2000-2005 Receiver and Speaker Installation Sheet - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 01-04-2013
g25racer's Avatar
How to remove rear seat cushion? I cant seem to find the retainers under the seat! I attempted to remove it multiple times during my sub installation to no avail. I ended up just running the 4ga power through the side of the cushion. I need to tear apart the passenger side trim in order to hide the wire the correct way. I dont feel like taking the pillar trim/seatbelt off.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #17 of (permalink) Old 01-04-2013
SCOTTYINWV's Avatar
THIS IS FOR IMPALAS WITHOUT A FOLDING BACK SEAT, BUT REMOVING THE BOTTOM WOULD BE THE SAME...
on the outer edges of the bottom seat cushions stick your hand under and give it a firm tug strait up,pull pretty hard almost like your trying to break it. (I'd say the latches are around 10 inches from the outside edge) get your hand in there as far as possible and pull. the bottom will come out.
then undo the 2 bolts holding the bottom of the back seat in.
after the bolts are out pull strait up on the seat back to release the top hooks.
then all ya gotta do is slide the seat back out from the seat belt.
then you have 4 plastic nuts that hold the package tray cover in place, remove these clips. bow the center of the package tray cover up and it out from underneath the side panels.
now comes the fun of removing the speakers...
push in on the black retaining clip.
grab a screw driver and pry up between the black plastic mounting bracket and the sheet metal tray.(it is glued in very good)
remove the 4 screws holding the speaker to the bracket and swap em out.
reverse steps to re install.
I was never good at writing anything so I done the best I could. HOPE THIS HELPS SOMEONE!!!
SCOTTYINWV
SCOTTYINWV is offline
The Following 2 Users Say Thank You to SCOTTYINWV For This Useful Post:
g25racer (01-04-2013), JerryPH (02-27-2014)
post #18 of (permalink) Old 01-04-2013
Kstaack's Avatar
Im talking about the front ones, I got to the point of the grill is off, getting the speaker out and unplugged it. I bought a speaker wiring harness (Metra 72-4568) but i dont know how to get the pin/wire out of the black adapter part of it... and also get the pin/wire out of the connector that connects inside the door. Any help would be awesome because im having a hell of a time trying to get it out so it will look professionally done, i really dont feel like soldering the wire to the speaker...
Kstaack is offline
post #19 of (permalink) Old 01-04-2013
Kstaack's Avatar
Talking
i figured it out. 2 hours later and ended using a chisel and hammer to bust off the black end to figure out how to get the pin out and you can just use a paper clip and bend the tip 1/4" from the end to about a 30 degree angle and shove it in with the pins FACING you.
Kstaack is offline
post #20 of (permalink) Old 01-04-2013
g25racer's Avatar
Will give it a try tomorrow. I plan on taking all the trim off to route my 4ga wire better. I am also going to take my front seats out to clean the rail system and paint them.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #21 of (permalink) Old 01-05-2013
SCOTTYINWV's Avatar
GOOD LUCK it shouldn't take too long to do. I done mine in about an hour at work.
SCOTTYINWV
post #22 of (permalink) Old 01-06-2013
chadds's Avatar
Does anyone have a working link to the master sheet? Thanks!
chadds is offline
post #23 of (permalink) Old 01-21-2014
Dylanlewis.f's Avatar
Very very useful and helpful info! I already have done the head unit & rear deck speakers.... Wish I would have seen this earlier it would have made my struggle far less difficult. But at least I know now not to try the front door speakers without taking the panel off as I am also right handed!
Dylanlewis.f is offline
post #24 of (permalink) Old 02-21-2014
ahill007ny's Avatar
Hey guys I'm doing the front speakers I know it requires 6.5s...My question is what's the max watt I could use?.I'm still using the factory amp. I also read that I have to cut the wire to the tweeters in order to remove the factory speakers..Will I be able to mend them back again without a problem and use them with the new ones? Thanks
ahill007ny is offline
post #25 of (permalink) Old 02-24-2014
I would always suggest waiting until you're able to replace the head unit and upgrade all the wires as well. The wire upgrade will be a significant improvement, almost a necessity if you want it to be more worth your money. The dash isn't anything difficult to get off, I did mine in 0 degrees (and it still didn't break, though it was a struggle!) [watched it on YouTube, made it far easier to do myself]
The factory head unit can push an avg of 15-50watts per speaker, you can go on the internet and find 400watt (bout 150 rms/nominal) for like 50 bucks (I bout Pyles and theirs doin great)
That's just my two cents! Idk about crimping the old tweeter wires personally but I've heard of many people doing so! Good luck!
The Following User Says Thank You to Dylanlewis.f For This Useful Post:
ahill007ny (03-03-2014)
post #26 of (permalink) Old 02-24-2014
SCOTTYINWV's Avatar
You don't have to cut the tweeter wiring, however you will be severely disappointed with new speakers and factory amp running them. Iirc the factory amp is like 17watt and runs 2ohm speakers. Unless you search for 2ohm speakers, the 4ohm 6.5s you replace them with will be around 8-9 watts each and not sound too great at all.
SCOTTYINWV
The Following User Says Thank You to SCOTTYINWV For This Useful Post:
post #27 of (permalink) Old 03-03-2014
ahill007ny's Avatar
Ok. I replaced all 4 speakers. I have a new head unit as well, i didn't install it yet. I want to relocate the factory radio to the trunk...how do u route the relocate wire? Do i still have to buy the piece to keep the steering controls or does everything remain the same? It's non onstar btw.
post #28 of (permalink) Old 03-03-2014
Quoted: 99 Post(s)
There is a harness that allows you to run the wires to the trunk for the factory radio. I know it's a metra harness, but I don't remember the part number.
It works well, but if you want to keep your steering wheel controls, you'll need the steering wheel control retention interface, which is another $50+
*2001 Impala Ls - 134k
Precision 6262 Turbo, ZZP Z3, CXRacing intercooler, ZZP 3" Cat-back, Muffler delete, Bosch 42.5# Injectors, Bosch fuel pump, CTS-V Brembos, Stainless lines, CM GP springs, Dorman solid sway bar, SPEC-D LED headlights, LED heads and fogs, Quad tails, C5 reverse lights, All LED interior, LED 6 gauge cluster retrofit, LED puddle lights, LED underglow, Debadged, Dipped emblems, Color-matched trim, Kenwood DDX271, Polk Audio dxi6500 components, Polk Audio db690, Hifonics GLX100.4, 2x Polk Audio db1240 in custom box, Hifonics ZRX1800.1D, KMC District, Nitto NT555G2, SS tail covers, SS spoiler, SS Lip, 20% tint, Black mesh grille
*2005 GTO - 72k
LS2/6SPD FOR SALE
*2014 Impala LT Limited - 35k
RYD SLO is offline
ahill007ny (03-05-2014)
post #29 of (permalink) Old 03-04-2014
g25racer's Avatar
Actually it's
Scosche GM06B 2000-Up GM radio T-Harness
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
The Following 2 Users Say Thank You to g25racer For This Useful Post:
ahill007ny (03-05-2014), RYD SLO (03-04-2014)
post #30 of (permalink) Old 03-06-2014
ahill007ny's Avatar
Originally Posted by ryd slo View Post
there is a harness that allows you to run the wires to the trunk for the factory radio. I know it's a metra harness, but i don't remember the part number.
what's the steering controls manufacture is it scosche? Whats the model number?
Car Wireless Bluetooth 3.5mm AUX Receiver Adapter For Audio iPad Phone Speaker RSS Bot Impala Diecast Toys Cars on eBay 0 08-21-2017 08:30 PM
Car Wireless Bluetooth 3.5mm AUX Receiver Adapter For Audio iPad Phone Speaker RSS Bot Impala Diecast Toys Cars on eBay 0 08-16-2017 08:20 PM
Car Wireless Bluetooth 3.5mm AUX Receiver Adapter For Audio iPad Phone Speaker RSS Bot Impala Diecast Toys Cars on eBay 0 07-27-2017 07:50 PM
