2008 Impala passenger dash clicking - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 12-06-2010
GFM
GFM's Avatar
No, the noise you are hearing are from the servo motor that control the vent from inside to outside air. I had two of the motors go bad, one as I mention and the other was for the passenger side temperture control vent. The GM part # 15844096 (made in China) GM sells them for app. $40-$50. These two were fairly easy to replace, I replaced both motors in about an hour. You will need a 1/4" rachet driver and 5.5mm socket. The easiest way I found to get to these two motors, is by removing all items from glovebox and let the gloovebox open down to the floor. You will have to help it pass the stops. You should be able to see both servo motors from the glovebox opening. I would first verify that you are removing the correct servo motor by unpluging the power connector first and trying it to make sure the noise stops. I hope this helps.
GFM is offline
post #17 of (permalink) Old 05-14-2011
deltatodd1's Avatar
This good info to know. But, has anyone thought that maybe there is a problem with the Remote start telling the BCM to turn this on? Mine starts clicking when I open my door when the car is not running. I would think after replacing parts and it happens again to look into the Remote/BCM potential.
deltatodd1 is offline
post #18 of (permalink) Old 05-16-2011
GFM
GFM's Avatar
Vent door chatter
After replacing the two servo motors, I opened the gear cover on both servo motors and found both had gears with broken off teeth which cause the vent to chatter. My chatter vent doors issue was resolved by replacing the two defective servo motors.
GFM is offline
post #19 of (permalink) Old 07-02-2011
ThePeter's Avatar
I registered because of this very problem on my 2009 Impala SS. My clicking seems to be isolated to just the driver side vents. Is that accessible from the glove box as well?
ThePeter is offline
post #20 of (permalink) Old 07-04-2011
GFM
GFM's Avatar
Driver side vent location
I only had to replaced the inside/outside vent and passenger temp. control servos so far and they were accessible from the glove box. I'm not sure where the driver vent control is located, Sorry!
GFM is offline
post #21 of (permalink) Old 09-19-2011
ab2
ab2's Avatar
Help. Ac making knocking noise
I have a similar problem. I just bought a 2007 impala lt with the 3.5 L v6. There is no problem with the ac when its on but when I turn it off it makes a knocking noise from the passanger side for about 30 sec then stops. It ony does it after turning off the ac or vehicle. I was looking this up but saw a couple different answers. Can any one tell me what this could be and explain to me how I can fix it? Sorry for asking again if already answered but im still having trouble with this any help would be greatly appreciated.
ab2 is offline
post #22 of (permalink) Old 09-26-2011
ThePeter's Avatar
Mine just started doing that as well. I just had the drivers side servo replaced with the same exact problem, except it would additionally grind for awhile after I turned the car on.
When I brought it to the dealership, they said the servo was getting stuck in the on position, which actually drained and killed my old battery.
Previously, it was the blend doors, but I think the problem now is whatever actuator switches from windshield to passenger vents.
ThePeter is offline
post #23 of (permalink) Old 09-26-2011
Guest's Avatar
Quoted: Post(s)
Originally Posted by kingnutin View Post
You have a 100k warranty
yes but thats the powertrain warranty......the 3yr/36,000 mile bumper to bumper warranty would cover that....but obviously hes over it
post #24 of (permalink) Old 09-26-2011
GFM
GFM's Avatar
ab2, I had this problem twice now. I will paste my previous answer to this question below:
No, the noise you are hearing are from the servo motor that control the vent from inside to outside air. I had two of the motors go bad, one as I mention and the other was for the passenger side temperture control vent. The GM part # 15844096 (made in China) GM sells them for app. $40-$50. These two were fairly easy to replace, I replaced both motors in about an hour. You will need a 1/4" rachet driver and 5.5mm socket. The easiest way I found to get to these two motors, is by removing all items from glovebox and let the gloovebox open down to the floor. You will have to help it pass the stops. You should be able to see both servo motors from the glovebox opening. I would first verify that you are removing the correct servo motor by unpluging the power connector to the servo first and trying it to make sure the noise stops. I hope this helps. By the way the plastic gears on the servo motor break off causing the servo to chatter, causing the knocking noise.
GFM is offline
post #25 of (permalink) Old 09-27-2011
Quoted: 10 Post(s)
Was this fixed once under warranty? I would be happy to look into this for you as well with more information including your VIN. Please feel free to contact me privately. Thank you in advance.
Tricia, GM Customer Service.
ChevroletCustomerService is offline
post #26 of (permalink) Old 10-03-2011
ThePeter's Avatar
Both times it has been fixed under warranty, fortunately. Each servo motor went bad (first the driver's side, then the passenger's side)
ThePeter is offline
post #27 of (permalink) Old 10-10-2011
impcor's Avatar
Dorman has it
I have the P/S problem now.Found several Dorman with same number that should fit on Ebay.The part # is 604-108.
impcor is offline
post #28 of (permalink) Old 06-13-2014
Angelo
Angelo's Avatar
Quoted: Post(s)
Question clacking noise under dash 2006 impala
I removed one actuator and dis-connected the connector to the other actuator and I still get a loud clacking noise. How is this possible ?? Is there something else other than the fresh air and re circulating actuators that is responsible ?? Do the temp controls (dual zone) have
solenoids or something to make a clacking noise ??
post #29 of (permalink) Old 06-20-2014
mattpark's Avatar
had the same problem with 2 of the actuators now having that problem with the third. 07 ls 3500 engine. problem is i don't know where the one for temp control is.
mattpark is offline
post #30 of (permalink) Old 09-11-2014
Mazuti's Avatar
Chattering from inside the dash area with no key and car sitting with no doors open, no engine running. Is there a relay that is receiving power from battery and trying to function? Sure sounds like it. Replace inside and outside air circulators already due to cheaply built plastic gear teeth. I have owened several Camaros and other Chevrolets and they ALL lack quality control and are usually electrical nightmares with improper routed wiring.
Mazuti is offline
LinkBack to this Thread: https://www.impalaforums.com/mechanical-and-electrical-problems/255177-2008-impala-passenger-dash-clicking.html
clicking | Press Any Key This thread Refback 09-23-2015 02:44 PM
How to remove glove box 2008 chevy impala - 1Q5A This thread Refback 12-09-2014 12:00 PM
How to remove glove box 2008 chevy impala - by Leyla G.(25) This thread Refback 10-11-2014 11:54 AM
Chevrolet Impala Clicking Noise - Carmagnify This thread Refback 06-29-2012 07:37 AM
Chevrolet Impala Clicking Sound - Carmagnify This thread Refback 06-12-2012 06:01 PM
TWW - Clicking in my dash when I start my car (video) This thread Refback 02-18-2012 05:40 AM
TWW - Clicking in my dash when I start my car (video) This thread Refback 07-02-2011 09:55 AM
Untitled document This thread Refback 03-25-2011 09:50 PM
2008 Impala SS changing spark plug difficulties impalaguyinflorida Chevy Impala 8th Gen Discussion 7 03-25-2019 09:19 AM
2008 Chevy Impala Passenger Side Headlight RSS Bot Impala Diecast Toys Cars on eBay 0 08-15-2017 07:10 PM
Details for the 2008 MY Impala (LS, LT, LTZ, SS) TeeRev Chevy Impala 8th Gen Discussion 1 08-14-2017 10:12 AM
2010 Chevy Impala LT/Loud clicking noise Jimarie Chevy Impala 8th Gen Discussion 1 07-16-2017 02:07 PM
2008 CHEVROLET IMPALA with Only 15,201 Miles. Grandma's Car. Must Sell JoyfulSoul Private For Sale Classifieds 3 02-11-2012 01:28 PM
