LT to LTZ Rim Swap How To - Chevy Impala Forums
post #1 of (permalink) Old 12-14-2014 Thread Starter
Transam7620's Avatar
Post LT to LTZ Rim Swap How To
First off thanks to LazerBlue07SS and RYD SLO for helping me with this swap.
Alright boys and girls. I have a 2008 Impala LT with 2013 LTZ wheels and tires on them. To do the swap, it is not as simple as a wheel and tire change.
LT's and LTZ's came with different suspension options LT being FE1 or FE2, and LTZ with the FE3 suspension packages. The numbers going from softest to firmest FE1-FE4.
The issue with just doing a wheel swap from the LT 16's to the LTZ 18's is the rear strut assembly clearance on the lower spring plate. (See Pics). Thus prompting you to have to change the rear suspension. The fronts have plenty of clearance with stock strut assemblies (for me) but the rears will rub.
In order to have the 18" wheels whether being SS or LTZ wheels work, you NEED to change the rear suspension if you have an LS or LT.
Heres what I ordered and worked. You can see in the pics that the new strut assembly allows for slightly more clearance on the lower spring plate. (Its a tad higher up)
- I used KYB-SR4103 and KYB-SR4104 strut assemblies for the swap to work.
- I used 2013 Impala 18" LTZ wheels but LTZ wheels from 08-13 should work. 18x7, on P235-50-R18.
Pictures:
(Left to Right - Top to Bottom)
1. Old Impala Wheels
2. New Wheels Installed
3. 16" Wheel Front Clearance
4. 18" Wheel Front Clearance (Plenty of Room)
5. 18" Wheel Rear Clearance Before Strut Swap (Rubs)
6. 18" Wheel Rear Clearance After Strut Swap (More room)
7. KYB FE3 Next To Original FE1 Strut (Lower Spring Plate is Higher)
Well, that about does it fella. Hope this helps you guys out if you plan on doing an 18" wheel swap on an LT or LS.
Name:	impala prof pic.jpg
2008 Impala LT (LTZ Clone)
-2013 LTZ 18" Wheels
-FE3 Rear Suspension
-Rear Trunk Lip Spoiler
Transam7620 is offline
The Following 4 Users Say Thank You to Transam7620 For This Useful Post:
donmateo (12-15-2014), mwilson62000 (12-14-2014), TSS (05-14-2015), volume (12-14-2014)
post #2 of (permalink) Old 12-14-2014
Quoted: 101 Post(s)
Great write-up! The only thing I will mention is that you MAY need to change the rear suspension. For whatever reason, some people don't run into the fitment issues with the FE1 or FE2 suspensions.
RYD SLO is offline
TSS (05-14-2015)
post #3 of (permalink) Old 12-14-2014 Thread Starter
Ahh alright. I mean my tire did spin even with it mounted with the original suspension but the clearance, as you can see, was so tight. I didnt want to risk it rubbing.
post #4 of (permalink) Old 12-15-2014
Quoted: 101 Post(s)
Yes, the clearance is very tight, and upgrading the parts definitely gives you some more wiggle room. My rear tires are extremely close, but not touching. I checked the tires on a lift about a thousand after putting them on, and didn't see any grooves or signs of wear from the strut mount. Definitely better to be safe than sorry though!
RYD SLO is offline
post #5 of (permalink) Old 12-15-2014
Quoted: 39 Post(s)
Glad it worked! Looks good.
donmateo is offline
post #6 of (permalink) Old 12-18-2014 Thread Starter
On a side note; How long does it take for the new strut assemblies to settle? My rear ride height is significantly taller after the install and is a little too tall actually.
post #7 of (permalink) Old 02-25-2015
grandville75's Avatar
Thanks for the write up. How's the ride with the KYBs? Stiffer ride, better handling?
grandville75 is offline
post #8 of (permalink) Old 05-01-2015
ImpKing's Avatar
I know this forum is old but what exactly is it that i need to get to put factory LTZ 18s on my 13 impala LT? just the strut?
ImpKing is offline
post #9 of (permalink) Old 05-02-2015
carlos64030's Avatar
Quoted: 17 Post(s)
I suggest you try fitting the wheels first before buying any additional parts that you MAY not need.
carlos64030 is offline
The Following User Says Thank You to carlos64030 For This Useful Post:
sthrnbumpn (11-01-2015)
post #10 of (permalink) Old 05-04-2015
Dave_N's Avatar
Quoted: 64 Post(s)
He went from 16" to 18" and the tires will rub, but if you go from 16" to 17" then you should be okay. I have the Monroe quick struts and 17" tires and the rear tires are very close to the strut plate, but do not rub. Great write up.
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline
post #11 of (permalink) Old 05-14-2015
ImpKing's Avatar
Ah, I see. Thanks, I'm going from 17s, cant wait! Great write up!
ImpKing is offline
post #12 of (permalink) Old 05-14-2015
TSS
TSS's Avatar
Quoted: 80 Post(s)
Just another note. Anybody going from 18s to 16s (for the winter) there are zero fitment issues. Only issue exists for SOME going to 18s from non 18s (ie LT).
2009 Impala SS (sold 3/2012)
TSS is offline
post #13 of (permalink) Old 01-22-2016
10ImpalaLT's Avatar
Very interesting. I put LTZ wheels and tires on my '10 LT and had no issues except having the dealer programs the TPMS to my car. Guess I got lucky..
10ImpalaLT is offline
post #14 of (permalink) Old 01-25-2016
Dave_N's Avatar
Quoted: 64 Post(s)
The old LTZ's like my car had 17" wheels, but the newer LTZ's (2012+) are 18" wheels on the 8th gens.
Dave_N is offline
post #15 of (permalink) Old 12-05-2018
Quoted: 171 Post(s)
So... going from 17" wheels/tires on a '13 LT to 18"wheels/tires would require more than the 18" rims/tires or not???
50th anniversary impala door sill plate emblem ss lt ltz chevrolet 25852263 RSS Bot Impala Diecast Toys Cars on eBay 0 07-31-2018 12:10 AM
2012 LT to LTZ fe3 Suspension change over Ziekjake 8th Gen Suspension 8 07-09-2018 07:37 PM
Front And Rear Brake Rotors & Ceramic Pads 2011 2012 2013 Chevy Impala Ls Lt Ltz RSS Bot Impala Diecast Toys Cars on eBay 0 12-20-2017 10:00 AM
Ltz wheels on LT. Help! Adot331 Wheels and Tires 4 11-07-2017 10:43 AM
10th generation impala. LTZ wheels on LT Adot331 Wheels and Tires 0 11-04-2017 11:27 PM
