does 2004 impala require a chip in key? - Chevy Impala Forums
post #1 of (permalink) Old 05-07-2008
matt12882003
matt12882003's Avatar
Quoted: Post(s)
i just bought 04 impala but only with 1 set of keys does it require a key with a special chip in it or can i just go to like ace hardware and make an extra key
post #2 of (permalink) Old 05-07-2008
jon
jon's Avatar
Quoted: Post(s)
Yes i go to ACE for my car keys..Get two more made..put it where you can see it..if you lose the others , get it copied DO NOT go with only one key
post #3 of (permalink) Old 05-07-2008
michaeljustussvcc
michaeljustussvcc's Avatar
Quoted: Post(s)
potatoe chips?
post #4 of (permalink) Old 05-07-2008
aaroj1
aaroj1's Avatar
Quoted: Post(s)
I dont think it has a chipped key. If the key you have that starts the car doesnt have the chip in it , a regular made key at ace hardware should work. I think GM did away with those type of security systems in the late 90`s.
post #5 of (permalink) Old 05-08-2008
pauly383's Avatar
If its anything like our 2003 , the security feature is in the lock area , and not in the key itself .
There is a piece stationary with the electronics on it , and the piece in the lock cylinder that turns with the key . Pull cylinder out and you can't start the car .
We have a regular key from a hardware store that works fine .
pauly383 is offline
post #6 of (permalink) Old 05-08-2008
02SexyImpala's Avatar
Thumbs up Yes It Has a chip kinda
Your car such as my 02 has something called GM passlock II which reads resistance on the key when it is turned to the crank position. Using a key that has no resistance will not allow the car to start.
02SexyImpala is offline
post #7 of (permalink) Old 05-09-2008
pauly383's Avatar
Take the tumblers out of the ignition , and any piece of metal will start the car . I know ............... damn lock cylinder failed one night , and I DO NOT call the tow truck
Try it , it works !!
pauly383 is offline
post #8 of (permalink) Old 09-28-2019
Donald Tabor's Avatar
I have a similar issue. My 05 i bought a few weeks ago didnt come with the original key. Some sort of hardware store key without a resistor from what i can see. Car started and ran fine up until a few days ago. No it flat out won't start/crank. You start it from the starter and it kills itself after a second or 2. Definitely security system. Am having trouble locating the correct resistance for the original key. Been told by a few people to bypass the system using the correct ohm resistor but obviously i do not know the correct resistance. Any suggestions?
Donald Tabor is offline
Question about the Key fobs on the 9th gen Impala FAWAZ87 Chevy Impala 9th Gen Discussion 15 4 Weeks Ago 01:26 PM
2008 Impala LTZ key stuck in Ignition neustkg Audio, Video, and Electronics 5 02-15-2019 07:59 AM
New original OEM 06 07 08 09 10 11 2012 Chevy HHR / Impala transponder chip key RSS Bot Impala Diecast Toys Cars on eBay 0 08-31-2017 03:50 PM
New original OEM 06 07 08 09 10 11 2012 Chevy HHR / Impala transponder chip key RSS Bot Impala Diecast Toys Cars on eBay 0 08-20-2017 03:30 PM
New original OEM 06 07 08 09 10 11 2012 Chevy HHR / Impala transponder chip key RSS Bot Impala Diecast Toys Cars on eBay 0 07-15-2017 03:10 PM
