'02 impala low-coolant light on but engine not hot? - Chevy Impala Forums
post #1 of (permalink) Old 09-20-2007
rd6108
rd6108's Avatar
Quoted: Post(s)
I've had to add some water several times in the past six weeks to the overflow bottle. The low coolant lamp lights but the engine doesn't get hot (overheat)
post #2 of (permalink) Old 09-20-2007
shovelkicker
shovelkicker's Avatar
Quoted: Post(s)
First and simplest would be to replace the radiator cap. Sounds like it might be getting old and not holding pressure.
The low coolant sensor is in the overflow bottle, hence the light is on but the engine is not overheating.
Try to replace this low fluid with coolant and not just water. The straight water can freeze in the bottle cracking it and over time and refills will dilute the coolant in the motor/radiator.
If you keep having to add coolant after the cap, you need to get the cooling system checked. It has to be going somewhere, lets hope a leaky hose, worst case a bad head gasket.
Happy Holidays
post #3 of (permalink) Old 09-20-2007
3DDD
3DDD's Avatar
Quoted: Post(s)
Sounds like you have a leak. You can pressure test the system to find where. If you cant do it yourself it should not cost a lot for a honest mechanic to do it for you.
73 impala intermittent dash light dunnhole Impala 1st - 5th Gen Discussion 5 11-30-2017 02:49 PM
2013 Impala Airbag Light On reubenswinks Chevy Impala 8th Gen Discussion 11 07-27-2017 06:06 AM
2000 01 02 03 04 05 chevy impala emergency hazard light switch button RSS Bot Impala Diecast Toys Cars on eBay 0 07-22-2017 10:50 AM
Coolant Lose...Head Gasket/Block? Lce Chevy Impala 7th Gen Discussion 2 07-20-2017 04:29 PM
New Engine Coolant Level Sensor Module For Chevrolet Impala Buick GM 10096163 RSS Bot Impala Diecast Toys Cars on eBay 0 07-19-2017 11:30 PM
