2014 Impala Electrical Issues - Chevy Impala Forums
post #1 of (permalink) Old 03-27-2019 Thread Starter
cac_478@hotmail.com's Avatar
Speedometer, tach, fuel,& temp gauges in/op, heat/a.c. In/op, tpms, airbag, abs, & traction control lights on, radio intermittently shuts off, car will not start without the fob placed in the compartment inside the center armrest & starting/shutting off has a delay. First issue was about a year ago, blind spot detection stopped working, light stayed on in the mirror - drivers side first then passenger, both quit working completely & message displayed on dash, clear message & everything worked as normal expect side detection. Started having the issues listed above a couple of days ago, started going through the wire harness checking connections & grounds, found corrosion inside the connection plugs to the side detection modules. Disconnect modules on both sides & everything went back to working normally, just a message displayed for side detection & front camera which are not hard codes so remote start still works. Modules will have to be replaced & corrosion cleaned, but car works normally again. Access to the modules & disconnecting them is pretty easy, i removed the rear tires & removed four mounting screws on each side of the back of the wheel well insert, takes a small torx bit, pull wheel well insert back & you will find the modules mounted about 16" back on the inside of the rear bumper. Disconnect the plug & look for corrosion. Tape up plugs if not replacing modules right away & start the car, all issues should be gone immediately. Good luck.
2014 Impala limited Instrument cluster issues MattDHardy Chevy Impala 8th Gen Discussion 17 08-19-2019 12:47 PM
Kool Vue Power Mirror For 2006-2013 Chevrolet Impala 2014 Impala Limited RH RSS Bot Impala Diecast Toys Cars on eBay 0 11-19-2018 05:41 PM
Multiple engine issues on a sitting Impala Teforne 7th Gen Engine Performance 3 10-31-2017 12:04 PM
2015 2016 2017 2018 chevrolet impala parking sensor 2014 chevy impala pdc oem RSS Bot Impala Diecast Toys Cars on eBay 0 09-11-2017 06:40 AM
