2012 ltz turbo 3.6l build - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 02-26-2014
volume's Avatar
Originally Posted by MDLTZ View Post
Yeah I've been contemplating on just doing a front mount but I'm worried about having no access for tubing and having to cut into radiator support
I should be getting the manifolds made up on Sunday I'll take pics if I do
why not do a air to water intrecooler?
volume is offline
post #17 of (permalink) Old 02-27-2014 Thread Starter
MDLTZ's Avatar
Originally Posted by Dwayne J View Post
I was saying that on V8s 2.5" crossover is too big. For a V6 it would be monstrous. 2.5" might be an OK size for after the merge, but probably a bit oversized even there unless looking to push the motor hard. Compressed gases are just the compressed and don't take up as much volume so a smaller pipe is appropriate.
Your talking about from the exhaust manifold up to the turbo correct? I'm gonna run 2 in pipe to a 2.5-3in into turbo then all my intercooler piping will be 2.5 in
Then turbo back I'm gonna run 3" out to the back
MDLTZ is offline
post #18 of (permalink) Old 02-27-2014
JerryPH's Avatar
Yeah, some minor fab work may or may not be needed for the rad supports, but you'd be getting 3-5 times more air flow through the intercooler, so it would be well worth it.
BTW, when coming down to the key to making this whole turbo project work with your setup, what are your plans for the tuning? You doing it yourself or getting someone to do that for you? Stock tune is going to do nothing for you in a turbo setup except help blow it up faster... lol
Just your average Impala
My Impala Website:
JerryPH is offline
post #19 of (permalink) Old 02-27-2014
JerryPH's Avatar
Likely just reduced cost and complexity issues, though A2W ICs do cool more effectively.
This is going to likely be a lower boost setup and the added complexities of a water pump, extra plumbing hoses and (for best effect if you want to go all out) a trunk mounted ice container may be beyond the scope of what the user looks to want for final results.
My Impala Website:
JerryPH is offline
post #20 of (permalink) Old 02-27-2014
SC2150's Avatar
Couple of observations, the earlier aluminum IM is a different port design and bolt pattern, your plastic OEM one will be fine, we boost them to 12-14# no issues.
Intercooler where you have it will do little to cool IAT temps. You must have constant flow through it of unheated air from the front of the car, so really needs to be behind grill or could be remote mounted anywhere it can get cool fresh air forced through it. Even a cooling fan added.
The MAF needs to be at least 6-8" from the TB to prevent error's in the MAF flow readings as the TB blade shuts.
Tuning, Will at Overkill can master that for you...he is awesome and we just finished a 2014 LFX engine single turbo with AWD and mid 400's to the wheels. Owners goal was to spank new Porsche Turbo Cayenne and he did handily. Will made cold start, warm start, and drivability excellent as well.
How are you oiling and doing oil return?
PCV evacuation is critical when your boosting through the IM so ask if you want guidance.
We do all types of FI to the 3.6L DI GM engines and have learned all the nuances and modifications needed to make it work. Good luck and were willing to offer guidance if you want it.
SC2150 is offline
post #21 of (permalink) Old 02-27-2014
Quoted: 80 Post(s)
Stay small on the hotside of the exhaust, after the turbo 3" may be OK but would be wildly overkill for before the turbo.
Dwayne J is offline
post #22 of (permalink) Old 02-28-2014 Thread Starter
MDLTZ's Avatar
Yes any guidance would be helpful, there is a go tuning specialist near Philly that will tune it he said for about $400.
I most likely will be changing to a FMI
for oiling I was gonna run a sandwich plate and run feed and returns off of that
What do you suggest for pcv evacuation
MDLTZ is offline
post #23 of (permalink) Old 02-28-2014 Thread Starter
MDLTZ's Avatar
Where is Overkill located?
MDLTZ is offline
post #24 of (permalink) Old 02-28-2014
Caprice Classic with Class
Old Bones's Avatar
Quoted: 66 Post(s)
:: Overkill Motorsports ::
Holly 0-83670 4 Barrel Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Sony F-50 dash-cam with GPS Antenna. Crazy Canuck behind the Wheel.
Old Bones is offline
post #25 of (permalink) Old 02-28-2014 Thread Starter
MDLTZ's Avatar
Originally Posted by Old Bones View Post
Oh wow....they are up in Canada, that's a long drive to get a dyno tune
MDLTZ is offline
post #26 of (permalink) Old 02-28-2014 Thread Starter
MDLTZ's Avatar
Originally Posted by mdltz View Post
yes any guidance would be helpful, there is a go tuning specialist near philly that will tune it he said for about $400.
I most likely will be changing to a fmi
for oiling i was gonna run a sandwich plate and run feed and returns off of that
what do you suggest for pcv evacuation
GM tuning specialist*
MDLTZ is offline
post #27 of (permalink) Old 02-28-2014 Thread Starter
MDLTZ's Avatar
My goal is 500hp to the wheels but my only and main concern is the 6 speed transmission. ..
Will it hold up to 500hp or more?
MDLTZ is offline
post #28 of (permalink) Old 03-01-2014 Thread Starter
MDLTZ's Avatar
OK I found the turbo I'm gonna run its a precision 6766 67mm ball bearing turbo and I'm might possibly run up to 10psi not sure yet
MDLTZ is offline
post #29 of (permalink) Old 03-01-2014 Thread Starter
MDLTZ's Avatar
MDLTZ is offline
post #30 of (permalink) Old 03-03-2014 Thread Starter
MDLTZ's Avatar
UPDATE:
Got everything for build but intercooler piping.
Didn't get exhaust done due to rain/snow. But should have it done this coming Friday or Saturday can't wait.kll have pics taken before it's put back to stock.
MDLTZ is offline
2013 LTZ vs Hyundai sonata turbo and Kia optima turbo turbotodd69 Street Racing 4 10-30-2016 02:27 PM
Chevrolet : Impala LTZ/LIKE BRAND NEW/2012/LTZ/FULLY LOADED/SAVE BIG 2012 LTZ LIKE BR RSS Bot eBay Cars For Sale: Impala 0 06-14-2012 12:51 PM
Chevrolet : Impala LTZ/LIKE BRAND NEW/2012/LTZ/FULLY LOADED/SAVE BIG 2012 LTZ LIKE BR RSS Bot eBay Cars For Sale: Impala 0 05-30-2012 08:30 AM
Chevrolet : Impala LTZ/LIKE BRAND NEW/2012/LTZ/FULLY LOADED/SAVE BIG 2012 LTZ LIKE BR RSS Bot eBay Cars For Sale: Impala 0 05-16-2012 09:40 AM
looking for Twin Turbo/supercharge for my caprice 200 ltz 5.7 Danger Chevy Impala Discussion 12 05-10-2010 02:23 AM
