7th Gen thermostat easy way - Chevy Impala Forums
post #1 of (permalink) Old 01-22-2019 Thread Starter
nightowl3130's Avatar
Quoted: 9 Post(s)
I've seen lots of post about changing the thermostat, which is a pain to get to. I'll show you an easy way to do this without fighting the exhaust crossover removal and lower housing bolt.. Time=about 1-1.5 hrs. You might get a new TB gasket first. Got mine at O'Rileys for under $2.00 part # 61503 and it's a fel-Pro..
pic1=A pic of the part no and gasket for throttle body
Pic2=you need to disconnect wiring to areas in red. There are a few other things attached to throttle body on top and the cables to throttle and trans.
pic3=Shows the heating hoses attached to unit
pic4=Shows the location of bottom bolt which also holds the bypass tube in place. Also the throttle body heat disconnected.
pic5=View of thermostat housing with throttle body removed
pic6=Shows access to lower housing 13mm bolt. I put a rag under housing as shown in next pic first to catch bolt in case you drop it.
pic7=Here you see the rag in place.
pic8=After loosening you can get to it with fingers.
pic9=Exposing the thermostat (already removed) and where it goes..
NEVER pee in the well, YOU might have to drink from it one day..
Last edited by nightowl3130; 01-23-2019 at 02:36 PM. Reason: Can't find where to put text for pics.
nightowl3130 is offline
post #2 of (permalink) Old 01-25-2019
Davec2008's Avatar
Quoted: 7 Post(s)
Is that a 3.4?
Just picked up a 2008 Impala LT after my 2004 Monte Carlo SS died.
Davec2008 is offline
'00-'01 7th Gen Wheels on '09 8th Gen Rowner Wheels and Tires 4 05-20-2019 07:36 PM
7th Gen Supercharger adapter for 3500 Luml3y Chevy Impala 8th Gen Discussion 1 10-26-2017 12:43 PM
Where is RPO Sticker on Impala (2000-2005) 7th gen? Need paint code john5246 Chevy Impala 7th Gen Discussion 9 09-03-2017 08:29 AM
According to Wikipedia 2000-2005 is 8th Gen, not 7th Gen! Mislabled forums? john5246 Chevy Impala 7th Gen Discussion 5 08-28-2017 01:20 PM
