the damage.
SOB TOOL: Any handy tool that you grab and throw across the garage while yelling 'SOB' at the top of your lungs. It is also, most often, the next tool that you will need.
retiredpauly is offline
Caprice Classic with Class
Old Bones's Avatar
Quoted: 76 Post(s)
tonyc712000 likes this.
Holly 0-83670 4 Barrel Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Sony F-50 dash-cam with GPS Antenna. Crazy Canuck behind the Wheel.
Old Bones is offline
Quoted: 233 Post(s)
tonyc712000 and Old Bones like this.
Forum Foto Fanatic
tonyc712000's Avatar
Quoted: 96 Post(s)
Name:	Smarty Pants.jpg
Old Bones and retiredpauly like this.
2012 Chevy Sonic LTZ--Given to Son
Current ride-
2012 Impala LT
tonyc712000 is offline
Quoted: 233 Post(s)
Buddy ! ! ! !
I have met/run into/dealt with, sooooooo many people that have gone through their entire lives like this.
I am a firm believer of removing the warning labels from EVERYTHING and just let natural selection run it's course.
Quoted: 233 Post(s)
Quoted: 233 Post(s)
You never appreciate what you've got till it's gone........
Toilet paper is a good example.
Old Bones's Avatar
Quoted: 76 Post(s)
Old Bones's Avatar
Quoted: 76 Post(s)
75 years ago June 6th , Lest We Forget
retiredpauly, sheila and kbz1960 like this.
Old Bones's Avatar
Quoted: 76 Post(s)
Old Bones's Avatar
Quoted: 76 Post(s)
Forum Foto Fanatic
Quoted: 96 Post(s)
Current ride-
2012 Impala LT
LinkBack to this Thread: https://www.impalaforums.com/off-topic-discussion/319306-quotes-and-words-of-wisdom.html
Untitled document This thread Refback 10-07-2014 12:20 PM
Untitled document This thread Refback 10-07-2014 12:18 PM
Tips in Choosing the Appropriate Lingerie which will Suit Your Body - Bodystocking, Heisse Dessous & Nuisette Sexy This thread Refback 10-07-2014 12:17 PM
Untitled document This thread Refback 10-07-2014 12:16 PM
Untitled document This thread Refback 10-07-2014 12:15 PM
Untitled document This thread Refback 10-07-2014 12:14 PM
Untitled document This thread Refback 10-07-2014 12:13 PM
Untitled document This thread Refback 10-07-2014 12:11 PM
Untitled document This thread Refback 10-07-2014 12:05 PM
Untitled document This thread Refback 10-07-2014 12:04 PM
Untitled document This thread Refback 10-07-2014 12:03 PM
Untitled document This thread Refback 10-07-2014 12:02 PM
Untitled document This thread Refback 10-07-2014 12:01 PM
Sexy Lingerie: Which Ones are Suitable for You? - Erotische Dessous, Lingerie erotique & Nuisette Sexy This thread Refback 10-07-2014 12:00 PM
Untitled document This thread Refback 10-07-2014 11:59 AM
Untitled document This thread Refback 10-07-2014 11:57 AM
Pin by Dan n Briana Blair on Funnies | Pinterest This thread Refback 10-05-2014 06:40 PM
Pin by Casey Jolly on Funny<3 | Pinterest This thread Refback 09-28-2014 05:16 AM
The Different Kinds of Granite Countertops and Kitchen Worktops - Corian Countertopslondon This thread Refback 09-09-2014 05:04 PM
Solid Surface Granite Countertops & Kitchen Worktops - Quartz Countertops This thread Refback 09-09-2014 05:03 PM
The Different Types of Granite Countertops and Kitchen Worktops - Marble Kitchen Worktops This thread Refback 09-09-2014 05:03 PM
Solid Surface Granite Countertops & Kitchen Worktops - Kitchen Worktops UK This thread Refback 09-09-2014 05:02 PM
Granite Countertops and Other Kitchen Worktops Options - Quartz Worktops London This thread Refback 09-09-2014 05:02 PM
Solid Surface Granite Countertops & Kitchen Worktops - Corian Colors London This thread Refback 09-09-2014 05:02 PM
Granite Countertops: One of the Very best Kitchen Worktops in the Market - Corian Countertopslondon This thread Refback 09-09-2014 05:01 PM
Solid Surface Granite Countertops & Kitchen Worktops - Granite Worktops UK This thread Refback 09-09-2014 05:01 PM
Granite Countertops: One of the Best Kitchen Worktops in the Market - Corian Countertop London This thread Refback 09-09-2014 05:00 PM
Granite Countertops and Other Kitchen Worktops: For an Elegant-Looking Kitchen - Kitchen Worktops London This thread Refback 09-09-2014 05:00 PM
Granite Countertops: One of the Very best Kitchen Worktops in the Market - Granite Countertops London This thread Refback 09-09-2014 05:00 PM
What You have to Learn about Granite Countertops and Other Kitchen Worktops - Solid Surface Worktops London This thread Refback 09-09-2014 04:59 PM
Granite Countertops and Other Kitchen Worktops: For an Elegant-Looking Kitchen - Granite Kitchen London This thread Refback 09-09-2014 04:58 PM
The Different Types of Granite Countertops and Kitchen Worktops - Quartz Worktops London This thread Refback 09-09-2014 04:58 PM
Granite Countertops and Other Kitchen Worktops: For an Elegant-Looking Kitchen - Granite Worktops UK This thread Refback 09-09-2014 04:38 PM
Solid Surface Granite Countertops & Kitchen Worktops - Kitchen Worktops UK This thread Refback 09-09-2014 04:27 PM
Information about Granite Countertops and Kitchen Worktops - Granite Kitchen London This thread Refback 09-09-2014 04:26 PM
What You have to Learn about Granite Countertops and Other Kitchen Worktops - Granite Countertops London This thread Refback 09-09-2014 04:26 PM
Granite Countertops: One of the Finest Kitchen Worktops in the Market - Marble Worktops London This thread Refback 09-09-2014 04:24 PM
The Different Kinds of Granite Countertops and Kitchen Worktops - Quartz Worktops London This thread Refback 09-09-2014 04:23 PM
The Different Types of Granite Countertops and Kitchen Worktops - Solid Surface Worktops London This thread Refback 09-09-2014 04:23 PM
Solid Surface Granite Countertops & Kitchen Worktops - Quartz Countertops This thread Refback 09-09-2014 04:22 PM
About Granite Countertops and Kitchen Worktops - Granite Kitchen London This thread Refback 09-09-2014 04:21 PM
What You Need to Find out about Granite Countertops and Other Kitchen Worktops - Granite Countertops London This thread Refback 09-09-2014 04:20 PM
Solid Surface Granite Countertops & Kitchen Worktops - Quartz Countertops This thread Refback 09-09-2014 04:19 PM
Granite Countertops and Other Kitchen Worktops Choices - Granite Worktops London This thread Refback 09-09-2014 04:18 PM
What You have to Learn about Granite Countertops and Other Kitchen Worktops - Granite Countertops London This thread Refback 09-09-2014 04:17 PM
Granite Countertops: One of the Greatest Kitchen Worktops in the Market - Quartz Countertops This thread Refback 09-09-2014 04:16 PM
Granite Countertops and Other Kitchen Worktops: For a Classy-looking Kitchen - Granite Kitchen London This thread Refback 09-09-2014 04:15 PM
Solid Surface Granite Countertops & Kitchen Worktops - Granite Worktops London This thread Refback 09-09-2014 04:14 PM
Granite Countertops and Other Kitchen Worktops Options - Quartz Kitchen Worktops This thread Refback 09-09-2014 04:14 PM
The way to Choose an Escort Girl in London This thread Refback 09-09-2014 02:51 PM
