Lowered 8th Gen Impalas - Page 2 - Chevy Impala Forums
Media Bucket Found some cool automotive-related pictures on the net? Want to share videos of your ride? Post Chevy Impala or other car-related pics and videos here!
post #16 of (permalink) Old 10-28-2014 Thread Starter
Eric91Z's Avatar
I want to get the ride height out of the air, little lower to the ground, but not slammed while still retaining good ride characteristics and better handling as it is still a daily driver, including Iowa winters! But I don't want the rear sitting way lower than the front. Trying to find best way to get front down so level or slightly lower even than the rear.
Eric
2016 Silverado LT 4x4
2014 Impala LTZ Limited
- Current Modifications:
- Trifecta, Addco rear sway/MOOG end links, Energy Suspension front sway bushings/MOOG end links, Elite Catch Can, Tinted windows, Dipped Bowties, Curt hitch, GMPP STB's/Don Rome brackets, GM Splash Guards, GM Exhaust Tips, WeatherTech DigiFit floor liners, Winter: Sport Edition P2 with Blizzak's
Eric91Z is offline
post #17 of (permalink) Old 10-28-2014
702•LTZ's Avatar
Lookin at about 240$ in bracketing for bags.
Iv read where someone took out the spring isolator or something from the front to drop it down a bit. Also read where someone installed just drop springs in the front. But the springs I got sat it level, untill i put the amp & subs that dropped about .25" then everything else dropped It another rough .25"
<a href=http://s1281.photobucket.com/user/702ltz/media/Mobile%20Uploads/20150112_165711_zpsah6xjvc_edit_1421167783579_zpsvuvufe2j.jpg.html target=_blank><img src=http://i1281.photobucket.com/albums/a518/702ltz/Mobile%20Uploads/20150112_165711_zpsah6xjvc_edit_1421167783579_zpsvuvufe2j.jpg border=0 alt= /></a>[/URL]
"I didn't really set a timeline for it to be done. I just wanted to make sure that when it was finally completed, it would meet my expectations."
702•LTZ is offline
post #18 of (permalink) Old 10-28-2014 Thread Starter
Eric91Z's Avatar
Yeah, I don't want to remove spring isolator and will be doing new anti pogo washers up front with new springs. I had thought about trying just the fronts as I already have a hitch on the rear and the front ride height - measured from center of wheel cap to inside edge at top of wheel well opening - is 1.5" higher in front than rear at this time. It is more pronounced or bigger difference when I have a full tank of gas and the bike rack with backs loaded on the hitch on back. But that's isn't all that often. Definitely want to try and get level or slight front rack ride height and the '97-'03 GP springs seems to be the suggested route. I know I will have slight bit more drop in rear due to the hitch, but can't be perfect all the time.
Here is Will's right up on the springs:
:: Overkill Motorsports ::
Eric
Eric91Z is offline
post #19 of (permalink) Old 10-28-2014
Quoted: 930 Post(s)
I do agree that the rear end "sags" a little on the 2012+ - especially when you have a full tank of gas, like you said. I do wich the rear end was a little higher. I guess you could always go the super-cheap route and put some spring lifters in the rear! Probably not a very good way to handle it though!!! :-) I used those once with an old Buick Regal when I was younger. Seemed to work OK... What are the drawbacks of spring-lifters?
post #20 of (permalink) Old 10-28-2014 Thread Starter
Eric91Z's Avatar
I am not looking to raise the rear, but rather lower the front. I don't think the rear end right height, as my car sits right now is too bad, but the front is WAY to high for my liking. And still not sure why, but the '12-'14 Limited sit much higher in front than the pre-'12 models. Front end needs to come down. And if I can do that in such a way as to improve handling, without killing ride quality, then that is the route I want to go.
Eric
Eric91Z is offline
post #21 of (permalink) Old 10-29-2014
tomthebomb's Avatar
Yeahhh
00 LS 3.8L, 200k mile club, HID's, led tail light assemblies, led tag lights led interior lights, 2 inch drop, 20% tint, black roof vinyl, ss spoiler, and so on and so forth...
tomthebomb is offline
post #22 of (permalink) Old 06-29-2015
def2000's Avatar
2012LTZ Oem everything suspension wise, except the (SSC) Canuk Motorsports drop springs
I hope these photos helps. The photo with the letters & numbers taped to the side, the whole car is empty.
first I start off with a photo that shows what resides in my trunk ((sadly)not clearly visible 2 12"s)
Do you know if these will work with a 2013 LTZ? Thanks
def2000 is offline
post #23 of (permalink) Old 06-29-2015
def2000's Avatar
Does anybody know the pros and cons of just lowering the front without lowering the back? Also looking for springs for 2013 LTZ if anyone can help please. Thanks
def2000 is offline
post #24 of (permalink) Old 06-29-2015
702•LTZ's Avatar
A '12 & '13 is identical. There should be no problems, 2 or 4 springs.
702•LTZ is offline
The Following User Says Thank You to 702•LTZ For This Useful Post:
def2000 (06-29-2015)
post #25 of (permalink) Old 06-29-2015
def2000's Avatar
Do you know the exact model number for the springs you ordered? I looked on the canuck website but only see springs for up to 2011. Your help is greatly appreciated. Thanks
def2000 is offline
post #26 of (permalink) Old 06-30-2015 Thread Starter
Eric91Z's Avatar
From my research, anything listed for a later W-Body will fit the '12-'14 Limited models. And most research still points to the Grand Prix '97-'03 springs as the right ride height and spring rate for any of the later model W-Bodies.
I have checked with Will (Overkill) who was integral in getting those springs developed and he has confirmed that as well.
On the Canuk Motorsports website that is the following: 2452.41100 - $167.95
Other options:
- ZZP: Spring/Strut Combo: completely assembled spring/strut combo ready to install with the SSC/Canuck '97-'03 Springs and your choice of KYB struts: $849.99 Drop in Strut/Lowering Spring Combo - Suspension & Brakes
If you are looking at springs only, the Canuck price seems to be the best out there. I like the idea of a complete plug-n-play setup with new hardware then I can just unbolt a few nuts, remove old setup, and reverse to install the new stuff. I am kind of lazy like that, but then have upgraded struts to go with the new springs.
And of course, if you lower, don't forget your new, lower dog bones to go with. ZZP and W-Body store both carry them for like $25. Seems to be good, safe investment.
Eric
Eric91Z is offline
The Following User Says Thank You to Eric91Z For This Useful Post:
def2000 (06-30-2015)
post #27 of (permalink) Old 06-30-2015
def2000's Avatar
I am just looking to lower the front end about 1.7 inches. So can I purchase any lowering springs that are for the 97-03 grand prix or are the canucks the only perfect fit? I appreciate all of the help. Thanks
def2000 is offline
post #28 of (permalink) Old 07-01-2015
DLW
DLW's Avatar
08 Impala LS with Intense Racing Coilovers and about 200lbs in the trunk
Current mods:
Pioneer AVH-X5800BHS
6.5" Image Dynamics CTX65cs (front stage)
American Bass XFL12s in a 4ft^3 ported box ~33hz
Rockford Fosgate T400-2 2 channel(speaker amp)
Sundown SCV2000D (sub amp)
Die Hard Platinum G34 (front batt)
XS Power XP2500 (rear batt)
2 runs of 1/0 Knukonceptz wire
Big 3 done in 1/0 knukonceptz
5% tint in the rear/20% tint up front
20" Velocity Wheels with 245/35/20 tires
Black Housing Headlights
DLW is offline
post #29 of (permalink) Old 07-01-2015
Quoted: 930 Post(s)
For the 2012 and 2013 owners out there, I wonder if we could use these as a cheap way to lower the front end a little:
In my case, I really don't want my car to look "lowered", but I would like to get rid of some of the gap in the front end... I already have rubber coil-spring spring boosters in the rear, which at least fixed the "sagging" look, but if I could lower the front end about 1", then the stance would look perfect...
post #30 of (permalink) Old 01-06-2016
carlos64030's Avatar
Quoted: 17 Post(s)
That looks damn near perfect!
carlos64030 is offline
The Following User Says Thank You to carlos64030 For This Useful Post:
Dave_N (01-08-2016)
'00-'01 7th Gen Wheels on '09 8th Gen Rowner Wheels and Tires 4 05-20-2019 07:36 PM
8th gen turn signal/dimmer switch replacement kingnutin DIY How To's & Write Up's 18 10-26-2018 10:41 AM
8th Gen vs 9th Gen Performance 2014LTDLTZ Chevy Impala 8th Gen Discussion 11 08-20-2018 05:20 PM
Can KYB AGX adjustable struts/shocks be used in 8th gen. impalas? Sealclubber 8th Gen Suspension 26 07-02-2018 04:44 PM
WTB: 8th Gen OEM Aux Trans Cooler 2014LTDLTZ Private Wanted Classifieds 1 09-24-2017 06:05 AM
