Tools - Page 15 - Chevy Impala Forums
 367Likes
post #211 of (permalink) Old 07-14-2019 Thread Starter
Quoted: 382 Post(s)
<wrong thread; delete>
post #212 of (permalink) Old 07-14-2019 Thread Starter
Quoted: 382 Post(s)
reubenswinks's Avatar
Quoted: 94 Post(s)
Well prime day pushed me over the edge.
I bought the Launch X431 Pro Mini Bi-Directional code reader.
Looking forward to all the additional diagnostic tools I will have access to through this, as well as the features like key fob programing, or relearn procedures I used to have to go to the dealer for before.
I'll post back an update after using it for a while to see if it was worth the money.
reubenswinks is offline
The Following 2 Users Say Thank You to reubenswinks For This Useful Post:
kbz1960 (07-16-2019), retiredpauly (07-20-2019)
retiredpauly's Avatar
Quoted: 236 Post(s)
How much did they offer it for on Prime day ?
retiredpauly is offline
Quoted: 94 Post(s)
Got it for $629. I think it was 20% off...so about $60 lower than if you bought it today with that coupon. Wasnt a killer deal, but enough to make me pull the trigger.
So far I have used it to troubleshoot an evap code on my wifes suv. Found out the purge valve isn't working by commanding it to different percentages and seeing that the vacuum wasn't changing at all. Looked up the air bag code from my impala, and read the abs codes from my truck. I will be attempting to program a key for my wifes suv here shortly too. So far I love it. There is so much stuff that it does. I feel like I've barely scratched the surface.
The Following User Says Thank You to reubenswinks For This Useful Post:
retiredpauly (07-22-2019)
hatzie's Avatar
Quoted: 159 Post(s)
That could be the fuel tank pressure sensor as well.
Been there done that got the Tee shirt.
Sounds like it's a good diagnostic tool. Good to have known working options to the GM hardware and GDS software
2009 Impala SS
hatzie is online now
post #217 of (permalink) Old 08-03-2019 Thread Starter
Quoted: 382 Post(s)
10mm socket recovered !
Sometimes, those lost 10mm sockets turn up
hatzie, retiredpauly and jtrosky like this.
Quoted: 932 Post(s)
Had to go buy a Torx E-12 socket today (female Torx socket). I am installed an under-the-seat subwoofer in my Challenger and of course, they have to use these oddball bolts to secure the seat... At first I used a 12-point 3/8" socket, but I then wasn't paying enough attention and somewhat stripped the 2nd one - which is why I had to go buy the real thing - the E-12 socket. I was eventually about to get the somewhat-stripped bolt out with the E-12 socket. But what a PITA... Why can't they just use regular bolts???
Oh, at least I now have a female Torx socket that I'll probably never use for anything else every again. :-) Lesson learned - buy the right tool for the job instead of trying to use something that is "close". :-)
post #219 of (permalink) Old 08-03-2019 Thread Starter
Quoted: 382 Post(s)
I think there are a couple advantages. On the assembly line, some things are done one-handed, so the worker is holding a tool - eg, air wrench - which has a socket on it, with the fastener inside that. I think a torx-headed fastener may be easier to keep perched in the socket without falling out more readily than a normal hex bolt, which in turn allows the assembly worker to reach into some recessed, hard-to-reach spot and run the screw in without needing to have his other hand on the screw to keep it in position.
The other advantage is that, for its diameter, I think the torx head can take more torque. So the fastener's head can be a bit smaller making it easier to fit it into tight spots.
I think these may be the new trend. (Keep in mind, 100 years ago, somebody made the same comment about his first Philip's screw driver ) My 2 Cruzes have a bunch of female torx fasteners. So hang on to that E-12 - you're gonna need it again
BTW, my Father's Day / birthday trick worked - I got that 13-pc set of female torx sockets whose pic I had texted to my wife/kids
jtrosky likes this.
Quoted: 932 Post(s)
Damn it, Doug - there you go applying logic to things again!! :-) Of course, your explanations make complete sense... :-)
Funny story.... So I look everywhere on-line to try and find this female Torx socket, which I assumed was an E-10 since it had a "10" clearly stamped on the head. My local AutoZone didn't have any, Walmart didn't have any and Lowes didn't have any (at least according to their web sites). So I find one at an Advanced Auto about 25 minutes away. I get in my car, get to the store and couldn't find it. I asked the people that work there and it wasn't even in their system. So I say, OK - I'll just order it online for pick-up in "30 minutes" - I'll *make* them find it! I order it online from my phone while in the store and when I get the confirmation email, I realized that I was at *AutoZone* instead of the Advance Auto a half mile up the street that I was *supposed* to go to! <sigh> - don't I look like an idiot!!!
It gets even worse...
So I leave AutoZone and go a half mile up the street to Advance Auto, where I've now ordered it on-line for in-store pickup. They fine the E-10 socket and give it to me. As I'm walking to my car, I remembered that I brought the bolt with me, so I "test" fit it and sure enough, the socket (E-10) is too small. I go back into Advance Auto and the guy says "it's probably and E-14" - give me an E-14 and it fits, but as she's exachanging it in the computer, I realized that while it does fit, it's a little loose. So I ask to check an E-12 and sure enough - it fits perfectly. SO then the poor lady had to exchange it yet *again*!
Man - sure was a lot of work getting that little socket.
To make matter even worse, while looking for the "E-10" at the original Auto Zone, I found a 9-piece female Torx bit set for $22 (the single was $5). My cheap ass puts the set back to go get the $5 single bit at the right store.
Long story short - I should have just bought the damn 9 piece set at Auto Zone and called it a day!!!!!
Caprice Classic with Class
Old Bones's Avatar
Quoted: 81 Post(s)
Picked up this foot tire pump (Silme 20061A Big Foot Pump) for $20 good for 100psi.
I had a little 12 volt pump for the last decade but died , this little pump is well made
Holly 0-83670 4 Barrel Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Sony F-50 dash-cam with GPS Antenna. Crazy Canuck behind the Wheel.
Old Bones is offline
kbz1960's Avatar
Quoted: 26 Post(s)
WTF lol
kbz1960 is offline
Old Bones's Avatar
Quoted: 81 Post(s)
Dropped a plug socket once , it never hit the ground , never found it
post #224 of (permalink) Old 08-04-2019 Thread Starter
Quoted: 382 Post(s)
Originally Posted by kbz1960 View Post
WTF lol
To be clear - I stole that from Facebook. I assure you, I would never admit to having that happen to myself
hatzie, Old Bones and kbz1960 like this.
John Craker's Avatar
Does the box count?
It'd been ~10 years since I picked up my last box (new job, wanted to look snazy!).
And since... well... that's happened a FEW times over the ~40 years I've been twisting wrenches... my tools were scattered over about 6 roller cabs. It was annoying. And an excuse.
John Craker is offline
4pc Audio Installer Car Removal Open Tools Door Clip Kit Panel Radio Trim Dash RSS Bot Impala Diecast Toys Cars on eBay 0 09-21-2018 10:30 AM
Cabin Air Filter - Remove Cowl Clips Tools 2016LimtedLTZ Chevy Impala 8th Gen Discussion 12 06-05-2018 05:29 AM
6 Stepper Motors Instrument Cluster Gauge/Speedometer Repair kit GMx27 168 Tools RSS Bot Impala Diecast Toys Cars on eBay 0 11-14-2017 11:50 AM
6 Stepper Motors Instrument Cluster Gauge/Speedometer Repair kit GMx27 168 Tools RSS Bot Impala Diecast Toys Cars on eBay 0 11-10-2017 08:30 AM
4 x Car Removal Open Tools Door Clip Kit Panel Radio Trim Dash Audio Installer RSS Bot Impala Diecast Toys Cars on eBay 0 09-16-2017 10:00 PM
