7th and 8th gen transmission service procedure - Page 3 - Chevy Impala Forums
post #31 of (permalink) Old 12-16-2012
OEM LOL
Ejbiers's Avatar
I wouldn't start preventive maintenance at 240k lol
If it aint broke at 240k dont fix it.
2016 Mustang GT PP Premium
Know the truth
http://infowars.com
Ejbiers is offline
The Following User Says Thank You to Ejbiers For This Useful Post:
Robby D. (09-16-2015)
post #32 of (permalink) Old 12-17-2012 Thread Starter
Quoted: 6 Post(s)
If you don't know the maintenance history, check the fluid. If its dark and stinky, it's probably been a long time, and you're best off leaving it alone. But if its just a little brown, or pink or red, go ahead and service it, since it has probably been done recently enough.
post #33 of (permalink) Old 12-24-2012
jim1405's Avatar
Hey King, I've got a 2007 3.5 (bought new in Nov. 2006) with 63,000 on it. Whats your 2 cents about whether or not to change the tranny fluid in this case? Cars shifts just fine and the fluid has just a slight brown to it. Does age make a lot of difference? That is, 63000 in 6 years vs same mileage in three years. It's been very well maintained otherwise but want to make sure I'm doing what I can to keep the tranny going strong. I didn't realize they have a reputation for short life until recently
Thanks!
jim1405 is offline
post #34 of (permalink) Old 12-25-2012 Thread Starter
Quoted: 6 Post(s)
63k isn't too bad, and time doesn't make much difference. I would go ahead and change it.
post #35 of (permalink) Old 01-01-2013
g25racer's Avatar
A flush every 30-50k and filter change every 100k for any GM is good rule of thumb. Also, do not use any additives in GM tranny's. Alot of people don't as it is kinda pricey but, your car and wallet will thank you later.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #36 of (permalink) Old 01-07-2013
Lucky1's Avatar
Thanks a bunch Kingnutin, but I do have a follow up question.
I have a 03 Impala LS 3800 and 58,xxx miles stock with no apparent tranny cooler. I plan to change the tranny fluid and filter this summer with Dexron VI (under your recommendation). My Haynes book says that my tranny fluid copacity is between 7.4 and 10 quarts.
My question is, if I follow your directions (thank you) will I be replacing all of the fluid or just a portion, if just a portion? What percent might that be?
Lucky1 is offline
post #37 of (permalink) Old 01-07-2013 Thread Starter
Quoted: 6 Post(s)
It replaces part of the fluid, 7-7 1/2 quarts is enough for this procedure, 10 quarts is the entire capacity. So you are changing about 75% of the fluid.
post #38 of (permalink) Old 01-09-2013
Lucky1's Avatar
Thanx, I think I'll change both the fluid and filter this summer. And then again at 100K. I am a proactive type, a little effort now can save big $$ later.
Lucky1 is offline
post #39 of (permalink) Old 04-03-2013
jrd0304's Avatar
As always, awesome writeup, did this last weekend with your help. In case anyone runs into a snag with the seal... I ended up getting the seal out pretty easily by gentling pulling down from the upper top lip of the seal with a pair of 90 degree bent bird-beak needle nose pliers.
jrd0304 is offline
post #40 of (permalink) Old 04-03-2013 Thread Starter
Quoted: 6 Post(s)
That seal can be a serious pain, many times I have considered just leaving it, but I know what can happen...
post #41 of (permalink) Old 04-19-2013
johnccc's Avatar
I'm going to change mine out, its over due as I'm nearing 65K already, the dealer recommends to change trans fluid and filter at 50K.
They're charging only $169 to change it, I can get the fluids and filter for about $100, so I'm still thinking about doing it myself, or not.
If I do I will take shots and post them for others to see, as to contribute to your write up, which is very detailed already and easy to follow, even without pictures, good job.
Metallic Cyber Gray 2011 Chevy Impala LT (Standard Fleet Equipment) (automatic)
Includes Stock Remote Starter
Mods:
LOUD Advent PRO9233N Alarm system
iSimple Solutions Gateway & SiriusXM Tuner and Bluetooth - Hidden in dash (Uses Stock Radio)
Window Tint
Chrome Window Pillars (almost done)
Future Mods:
Chrome Door Handles
Foot area LED Strips (Also replace all interior bulbs with LEDs)
Chrome 5 spoke 20" Rims (later on)
johnccc is offline
post #42 of (permalink) Old 06-17-2013
DallaSS 214
TxImpala89's Avatar
I wanted to change the trans filter on mine (128K and i don't know if they ever changed it before) but after seeing some posts, i guess it's best to leave it alone
PROJECT LINDSAY!
TxImpala89 is offline
post #43 of (permalink) Old 06-17-2013
SCOTTYINWV's Avatar
No, change it but don't flush
SCOTTYINWV
SCOTTYINWV is offline
post #44 of (permalink) Old 06-19-2013
Dave_N's Avatar
Quoted: 64 Post(s)
I just had mine done at Mr. Transmission at 70 000 kms. The fluid still looked pretty good, but I figured the car is 7 years old, so it was time for a change.
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline
post #45 of (permalink) Old 06-19-2013 Thread Starter
Quoted: 6 Post(s)
That's about 44k miles, good time to change it anyway.
'00-'01 7th Gen Wheels on '09 8th Gen Rowner Wheels and Tires 4 05-20-2019 07:36 PM
8th gen turn signal/dimmer switch replacement kingnutin DIY How To's & Write Up's 18 10-26-2018 10:41 AM
According to Wikipedia 2000-2005 is 8th Gen, not 7th Gen! Mislabled forums? john5246 Chevy Impala 7th Gen Discussion 5 08-28-2017 01:20 PM
