AC works great but heat does nothing - Chevy Impala Forums
 3Likes
  • 1 Post By sheila
  • 1 Post By plano-doug
  • 1 Post By Jefflb
post #1 of (permalink) Old 10-05-2019 Thread Starter
Jefflb's Avatar
I have a 2011 Chevrolet Impala LT 3.5L MFI FFV OHV 6cyl
My AC works great, but I turned the heat on yesterday morning and it only blew cold air. In the evening I turned the AC back on, and again, it worked great. This morning, no heat again. All the fluids are good. Any thoughts. Thanks!
Jefflb is offline
post #2 of (permalink) Old 10-05-2019
Quoted: 190 Post(s)
Sounds like a failed temp blend door actuator. Any clicking/thumping behind the dash?
12 lt likes this.
The Following 2 Users Say Thank You to sheila For This Useful Post:
Jefflb (10-07-2019)
post #3 of (permalink) Old 10-06-2019 Thread Starter
Jefflb's Avatar
No sounds from behind the dash at all.
Jefflb is offline
post #4 of (permalink) Old 10-06-2019
Quoted: 378 Post(s)
Your car has dual heat controls? Have you checked it on the passenger side?
With dual controls, there will be two hot/cold blend door actuators, one for each side. I'd be surprised that both have failed. But it's possible.
My first step would be to try to verify they are working correctly. Maybe have to get under the dash and feel or listen to them turning when the hot/cold knob is moved.
After that, I would get under the hood and verify the heater hoses are properly connected to the firewall. That is, if it's not the hot/cold blend doors, the next step is to make sure there is coolant flow thru the heater core.
12 lt likes this.
Jefflb (10-07-2019)
post #5 of (permalink) Old 10-07-2019 Thread Starter
Jefflb's Avatar
Thanks to both of you. You guys were right. I have heat on the passenger side but the cold blowing out of the drivers side made it to cold to notice the difference until I held my hands over each side with vents open or closed.
Jefflb is offline
post #6 of (permalink) Old 10-07-2019
Quoted: 378 Post(s)
So you probably just need a new driver's side actuator.
Here are my notes on this:
actuator for blend doors and recirc:
GM# 15844096
ACDelco# 15-75317 (aka 1575317)
>>>NOTE: 15844096 replaced by 22754988 <<<
Pricing will be in the ~25-35 dollar range.
You can access it by removing the trim over the driver's legs. The spec calls for a 5.5mm socket, but 7/32" works pretty well
Jefflb (10-10-2019)
post #7 of (permalink) Old 10-07-2019
Quoted: 190 Post(s)
Iirc, member Klowny has a how-to video on the bda's on here and/or u-tube.
Jefflb (10-10-2019)
