1977 impala th400 swap - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 03-20-2018
Quoted: 88 Post(s)
The 2007+ truck intake is actually very good and cheap. Called the Trailblazer SS intake in this article.
20 LS1 Intake Manifolds: Tested! - Hot Rod Network
Mocked up the stock 2004 intake in my Caprice and while it was going to need some cowl hammering it looked like it could work with the custom built mounts I got from a GM powertrain engineer.
Dwayne J is offline
post #17 of (permalink) Old 03-21-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
thats actually the intake im ordering this week. and putting the holley mid ram up for sale
i want to be able to reuse my 92mm throttle body
Stockcar10 is offline
post #18 of (permalink) Old 03-21-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
what did they have to do to make the mounts work?
1977 impala Aero Coupe White
Turbo LS/TH400 Disc Brake Conv.
1977 Impala Aero Coupe Red
Bone Stock 305 2bbl on Studded snow tires
1978 Malibu Landau coupe
"Mini-Me"
2015 F250 Platinum CCSB
post #19 of (permalink) Old 03-21-2018
Quoted: 88 Post(s)
KDS Performance the guy who I tested prototype mounts for ended up opening this shop.
The 94-96 cars have an odd low mount AC compressor that makes the passenger side motor mount a but unique.
Right now I have little ambition to work on the Caprice, kids, bigger yard/house, career, getting fat and middle aged are all working against it. Car isn't worth anything so no motivation to sell it either, maybe work on it when the kids are a little older, local track starts some bracket racing at 13yo with parent in car and without at 16yo.
For now the family hotrod is electric, with 440tq from 0-43mph and 416hp from there to 73mph and will run 12.4 in the quarter stock, without all the noise and drama of a high stall and loud exhaust etc.
What are you doing for an axle? the low spline count stocker even if an 8.5" 10-bolt is going to be stressed, the later 30spline axle should handle it unless you are putting a brake in the TH400
Dwayne J is offline
post #20 of (permalink) Old 03-22-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
ill have to check them out.
and i hear you i have another 77 impala coupe sitting in my yard with a cage in it. trying to get a title for it and want to do a back half kit on it.. but this one is gonna be the toy for now. my little girl should start racing 1/4 midgets this year so well see how far we get on her street car (this one).
im gonna run the 28 spline till it breaks. having moser make me some bop replacements so i can the factory c clip eliminators and then its off the the junk yard to get some s 10 blazer brake brackets calipers and rotors!
putting the trans in tonight after work hopefully
"Mini-Me"
post #21 of (permalink) Old 03-22-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
Moser BOP axles and factory C clip eliminator kits on order
"Mini-Me"
post #22 of (permalink) Old 03-22-2018
Quoted: 88 Post(s)
Not easy to find but you realize a 94-94 cop car or Impala SS is a 30spline 8.5 with discs. The Impala axle is wider than the cop car axle, so the cop car axle might be better with slicks
Dwayne J is offline
post #23 of (permalink) Old 03-23-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
yeah ive been lookin for ever for one but they all have been crushed in the wyo colorado neb region an the ones that arent they want 3000 plus to buy the whole car
"Mini-Me"
post #24 of (permalink) Old 03-26-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
well didnt get the transmission installed this weekend like i wanted. decided to put it on my brothers lift so we could figure how we were going to modify the trans cross member. Still had a productive weekend on the car. decided to finally move the coils to the engine block(or so i hoped) or anywhere off the valve covers. Car has a tendency to eat plug wires even with wires being wrapped and the headers being wrapped.
heres some pictures. ended up using a new set of 12" factory plug wires and cut all the spark plug ends off and put on 90" ends with socks. the coil brackets are from ict billet and i fabricated the frame mounts out of some spare steel laying around my work ill redo the drive side to match the passenger side later on. i will say the coil pack jumper harness i got was just a hare to long. probably need to get a 15" jumper instead of a 24" but it will work for now
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
driver side mount
[IMG][/IMG]
this was before the wires were finshed as they arent wrapped nor do they have 90 degree ends on them
[IMG][/IMG]
passenger side mount
passenger side sits just above the starter and i made sure that theres no way they could ever contact the starter or its wires. also to take the coils out just have to remove 2 bolts and the hole assembly comes off the frame rails. I personally think they came out way nicer than i imagined!!
"Mini-Me"
post #25 of (permalink) Old 03-26-2018
Quoted: 88 Post(s)
There is a guy that makes tubular tranny crossmembers for the 94-96 cars that are a LOT easier to work with, not sure about compatibility or maybe you have the resources to fab something.
What headers did you use? I was looking at having band flanges added to truck manifolds since they are held in high regard up to about 1000rwhp, cast iron holds heat well.
I am sure there are a lot more options in the 6 years my car has sat.
Dwayne J is offline
post #26 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
yeah were just going to c notch the factory cross member and call it a day
and they are ebay turbo headers. if you run them you might have to do some fab depending on your setup. we had to cut down the right side about 2" so the flanges were even across the front of the engine.
"Mini-Me"
post #27 of (permalink) Old 04-03-2018 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
[IMG][/IMG]
got the th350 out and the built 400 is ready to go in. fingers crossed it will be in tonight.
"Mini-Me"
post #28 of (permalink) Old 06-24-2019 Thread Starter
Stockcar10's Avatar
Quoted: 9 Post(s)
got it in got it going and driving had the wrong converter in it the whole time
"Mini-Me"
impala 1981 wagon 496 bbc tall deck swap! rockabilly66 Chevy Impala 6th Gen Discussion 0 04-12-2019 06:46 AM
Rear end swap on a 72 impala from a 96 impala ss Gemale11 Impala 1st - 5th Gen Discussion 1 03-20-2019 08:26 PM
1977 Chevrolet Impala RSS Bot eBay Cars For Sale: Impala 0 07-08-2018 02:51 PM
1977 chevy caprice door pillar trim impala RSS Bot Impala Diecast Toys Cars on eBay 0 08-27-2017 06:40 PM
1977 Chevy Caprice Chrome Seat Trim Mounding 1978 1979 Impala Box Chevy Interior RSS Bot Impala Diecast Toys Cars on eBay 0 08-24-2017 12:30 AM
