1977 impala street project named "OH" - Chevy Impala Forums
 4Likes
post #1 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
So i have another built thread going on gmbbodyforum.com but i thought i would post up here as well.
little back story car had been abandoned since 1995 at a a few residences here and there in town. I was able to snag it with a broken th200 trans in it for 500 bucks. Didnt have a title but found the Gal that owned the car and she signed the title over to me free and clear as long as i didnt crush it or turn it into a derby car. I gladly excepted and the past 2 1/2 years its been slowly coming together.
first it had a stock smog small block in it. put a "built" th350 in with a 2600 stall converter, took the quadra junk off and put a fitech efi throttle body on it in 2015 along with a complete fuel system including a Aeromotive A1000.
2016 got super busy with dirt racing and traveling with it, so the car sat and i traded my brother the fi tech for a complete 4.8ls with harness. like a said the car sat all year long didn't move at all. Time didn't allow for it.
2017 things changed in my personal life and i realized that this thing needs to be done so my little girl can be happy and enjoy it
she named the car "OH" and has every intention of making it her first car ever. This car has come to represent more than just a build or an old classic to keep from the scrap yard... it represents imagination and childhood happiness
So skip to 2017-18
spent all summer working on it. tore the engine apart put a BTR cam, dual valve springs, push rods, cam, mls head gaskets and arp head bolts. Also installed new timing chain, chain guide, 25% pulley. and a Holley 302-2 oil pan. put dual drains in the front timing cover for turbo drains and put a brand new Borgwarner S475/83 t4 turbo on. used the factory truck intake with 80lb injectors and got everything tuned. did put a Holley mid rise on it an a 92mm tb. taking that off an going to a TBSS intake instead
Did Just move the the engine coils to the frame rail because it kept eating plug wires. So we shall see how that goes.
now the car is getting a TH400 with a 2800 stall converter and i swapped out the factory 8.5 gm axle for a 8.5 BOP with factory C clip eliminators
Just installed a set of Moser axles and a LWP diff cover this weekend along with a S-10 factory disk brake conversion.
Big thank you goes out to a friend of mine that i met through the gmbbodyforum he gets me all the body parts i have needed for this car. including nos front marker lights and 2 front head light buckets in mint condition i couldn't make this car what i wanted to without him and a big thank you to all the guys on that forum that have helped me too!!!
link https://www.gmbbodyforum.com/t627p75-the-goose
so now time for pictures. ( sorry about the long read, passion gets the best of me at times)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
coil mounts
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
8.5 bop
1977 impala Aero Coupe White
Turbo LS/TH400 Disc Brake Conv.
1977 Impala Aero Coupe Red
Bone Stock 305 2bbl on Studded snow tires
1978 Malibu Landau coupe
"Mini-Me"
2015 F250 Platinum CCSB
Stockcar10 is offline
post #2 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
if there are any other pictures you would like to see or any other info let me know
"Mini-Me"
post #3 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
[IMG][/IMG] shes a racer through an through an my inspiration for my life
[IMG][/IMG]
[IMG][/IMG]
figured out these intakes were not built for truck accessories. so 1" 4 port carb spacers were needed to clear the idler pulley and belt.
"Mini-Me"
post #4 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
new BOP LPW diff cover
also welded up the axle tubes to the carrier housing this weekend.
"Mini-Me"
post #5 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
Goodies from Moser Engineering came in this past week and we got them installed this weekend
Scored a free 2002 ish s-10 blazer rear axle and was able to get the entire brake assemblies off of it. So as of right now i'm $85 into the rear disk brake conversion!!
"Mini-Me"
post #6 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
clears 15" wheels perfect
Old Bones likes this.
"Mini-Me"
post #7 of (permalink) Old 04-05-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
just gonna leave this right here
"Mini-Me"
post #8 of (permalink) Old 04-05-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
th400 is installed sitting on the old cross member and got the drive shaft measured.
just came in today. went to a 3.5" tube as well
"Mini-Me"
post #9 of (permalink) Old 04-06-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
275 60 15 m/t pro radial
"Mini-Me"
post #10 of (permalink) Old 04-09-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
got the trans cross member modified brake system put back together and bled. trans cooler and lines flushed out. just need to fill the trans full of fluid and start it.
15x10 5.5 offset should work better, probably at 6" is the best but 5.5 will defiantly work unlike the 6.5
so if any one needs some weld wheels i got a pair to sell :-)
"Mini-Me"
post #11 of (permalink) Old 04-09-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
ordering longer wheel studs today
"Mini-Me"
post #12 of (permalink) Old 04-10-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
Well last night had a sucessful test drive. no fluid leaks at no other issues. car makes about 15psi and stops on a dime.
these 4:10's woke it up big time. now just need to get some 28 10.50s and it should be alittle better for street driving.
still need to swap the intake over and get the tune dialed in but it should be fun from here on out.
"Mini-Me"
post #13 of (permalink) Old 04-16-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
not much of an update. drove the car some this past week then it snowed again so i parked it. in process of swapping out the holley midram for the tbss intake with holley rails.
"Mini-Me"
post #14 of (permalink) Old 04-16-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
[IMG][/IMG]
out with the old
[IMG][/IMG]
in with the new.
little cutting, bending, drilling and tapping and the holley rails fit like a glove
"Mini-Me"
post #15 of (permalink) Old 04-26-2018 Thread Starter
Stockcar10's Avatar
Quoted: 7 Post(s)
well took the car to get the tune finished ran into some unexpected issues. ended up swapping out injectors.
but i did get longer wheel studs installed and new lug nuts for the rear tires/wheels. sitting on the floor this girl is mean... pictures do no justice to the look this thing has
[IMG]
15x10 5.5bs with a 28 10.50 tire
"Mini-Me"
Project FS: 1961 Impala 1961:FS Private For Sale Classifieds 1 04-22-2019 05:04 AM
El Jefe, The 65 Impala project nowhereman Restoration Forum 0 09-18-2018 03:58 PM
1977 Chevy Caprice Chrome Seat Trim Mounding 1978 1979 Impala Box Chevy Interior RSS Bot Impala Diecast Toys Cars on eBay 0 08-23-2017 11:30 PM
Hooker Headers 2063 Street Force Headers 1994-96 Impala SS with 350 LT1 RSS Bot Impala Diecast Toys Cars on eBay 0 08-23-2017 02:06 AM
1977 Chevy Impala: Ca smog guidance? townchevy77 West Coast 1 07-26-2017 10:49 PM
