maintainance - Chevy Impala Forums
post #1 of (permalink) Old 04-18-2009 Thread Starter
bonez's Avatar
Thumbs up maintainance
i just put a vortec supercharger on my 96 ss car has headers and flowmaster thats about it the mechanic said the supercharger is at 9 psi. people have been telling me that is too much for stock internals WHAT SHOULD I HAVE DONE TO THE INTERNALS TO KEEP THE ENGINE SAFE????????:
bonez is offline
post #2 of (permalink) Old 04-18-2009
Quoted: 84 Post(s)
Well there are a few different ways the engine could be hurt.
Most common is poor tuning too much spark, can cause detonation, as can too much or too little fuel. Detonation cracks rings or pistons and it like taking a hammer to bearings.
Another way it can fail is too much heat from all that power makes the rings grow and the gap that is supposed to be there butt closed, ring jams in the bore and rips the ring land off the top of the piston.
To make the engine handle the boost you are looking at a full engine build. Could go fairly budget and just put in forged pistons then refurbish and rebalance the rods and crank. Have the heads rebuilt with at the very least better springs because with boost trying to open the intake valve you need more spring pressure.
If you get good heads it will make more power but the boost number will get lower, boost is how much air is NOT getting into the engine and when you make the engine move the air with less restriction it makes more power but the stress on the crank snot driving the blower goes down as does the boost number.
What sort of budget do you have and we can try and help you work something out.
Understand though that boost alone does NOT make a car fast. First forced induction Impala I saw in person was 5-6 years ago, was forged pistons(otherwise stock down to the cam) alky injected(intercooling not as fuel) single turbo setup running 11-12psi ran high 12s. I was impressed at that point, but these days and decently done heads/cam car will walk all over that one.
Dwayne J is offline
post #3 of (permalink) Old 05-09-2009
BAD IMP's Avatar
What Dwayne said above is dead on accurate. I think you can look at getting a different pully to change the boost, Right??? Going that high on boost can be bad for your motor. I was told the max boost for a stock internals is 8, with 6psi being the best. I have heard of a guy running 10psi for the past couple years and no problems, YET. Like Dwayne said above the real key is tuning. If your tuning is off you will have problems very soon.
1996 Impala SS DCM, Powerdyne Supercharger 6 psi, 3.73s, Snow Performance Water/Meth injection, Borla catback system, Grotyohann long tube headers, Magnaflow high flow cats, Hotchkis springs, front and rear sway bars, Bilstein shocks, Vigilante 3000 stall TC.
BAD IMP is offline
