09 Intermittent Transmission Harshness - Chevy Impala Forums
 6Likes
  • 2 Post By Bill58
  • 1 Post By sheila
  • 1 Post By rjayl
  • 2 Post By ranger
post #1 of (permalink) Old 06-30-2019 Thread Starter
ranger's Avatar
Background:
The vehicle in question is a stock 2009 Chevrolet Impala with the 3.5L engine and 4T65E transaxle. It has around 125,000 miles on it. There is no check engine light, and I havenít been able to pull any trouble codes with a basic scan tool. The transmission fluid was changed by the dealer about a year and a half ago at 115,000 miles. They did not change the transmission filter or pull the pan. The fluid looked to be in okay condition before it was changed. The transmission fluid, as it should, looks new and doesnít seem to be frothy or otherwise full of bubbles. It looks to me like it might be slightly overfilled. The problem has been occurring for at least a year; Iím not sure if it coincides with the fluid change.
Complaint:
Occasionally, when I come to a complete stop, then go to take off again, the engine will rev up to 2000ish rpm but the car moves forward with very little power as if the transmission is slipping, but then it will lurch forward, sometimes quite harshly depending on how much gas youíre giving it, then resume normal operation. Itís as if it was taking off from a stop in a high gear then downshifting suddenly to first, but I donít know if thatís what really is going on. This happens maybe once or twice per hour of driving. Sometimes more, sometimes less. It seems like it tends to happen when the engine/transmission are hotter, but thatís not the case 100% of the time.
Aside from this issue, the engine runs well and the transmission upshifts/downshifts fine and the torque converter seems to lock up and hold fine. When itís not having trouble, it will launch off the line with plenty of power if you want it to; the transmission does not feel weak.
Iíve read a bit about some problematic EPC solenoids in these transmissions, but I donít have any way to do further diagnostics on this transmission.
Question:
With that all in mind, does this issue sound familiar? Ultimately, Iíll likely end up bringing it to a transmission shop, but Iíd like to be as informed as possible before doing so. My experience with other vehicles is that any transmission shop just wants to do a full $3000 rebuild, but I refuse to believe that is necessary here. It seems like an electrical/sensor/computer issue or a pressure control problem. Unfortunately, it seems that most of the relevant sensors and solenoids are not in the pan and are difficult to access. The intermittent nature of the issue will prove challenging for most transmission shops as well. Any information would be greatly appreciated.
ranger is offline
post #2 of (permalink) Old 06-30-2019
Bill58's Avatar
Quoted: 48 Post(s)
The "flush" will stir up the particles in the trans. Some of the particles are ferrous material which will stick to the magnetic part of the solenoids so they don't operate correctly. Changing the solenoids probably will fix the problem but is labor intensive.
Dropping the pan and changing the filter usually works better.
Bill58 is offline
post #3 of (permalink) Old 06-30-2019
Quoted: 171 Post(s)
^+1 with Bill. Has the atf filter ever been changed in 125k mi.? I'd recommend a pan drop fluid/filter change ea. 30k mi.
Bill58 likes this.
post #4 of (permalink) Old 07-01-2019 Thread Starter
ranger's Avatar
To my knowledge, the AT filter has never been changed. When I brought it to the dealer I discussed this with my service writer and he said that it was Chevrolet's policy to only do fluid exchanges and to not open the pan or replace the filter unless specifically requested. Something about not wanting to introduce contaminants into the transmission unnecessarily. Not sure if I believe it, but that's what he said.
As far as the "flush" goes, I'm aware of potential trouble they can cause, particularly for neglected transmissions which have dirty fluid or where the friction material suspended in the fluid is all that's keeping it going. This was a concern of mine so I was sure to confirm with the service writer that they were doing only a "low pressure" fluid exchange, with no special cleaners or chemicals. As it was explained to me, the fluid is slowly pumped out through the filter and out the tranny cooler line while new fluid is added through the other cooler line. The fluid was red prior to the flush, not burnt or dirty, so that factored into my decision to go ahead with the fluid exchange as well.
Do you think it would be useful at this point for me to pull the pan and change the filter? I thought I also read something at some point about a new style of pan magnet that GM called for. If nothing else, I'd be curious to see what kind of shape the filter is in and what there is on the magnet or on the bottom of the pan.
ranger is offline
post #5 of (permalink) Old 07-03-2019
rjayl's Avatar
Quoted: 28 Post(s)
Short answer is yes.
My '08 did the same thing. I replaced the oil pan with the
pan. It has a drain plug so you can change the oil more often. I change it out every-other motor oil change.
I also added the 2nd magnet as recommended by GM along with replacing the filter. It goes without saying, use full synthetic ATF.
I initially drove the vehicle about 100 miles and drained the fluid and re-filled. So-far so good.
If you do this its also a good time to install a shift kit; while your there, why not.
rjayl is offline
post #6 of (permalink) Old 07-04-2019 Thread Starter
ranger's Avatar
I've been looking at that pan for awhile, but I have a question. Does the drain plug interfere with the placement of the new donut-shaped magnet that is to be installed? Or is the inner diameter of the magnet such that it fits around the bung for the drain plug? As far as shift kits go, the Transgo 4T65E kit says it works for 1997-2008. Is this accurate?
TransGo 4T65E: SK 4T65E
ranger is offline
post #7 of (permalink) Old 07-05-2019
rjayl's Avatar
Quoted: 28 Post(s)
The 2nd magnet has to be installed next to the drain hole. Unfortunately it doesnt fit around it. The 4T65E kit is the one I used, but mine is an '08. You might want to check with TransGo to make sure it works in the '09. I would think it would, but better safe than sorry.
rjayl is offline
post #8 of (permalink) Old 07-10-2019 Thread Starter
ranger's Avatar
I ordered the Dorman pan and the AC Delco pan magents & filter as well as 8 qts of Dexron VI. I am probably going to hold off on a shift kit at this point even though the timing would be convenient since I'll have the pan off. This way, I'm not changing too many variables at once, giving me a better idea of what solves (or doesn't solve) the problem. It'll be some time before I get the new parts on but I'll update with anything interesting I see once I get the pan opened up.
Thanks everyone for all the help.
ranger is offline
