Getting in over my head... on purpose? - Chevy Impala Forums
 5Likes
  • 1 Post By WickedGoat
  • 1 Post By plano-doug
  • 2 Post By 12 lt
  • 1 Post By Old Bones
Scrappy's Avatar
Quoted: 9 Post(s)
Question Getting in over my head... on purpose?
Greeting, And a preemptive happy memorial day!
So, I've got it in my head that I *REALLY* want to add a turbo to my '06 SS w/ 5.3ltr - because... well... why not?
I recently had the transmission rebuilt and supposedly he used tougher-than-factory parts in the rebuild and should be a lot stronger than factory.
As I've stated many times, I'm not a mechanic... so much as a tinkerer who wants to learn. What all do I need to accomplish this feat of engineering? I've found a few "kits" on ebay that are supposedly compatible with my car.. but I feel like they are going to be missing some vital piece that will leave me with a half-assembled car lol
I've found this - doesn't seem to include an inter cooler (necessary?):
https://www.ebay.com/itm/T3-T4-Hybri...sAAOSwBmZWCtLZ
and this inter cooler kit:
https://www.ebay.com/itm/2-5-Diy-Tur...oAAOSwxupcx5ca
Any experts our there that confirm that is all I need? I presume I'd also need some one to modify or program the ECU / chip to work with the added air flow / pressure in the system?
I thank you for your time and appreciate all guidance in this foolish endeavor.
Kind Regards,
-JDT
Kind Regards,
-JDT
Scrappy is offline
Bill58's Avatar
Quoted: 44 Post(s)
Going to need a ton of exhaust fabrication to feed the hot side of the turbo. ECU programming and a 2 bar map sensor.
Bill58 is offline
Scrappy's Avatar
Quoted: 9 Post(s)
I've been contemplating some exhaust work... is there a setup that sounds particularly great on these cars?
I used to have a set of straight pipes attached to Flowmaster series 80s(?) sounded pretty sweet imho.
Kind Regards,
-JDT
Scrappy is offline
post #4 of (permalink) Old 4 Weeks Ago Thread Starter
Scrappy's Avatar
Quoted: 9 Post(s)
Kind Regards,
-JDT
Last edited by Scrappy; 4 Weeks Ago at 05:27 PM. Reason: duplicate posting, deleted
Scrappy is offline
WickedGoat's Avatar
Quoted: 134 Post(s)
I'm no expert, but you are going to have to do something for the exhaust manifolds and a crossover pipe, probably different piping for the intercooler to work best with your engine bay, rework the air filter set up, and most likely fuel system mods... better, higher flowing pump and injectors. Tuning will be a must... This will cost more than you think, but definitely a cool project.
And about the beefed up trans... I supposedly had a beefed up rebuild done on my 02 GTP that made about 300 horsepower and the dam thing shit the bed on me just over a year after the rebuild, and the trans shop basically told me to get bent. Hopefully your shop treats you better.
2014 Chevy Impala LTZ Limited
2004 Pontiac GTO
2004 GMC Yukon SLT
WickedGoat is offline
Quoted: 81 Post(s)
Turbo is a muffling device, they build more backpressure in the exhaust system than you get in the intake system, not going to get good sound.
If you like sound I would sooner look at modifying the engine but keeping it naturally aspirated. An intake manifold upgrade, and a larger cam shaft with exhaust upgrades should get you more power than FWD can use anyway and sound good, probably be at the limit of what the tranny will handle anyway. Be a LOT easier to pull off.
The intake on the FWD 5.3l motors is crap an LS6 intake is a fair bit better and I believe adaptable. the heads are LS6 heads but with heavier valves.
Dwayne J is offline
post #7 of (permalink) Old 4 Weeks Ago
Quoted: 333 Post(s)
Too bad nobody makes a turbo-400 kit for the 4T65E
Fred_06Impala likes this.
post #8 of (permalink) Old 4 Weeks Ago
WickedGoat's Avatar
Quoted: 134 Post(s)
Right?!?
2004 Pontiac GTO
2004 GMC Yukon SLT
post #9 of (permalink) Old 4 Weeks Ago
Quoted: 333 Post(s)
Right?!?
Back in the day, GM's Turbohydramatic-400's often got used in drag racing, probably mostly in super-stock. They would be bolted to 800-HP big blocks and hold up quite well. And there were aftermarket supplied parts for beefing them up.
Unfortunately, there's not much available for hot-rodding FWD transmissions. I gotta wonder what the shop that did yours actually did.
post #10 of (permalink) Old 4 Weeks Ago
Quoted: 223 Post(s)
Good luck with your project. Those ebay kits total under $400? And looking at the first link it says it would work on my 2012 and could make up to 450 hp. Ummm, would suspect this kit is a gimmick, too good a deal to be true.
If you do this though, report back how it goes and what type results you get.
post #11 of (permalink) Old 4 Weeks Ago
Caprice Classic with Class
Old Bones's Avatar
Quoted: 66 Post(s)
[QUOTE= Wicked Goat......
And about the beefed up trans... I supposedly had a beefed up rebuild done on my 02 GTP that made about 300 horsepower and the dam thing shit the bed on me just over a year after the rebuild, and the trans shop basically told me to get bent. Hopefully your shop treats you better.[/QUOTE]
Just curious , when you had your tranny beefed up did you tell the shop what HP to spec it to ? I have no experience with front wheel drive but my 305 had a Turbo 250 which would have blown up when I put in a 330 HP , 350cid so had a 350 Turbo Trans built to take 350 Hp , it is rock solid.
Holly 0-83670 4 Barrel Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Sony F-50 dash-cam with GPS Antenna. Crazy Canuck behind the Wheel.
Old Bones is offline
Bad head gasket...2nd time. Something else wrong? UmmScott Chevy Impala 7th Gen Discussion 15 03-03-2019 04:43 AM
04 Head Unit Adapter/ Relocation Coedy Slone Audio, Video, and Electronics 0 10-16-2018 11:24 AM
HELP! mechanic says head gasket blown on '03 Impala LS (video) SG Delco Chevy Impala 7th Gen Discussion 1 03-02-2018 08:40 PM
Head Gasket Set Head Bolts Fits: Chevrolet Oldsmobile Pontiac 3.1 & 3.4 OHV 12V RSS Bot Impala Diecast Toys Cars on eBay 0 01-03-2018 09:10 AM
« Supercharger | - »
