Leather seat swap on 8th gen how to - Chevy Impala Forums
 2Likes
  • 1 Post By Impala_9c1
post #1 of (permalink) Old 12-02-2018 Thread Starter
Impala_9c1's Avatar
I have tasked myself with swapping my cloth seats for leather ones, however in the process I have had to work with two threads on here which gave me some insight but were very wrong in information, so I am going to give the ultiamte write up for anyone wanting to do this in the future.
1. Pick the right seats.
Front Seats:
If your car is a 2009+, you cannot pull seats from a 2006-2008. This is due to the 2009+ models having in seat airbags. If you do swap with a different model, your service airbag light will come on and annoy you.
If your car is a 2006-2008, you cannot pull seats from a 2009+. This is due to the 2009+ models having in seat airbags. If you do swap with a different model, your service airbag light will come on and annoy you.
Rear Seats:
All rear seats are interchanageable 2006-2012, 2013-2016 (limited), but note that there are two versions: foldable and positioned. The foldable are more sought after as they fold down to allow bigger items to be stored in the trunk. These seats come in 2007-2009, and 2012+ models.
2. Install the seats:
Front seats remove with two bolts near the rear of the seat then you slide the seat backward and up. There are a bund of qquick disconnect wires that you must undo, as well as disconnecting the seat belt from the seat.
Rear seats remove in two pieces, the bottom is only tabbed in and held by two pull tabs under the bottom bench. The top is held on by 4 18MM botls, and one 7MM bolt. onece all are remove the seat slides up and out.
Do the reverse for install.
3. Getting it to work:
If you are ina 2012+ model, it is all plug and play. They BCM should already be programmed for the heated seats as well.
2006-2011 models, you will need to splice your wiring to allow power to the passenge front seat. After splicing you will have to add a switch and run power and ground to switch for the heated seats to work (sorry non LFX models, I don't know why they didnt just have your BCM programmed ).
After that you now have the heated seats, leather, and your ride will look load better!
Wanna race? Pauline is very mean.
Impala_9c1 is offline
post #2 of (permalink) Old 12-25-2018
Clifford the Impala's Avatar
Do you have to splice for the driver seat?
Clifford the Impala is offline
post #3 of (permalink) Old 01-07-2019 Thread Starter
Impala_9c1's Avatar
on 2009+ impalas everything is plug and play. Just swap your 2009+ leather seats in and add the heated seat controller and you're in business.
on 2006-2008 you will need to splice the passenger into the driver side for passenger seat power. heated seats will not work due to BCM programming
post #4 of (permalink) Old 01-07-2019
Vulcan_DI's Avatar
Quoted: 4 Post(s)
Thanks for this! I loathe that my 16' Limited does not have folding rear seats! This is a simple model that I hadn't thought of. Question though: if the passenger seat is completely manual, on the 16, does an electrical connection still exist for the swap?
Vulcan_DI is offline
post #5 of (permalink) Old 01-07-2019
Vulcan_DI's Avatar
Quoted: 4 Post(s)
Correction: "mod"
post #6 of (permalink) Old 02-01-2019 Thread Starter
Impala_9c1's Avatar
Hey sorry for the late reply!
YES, if you have a manual passenger seat, plugging in a powered seat will be plug and play! The new seat will be powered!
Just make sure the powered seat is from a 2009 or newer car because of the airbags.
I think that was one of the best upgrades when doing mine besides the heated seats
post #7 of (permalink) Old 02-02-2019
Quoted: 919 Post(s)
Did they ever make a power passenger seat? I thought all passenger seats were manual?
post #8 of (permalink) Old 02-02-2019
1954 Chevy's Avatar
Quoted: 14 Post(s)
Our '08 LT had a dual power split bench seat w/leather as well heated on both sides. The LTZ models had dual power & heat but with buckets & console only.
1954 Chevy is offline
post #9 of (permalink) Old 02-02-2019 Thread Starter
Impala_9c1's Avatar
So whats interesting is there is a power and non power seat variant in existence. If you find the right LTZ you can find a power seat. It is nice because if you dont have a power seat, the passenger power seat swap is three bolts and plug and play
jtrosky likes this.
post #10 of (permalink) Old 02-03-2019
Fi_bassimpala's Avatar
Quoted: 16 Post(s)
Very informative write up, as I did not know the front seats could not be interchanged from before 2009 and I also did not know that the foldable seats were only made in certain years; however, they were available in 2006 models as I own a 2006 ltz and my rear seats are foldable. I hope your leather swap turned out nice! My impala is the first car Ive had with leather and I personally will not ever get a car with cloth seats again
Fi_bassimpala is offline
post #11 of (permalink) Old 02-03-2019
Quoted: 16 Post(s)
Not sure if only certain years had the option but my 06 ltz has power passager seats
'00-'01 7th Gen Wheels on '09 8th Gen Rowner Wheels and Tires 4 05-20-2019 07:36 PM
2014 2LTZ Driver Side Seat Not Lowering ***Long Post, TL;DR Available*** EYEL1NER Chevy Impala 9th Gen Discussion 3 12-31-2018 03:06 PM
Seat swap sstolt64 Autocare and Maintenance 0 06-30-2018 11:45 AM
FS: New in Box 8th Gen Impala Leather Steering Wheel wchain Private For Sale Classifieds 2 03-23-2018 03:07 PM
Black Leather Car Seat Covers Front Rear Set Synthetic Leather Auto (Fits: Seat) RSS Bot Impala Diecast Toys Cars on eBay 0 08-20-2017 08:40 PM
