Ultimate Speaker Replacement Guide for 8th Gen Impala (2006-2013) - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 02-25-2014
Quoted: 39 Post(s)
Done.
donmateo is offline
The Following User Says Thank You to donmateo For This Useful Post:
jtrosky (02-25-2014)
post #17 of (permalink) Old 08-22-2014
mommykayla3's Avatar
I recently got a 2007 Chevy impala Ltz I was wondering which speakers I could use in the back being I think they're blown? Thank you
mommykayla3 is offline
post #18 of (permalink) Old 03-05-2015
peptobismal's Avatar
I do not see any information pertaining the tweeters? I am trying to figure out the wire colors and placement in the wiring harness on the head unit. I had a mechanic install a radio when I bought it.
I just came to realize that. FADE: REAR = Front Door / Rear; FRONT = Tweeters only.
I do not have the Bose, but do have OnStar/XM. I was getting the feeling that my speakers were not delivering full potential, then realized this. I have found very basic wiring color coding w/o tweeters. The ones I find with tweeters are not specific to Impala / have no pictures of head unit and have a vast amount of little differences or major differences.
I did not want to pop the stereo out until I know for sure I have a specific diagram for my Impala, because I am sure splitting connections meant for 2 speakers to 4 is a huge hit to my sound performance. Also, based on what I can tell is the reason my chimes are nonexistent/so quiet you would need dog ears. Any help would be awesome!
peptobismal is offline
post #19 of (permalink) Old 03-05-2015
Sorry for quick double post can't figure out edits on my phone...
This is a Factory Head Unit, so it's clear.
post #20 of (permalink) Old 03-05-2015 Thread Starter
Quoted: 919 Post(s)
The tweeters just run off of the same "channel" as the door speakers - they are not separate. The rear speakers have their own channel and the front channel is for the door speakers and the tweeters. Not sure how you are getting the tweeters on their own channel like that - sound like the wiring is not done right on the head-unit.
post #21 of (permalink) Old 04-08-2015
I finally replaced my driver's side door speaker. I dunno that I did it too properly seeing as it started acting like it was going to pour. Of course, got it working and the passenger side stopped. Rain stopped and I reluctantly replaced it dreading the same consequence. Cheap $30 speakers work awesome.
Anyways, I found that all these door panel removal tutorials say to use a towel and a screwdriver, found this to be very ineffective. What I ended up doing was pulling the panel up over the lock and then using my hands to pop out the fasteners by pulling it towards me.
No issues at all and it was off in a matter of seconds. I basically just used a box to prop the panel on, because I could not get the handle cord to release as easily as I had seen. All I needed was the speaker anyways.
post #22 of (permalink) Old 06-25-2015
metalmike187's Avatar
Quoted: 7 Post(s)
What about under seat storage?
What about the Impalas with under seat storage? I'm planning on undertaking this rear speaker replacement task sometime tomorrow. It looks like the under seat storage folds away the bottom seat far enough to be able to remove the seat back without all the extra steps.
Anyone try this yet?
metalmike187 is offline
post #23 of (permalink) Old 06-25-2015 Thread Starter
Quoted: 919 Post(s)
Can you elaborate on what steps you are looking to avoid? I certainly didn't see any way to take any "shortcuts" though (I have the fold-up seats).
post #24 of (permalink) Old 09-04-2015
Cocoabeans's Avatar
Very detailed about the rear deck. I spent two days doing that the first (and last time) I changed them. Never again.
Cocoabeans is offline
post #25 of (permalink) Old 10-10-2015
USA1's Avatar
Looking around on ebay i found these
6.5 6.75 GM Chevy Factory Speaker Mount Plates Adapters Brackets Ring
about $11 for the pair shipped.....saves having to find/buy set of H3 speakers
6" 6 5 6 1 2 6 75 GM Chevy Factory Speaker Mount Plates Adapters Brackets Ring | eBay
USA1 is offline
post #26 of (permalink) Old 10-12-2015
Dave_N's Avatar
Quoted: 64 Post(s)
Maybe this thread should be made into a sticky? Nice information jtrotsky.
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline
post #27 of (permalink) Old 10-12-2015
KG2014's Avatar
Quoted: 59 Post(s)
He referenced these in his original posts and states they aren't of the best quality. Which is why he referred to the hummer speakers.
Yeah I got a few mods.......
Check out my mod thread here
Check out my garage here
KG2014 is offline
post #28 of (permalink) Old 10-13-2015 Thread Starter
Quoted: 919 Post(s)
The speaker adapters mentioned above are actually a little different than the Scosche adapters - so it's possible that they are better quality (they do look a littler "sturdier"). However, the biggest benefit of the Hummer brackets are that they have the little "roof" that covers the speaker from falling water, etc (in case water would get into the door) - just like the stock bracket has - and more importantly, they have the foam going around the front of the adapter, which helps avoid any sound loss into the doors - it basically create somewhat of a "seal" between the speaker and the speaker grille that is built into the door - just like the factory speaker does. They also have a thin layer of foam on the back, where the bracket meets the door, which is nice (may help to avoid rattles, etc). It's just a better overall solution, in my opinion.
Kinda curious to see how these newer-style brackets work out too though...
post #29 of (permalink) Old 10-13-2015 Thread Starter
Quoted: 919 Post(s)
Here are some pictures of the Hummer speakers where you can see the foam (front and back) and the "roof" that I'm talking about. I would imagine that the "roof" may also help the sound quality as well...
post #30 of (permalink) Old 11-01-2015
USA1's Avatar
I got the ebay ones and they look to be fairly solid not flimsy no roof or foam but I am considering laying up a fiberglass bowl for the speakers and adding so poly fill I did this on my dime a few years back and it worked out well, as for the foam weather stripping is fairly cheap since that's all the foam is to begin with...more to come as the pile is building.....hehehe
2006 Impala 9C1
Lund in channel vent visors
Interior LED kit
Trunk LED strip
Comming soon a Pioneer Nav Sound System w/ back up camera
USA1 is offline
Front emblem replacement 2013 impala xtremewhite99 Appearance 0 03-27-2019 06:04 AM
Premium All Weather Front Chevrolet Impala Floor Mats 2006 - 2013 RSS Bot Impala Diecast Toys Cars on eBay 0 07-30-2017 09:00 AM
For 2006 - 2013 Chevy Impala LT / LTZ / LS / SS LED Tail Lights Red Smoked RSS Bot Impala Diecast Toys Cars on eBay 0 07-23-2017 06:40 PM
Premium All Weather Front Chevrolet Impala Floor Mats 2006 - 2013 RSS Bot Impala Diecast Toys Cars on eBay 0 07-22-2017 08:50 AM
SPOTLIGHT POLICE 2006 to 2013 CHEVROLET IMPALA L/S RSS Bot Impala Diecast Toys Cars on eBay 0 07-21-2017 01:40 AM
