2014 Impala Limited MAF mating electrical plug - Chevy Impala Forums
  • 1 Post By its420erik
post #1 of (permalink) Old 10-04-2017 Thread Starter
its420erik's Avatar
Hi All,
I own a 2014 Impala Limited with the 3.6L engine.
In the course of changing the air filter, I removed the electrical connector from the MAF sensor to gain some extra slack.
I went to use the car later that night, and I noticed the electric cooling fans came on at full speed and remained that way the entire 10 minute trip I took (even though engine was not hot). When I parked the car and shut it off, the fans remained running for a good 5 minutes afterwards.
I started investigating, and discovered that when I re-inserted the electrical plug, I must have bent one of the pins on the MAF sensor, and it was flattened to the bottom of the housing and touching another pin. I tried bending the pin back, but it is still not quite straight. I think bending it twice also weakened the pin somewhat. I also discovered that the mating plug itself got somewhat mangled, and it looks like one of the contacts is in bad shape.
It looks like my MAF sensor will need replacement, however, does anyone know where I can find the mating electrical plug that is attached to the wiring harness?
The MAF part number is 20787043.
The mating plug has the following markings: 140511A C08C. I can't seem to locate, so maybe that is not the part number.
Thanks,
Erik
its420erik is offline
post #2 of (permalink) Old 10-05-2017
Quoted: 201 Post(s)
Go to your GM dealer with the car's VIN. The part's department employee can determine if GM sells a pigtail connector for the damaged one, that you could splice-in.
I do not have a part number that will enable you to look online and order it. Good luck.
post #3 of (permalink) Old 11-06-2017 Thread Starter
its420erik's Avatar
Thanks for the advice "1999 White C5 Coupe". It turns out I found a pigtail connector online.
If anyone else encounters this problem, I was able to find a generic "8-way MAF Sensor Plug Connector Pigtail" online at a place called Ballenger Motorsports in Mechanicsville, VA.
Part # is CONN-85897 and goes for $21.99.
I have since learned that the AC Delco pn20787043 8-pin MAF sensor is built by Hitachi, and the pin out is as follows:
 Pin 1 – Signal, IAT 1
 Pin 2 – +5V Reference
 Pin 3 – Low Reference
 Pin 4 – Signal, BARO (TIAP)
 Pin 5 – Ignition, +12V
 Pin 6 – Signal, MAF
 Pin 7 – Ground, Chassis
 Pin 8 – Signal, Humidity (duty cycle – %) and IAT 2 (frequency – Hz)
Apparently I had bent and shorted pin 1 (IAT 1) to pin 2 (+5V reference), so that the IAT 1 signal was always high.
post #4 of (permalink) Old 11-07-2017
Maven76's Avatar
Quoted: 80 Post(s)
That is cheap as hell for that pigtail, good find. I
GM World Class Technician
Im just here for the cookies
Maven76 is offline
2014 Chevy Impala with 9C1 wheels? Trax779 Wheels and Tires 1 04-20-2018 09:33 AM
2 Replacement For 2014 2015 2016 2017 Chevrolet Impala Limited Flip Key Fob Case RSS Bot Impala Diecast Toys Cars on eBay 0 02-14-2018 03:10 PM
'15 Impala Limited vs LLT Camaro RS etb4u Street Racing 1 10-31-2017 09:15 PM
