Rapid turn signal, works when struck on brake lgt - Chevy Impala Forums
 9Likes
  • 4 Post By plano-doug
  • 2 Post By plano-doug
  • 1 Post By kbz1960
  • 2 Post By 12 lt
Joe Needs Advice's Avatar
Hello. The right turn signal on my 2008 Chevy Impala 3.5L LT began
blinking very rapidly, and I noticed my rear right brake light was out. After examining the bulbs and wiring, nothing seemed amiss. In
frustration I thumped the car near the brake light with the palm of my hand and it started working. It now reverts to the quick blinking, I assume when the ride is rough and whatever the problem is shakes loose, and again, if I thump it over the left brake light, it corrects itself... Any ideas? Thanks in advance for your help!
Joe Needs Advice is offline
Quoted: 223 Post(s)
Possible bad multiswitch. Seen them do some crazy and erratic stuff on some vehicles with blinkers and wipers.
Quoted: 329 Post(s)
I'm getting confused - which bulb is intermittent?
If a thump fixes it, that is indeed some sort of a bad connection. Could be a loose wire, a failing bulb or a bad socket. We haven't seen bad tail light sockets (but we've seen a few bad headlight sockets). I'm guessing you have a bad bulb. The filaments can break on one end, and intermittently connect, such as after a thump. I replaced one within the past two weeks doing just that. When I pulled it out to inspect, I could see the loose filament.
Usually, they will eventually break off and fail completely.
I'd try a new bulb and see if the problem stays gone or comes back. That's the easiest/cheapest thing to do.
sheila, 1954 Chevy, 12 lt and 1 others like this.
Quoted: 329 Post(s)
I agree, the mulitswitch and also the emergency flasher switch can cause some weird behavior, but the result of thumping the light makes me focus there first.
sheila and 12 lt like this.
kbz1960's Avatar
Quoted: 16 Post(s)
My Mercury I had would flash rapidly if a bulb was out. Replace burnt bulb and back to normal.
I'd try the bulb first also.
kbz1960 is online now
Quoted: 223 Post(s)
Read that and somehow missed retaining the thumping part, have our month old granddaughter here, focus issues. lol.
Agree that with the thumping or wiggling the bulbs it would be in the bulb/bulb holder/wiring at the socket.
plano-doug and 1954 Chevy like this.
Quoted: 144 Post(s)
^+1. Sure sounds like intermittent filament contact.
Car Motor Trunk Tail Flow LED Strip Light Reverse Brake Turn Signal Running Lamp RSS Bot Impala Diecast Toys Cars on eBay 0 03-29-2019 04:41 AM
2000 Impala LS turn signal problem dandyd Chevy Impala 7th Gen Discussion 1 10-15-2018 05:53 PM
Turn signal woes daytonboi Chevy Impala 8th Gen Discussion 3 03-30-2018 07:34 AM
60" Red/white Tailgate LED Strip Light Bar Truck Reverse Brake Turn Signal Tail RSS Bot Impala Diecast Toys Cars on eBay 0 08-16-2017 12:50 PM
60" Red/white Tailgate LED Strip Light Bar Truck Reverse Brake Turn Signal Tail RSS Bot Impala Diecast Toys Cars on eBay 0 07-27-2017 09:40 AM
