2000 Chevy Impala LS, HELP NEEDED ASAP. - Chevy Impala Forums
post #1 of (permalink) Old 10-29-2013 Thread Starter
MonteSS2013's Avatar
2000 Chevy Impala LS, 3.4L
I hope i am placing this in the right location. i am new.
I have searched all over the internet for 2 days now. checked with our local Chevy dealer, checked parts stores and salvage yards. i am at a complete dead end. It is not my car, i am attempting to fix it for someone, but i have never run into this problem before.
Anyway, what happened was the belt on the car was bad and decided to shred, creating a V-Belt with a whip. (lol) anyway, when it did that it ripped the wires to the main engine wiring harness, located above the water pump. instantly killing all power to the engine/trans
I am attempting to bypass the connector and just wire the wires back together, considering the wiring harness (comes as a whole, and is $947.46, discontinued part and not installed, and id have to go to another state to pick one up from the nearest salvage yard)
I re-wired the purple, Yellow/black and one other matching one. (don't remember color) however, i have 2 greens, 2 green/white, 5 pink wires, and a brown one and another pink one that does not have a mate in the wiring harness. It WILL run now, but not properly. I am looking for tips to get it right, or what all those wires actually go too! I need to get this car fixed asap, because i am now over my dead line. and it does not run well enough to be driven long distances.
I have included some pictures of the wires/harness i am referring too. and if anyone knows the "technical" name for it, please let me know. Thank you!!!!!!!!
ID:	32633   Click image for larger version
ID:	32641   Click image for larger version
MonteSS2013 is offline
post #2 of (permalink) Old 10-30-2013
alaska_AV's Avatar
if it was a 3800 id sell you a full engine harness cheep, but I don't have one for the 3400
alaska_AV is offline
post #3 of (permalink) Old 10-30-2013
auntjemima's Avatar
Well youre correct on your name, it is the engine harness. Honestly you would need to grab a hanes manual and look at the wiring schematics in it. I am getting ready for work but I can have a look later tonight.. I know you have a deadline, but things come up, so let the customer know that their lack of maintenance destroyed a pretty important part to the vehicle and you need more time.
auntjemima is offline
The Following User Says Thank You to auntjemima For This Useful Post:
MonteSS2013 (10-31-2013)
post #4 of (permalink) Old 10-30-2013 Thread Starter
Yes, the entire harness would be 50 dollars, and probably 50 dollars in gas for my Monte Carlo to go pick it up. I told her we could do that. but she wanted the cheapest route (10 Dollars for parts), which was rewiring it. since she said she does not plan on ever having the engine out. I also told her that i COULD do it, but it may take longer depending what "issues" i run into (since its multiple same colored wires, and I never let a belt break and cause that, and no other cars I've ever worked on was close to that, I've replaced many belts but never a broken one, tbh) but she wanted it completed by today (10/30/13) but its not happening and i warned her it might not happen. and we had a nice like 45 minute chat about checking & replacing belts, changing oil, and other maintenance lol. and what happens if you DO NOT do it.
I've got a 92 Chevy k1500, driven HARD, Take it literally ANYWHERE, 202K, well maintained and NEVER Skips a beat, Runs & Drives like it just came off the showroom back in 92.
I would also really appreciate it if you could take a look for me, when you get a chance. I planned on digging out my Haynes & Chiltons manuals, HOPEFULLY i have one for the Luminas/Impalas/Monte Carlos.
I will keep you all posted about the progress! Thanks again!!
My buddy needed one of them about a month ago. he had a short off of a lose wire onto the engine, melted about 1/3 of the engine harness. but our local salvage yard had one for 25 bucks. I do appreciate you taking your time to reply to my dilemma, Thank You also.
post #5 of (permalink) Old 10-30-2013
auntjemima's Avatar
I found my book but its all water damaged on the 3.4 and up pages wrt engine wiring. of course.
post #6 of (permalink) Old 10-31-2013 Thread Starter
Well, In Case, anyone ever runs into this problem, the cause was the serpentine belt breaking and where Chevy decided to locate that harness!
I've include a wiring diagram that will help you figure it out. only a $10 repair and really easy with the diagram i am posting!
ID:	32665   Click image for larger version
ID:	32673   Click image for larger version
The Following 2 Users Say Thank You to MonteSS2013 For This Useful Post:
missliz0204 (01-11-2015), User Nameless (05-14-2014)
post #7 of (permalink) Old 10-31-2013
auntjemima's Avatar
Thanks for the update and diagram! I will definitely be saving it
post #8 of (permalink) Old 11-01-2013 Thread Starter
Not a problem, figured if someone else ran into this problem, they may come across this forum. and help another person out. Its straight from GM, and made it a breeze. Sorry i didn't reply sooner, i got caught up repairing a Dodge 3500 Cummins.
post #9 of (permalink) Old 05-14-2014
User Nameless's Avatar
Where did you source these diagrams at?
User Nameless is offline
post #10 of (permalink) Old 05-15-2014
g25racer's Avatar
Look at the bottom I each page the diagrams are on. Lol
Can prob find these diagrams on ebsco as well
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #11 of (permalink) Old 05-25-2014
I did look. The reason I asked is because they appear to be scanned prints, not web based images.
post #12 of (permalink) Old 05-25-2014
g25racer's Avatar
Head out to a local junkyard and pull the harness if you need one. I can't imagine it being pricey at all.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #13 of (permalink) Old 01-11-2015
missliz0204's Avatar
00 Impala 3.8l engin rather than the 3.4l same broken harness connection/plug though
Just curious if I could also use the wire diagrams posted to rewire my harness? Mine broke while changing the battery... I have a 2000 impala with the 3.8 not the 3.4, so guess im just curious if the wiring will be the same... Thanks to anyone willing to help. Im new here so I do hope ive posted correctly!!
missliz0204 is offline
post #14 of (permalink) Old 01-11-2015
g25racer's Avatar
I would suggest using the proper diagram. Use this guide here to gain access to Ebsco
https://www.impalaforums.com/resource...r-manuals.html
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
LinkBack to this Thread: https://www.impalaforums.com/mechanical-and-electrical-problems/423633-2000-chevy-impala-ls-help-needed-asap.html
2000 Chevrolet Impala Wiring Diagram - Wiring Diagram This thread Refback 10-10-2017 06:12 PM
Engine Air Filter 2012 2013 CHEVY IMPALA LS LT LTZ 2014 2015 2016 IMPALA LIMITED RSS Bot Impala Diecast Toys Cars on eBay 0 03-07-2018 09:20 AM
2003 Chevy Impala LS V6 3.8L Excellent Condition $2,650 Impala2003! Private For Sale Classifieds 0 11-15-2017 09:50 AM
