Rear end swap on a 72 impala from a 96 impala ss - Chevy Impala Forums
post #1 of (permalink) Old 03-04-2019 Thread Starter
Gemale11's Avatar
I switched out my 72 impala rear end with the rear from a 96 impala ss. The original rear had drum brakes and the ss has disc brakes, 373 gears and the posi traction. Everything bolted right up with no problem. I noticed that the Emergency brake cables on the 96 ss were way longer than the ones on the original rear and it also has a different fitting on the end that connects to the inner side of the caliper, the fitting is connected to a hook that locks the brakes when you step on the pedal. I have no I sea how to make this work the original cables on the 72 rear end are 37.062 inches and the one on the 96 ss rear end are almost or about 73 inches! Does anyone have an answer so I can get this tool in care of ASAP!???? Here’s a pic of the fitting that is on the newer cable that’s not on the old one
Gemale11 is offline
post #2 of (permalink) Old 03-20-2019
DesertXL's Avatar
Quoted: 5 Post(s)
Hello Gemale11,
I just completed installing a custom made Ford 9" utilizing 94-96 Impala SS/9C1 rear disc brakes on my 1973 Caprice Classic. How I incorporated the '94-'96 full size rear disc parking brakes is I used the '94-'96 parking brake cables and lightly modified the '73 front and intermediate cables to attach to the later model cables. Works great.
Here are some pictures if it helps.
This is the near final installation. But you can see the 94-96 parking brake cable routing.
Passenger side cable
Drivers side.
Using the 94-96 tensioner
The 94-96 cables snap the in same place as on the 73
The original front cable that I sliced up for test fitting. Then a new replacement, which was made incorrectly anyway, that I modified for final assembly.
I made my own cable crimps from 304 stainless on the lathe.
I used an electrical hydraulic crimper to crimp the cable stops on.
Then I really shortened the long intermediate cable to this.
I used the original cable end ties. Now this transmission cross member is temporary for this car. Later this summer I am installing a 4L80E in lieu of the TH400. This cable guide forces the cable down further than I'd like. Really you want the guide up and through the cross member instead. But like I said this is a temporary thing so I didn't want to waste time on this cross member since a new one will be made for the 4L80E and the parking brake will be routed higher than this.
Hope this helps a bit, some fabrication work involved but they work splendidly and safely.
Cheers
DesertXL is offline
96 Impala SS rear end "Clunk" Peteroros Chevy Impala Discussion 5 12-22-2018 06:31 PM
1994 1995 1996 Chevy Impala SS Black Rear Passenger Door Bezel Insert 94 95 96 RSS Bot Impala Diecast Toys Cars on eBay 0 08-09-2018 08:10 AM
94 95 96 Impala SS REAR TRUCK LIGHT OEM CHEVY CHEVROLET CAPRICE 9C1 RSS Bot Impala Diecast Toys Cars on eBay 0 09-10-2017 11:40 AM
94 95 96 1994 1995 1996 Impala SS Caprice Grey Rear Door Panel Window Switch RSS Bot Impala Diecast Toys Cars on eBay 0 08-25-2017 06:40 PM
1994 95 96 chevrolet impala ss gray leather rear seats RSS Bot Impala Diecast Toys Cars on eBay 0 08-22-2017 06:40 PM
