Wipers issue - Chevy Impala Forums
  • 1 Post By plano-doug
post #1 of (permalink) Old 05-21-2019 Thread Starter
Christopher Perez's Avatar
Wipers issue
Any know what could be the issue with my 2001 Impala wipers. The wipers park up while turned on intermittent. When I turn them off, the don’t not park all the way down, and the transmission does not make contact with the metal stub. Thanks in advance for any advice. Here is a video: https://youtu.be/rcx2u_zka5k
Christopher Perez is offline
post #2 of (permalink) Old 05-22-2019
Quoted: 338 Post(s)
Originally Posted by Christopher Perez View Post
Any know what could be the issue with my 2001 Impala wipers. The wipers park up while turned on intermittent. When I turn them off, the donít not park all the way down, and the transmission does not make contact with the metal stub. Thanks in advance for any advice. Here is a video: https://youtu.be/rcx2u_zka5k
I think your problem is that little tab I circled in the pic from your video. It's supposed to catch the bottom side of the rotating section to cause it to "shift" into park.
Try raising it up if possible. It may need to be replaced (if that's possible). But it appears that corrosion has worn it down.
In the 2nd pic, you can see how the tab engages the transmission when it's turning counter-clockwise. That must happen in order for the wipers to park.
plano-doug is online now
Found The Loose Gas Cap Issue Carbide Chevy Impala 8th Gen Discussion 18 03-07-2019 07:08 AM
Multifunction switch; cut strap around steering wheel base; wipers question impala34004 Chevy Impala 7th Gen Discussion 0 06-07-2018 06:15 AM
Weird issue with door locks - ignition? RYD SLO Chevy Impala 7th Gen Discussion 0 05-15-2018 12:31 PM
2003 Impala Ls startup issue juskii Chevy Impala 8th Gen Discussion 0 08-24-2017 05:56 PM
