fellow 2000 - 2005 Impalas, can you do me a favor - Chevy Impala Forums
 5Likes
  • 1 Post By Nacho
  • 1 Post By Bill58
  • 2 Post By plano-doug
  • 1 Post By Nacho
post #1 of (permalink) Old 10-01-2019 Thread Starter
Nacho's Avatar
Hello 2000 - 2005 Impala owners, on the key ignition switch, there is Off, Accessory, On, Start positions,
1. Can you tell me, if you turn your key from Off position to Accessory position, does it turn on the fuel pump?
2. And then from On position to Accessory position, does it turn on the fuel pump?
I thought only when the key is turn to the On position is when the fuel pump turns on.
But my ignition switch seems to be turning on the fuel pump from the Off position to Accessory position and On position to Accessory position. So in short, seems the Accessory position is turning on the fuel pump also.
Thank You
Nacho is offline
post #2 of (permalink) Old 10-01-2019
Bill58's Avatar
Quoted: 51 Post(s)
'05 ls with 3.8
The fuel pump primes from off to accessory, accessory to on and from on to accessory. My pump seems to be functioning the same as yours. Does seem strange it would prime in accessory.
Bill58 is online now
The Following 2 Users Say Thank You to Bill58 For This Useful Post:
Nacho (10-02-2019)
post #3 of (permalink) Old 10-02-2019 Thread Starter
Nacho's Avatar
Originally Posted by Bill58 View Post
'05 ls with 3.8
Thanks Bill58, yes it does seem strange the accessory position would prime the fuel pump. Other automotive makes i have know to only prime the fuel pump from the ON position. I have an 05 3.4 that is a having a CRANK NO START issue. I thought this would have been the cause of no start.
Bill58 likes this.
Nacho is offline
post #4 of (permalink) Old 10-02-2019
Bill58's Avatar
Quoted: 51 Post(s)
Do you have fuel pressure (key on engine off should be 52-59 psi)?
Do you have spark?
Will it start using starting fluid?
Nacho likes this.
post #5 of (permalink) Old 10-02-2019
Quoted: 378 Post(s)
I too think it's kind of weird to send power to the fuel pump on ACC.
Starting at the pump, the PCM controls it via the fuel pump relay.
Looking farther upstream, using the drawings I have access to, I can't find one focused on the ignition switch, but, from what I pieced together, it works as follows:
START and ON both send +12V to the pink wire which goes to both the PCM and BCM.
START and ON also both send +12V to the dark green wire which also goes to both the PCM and BCM.
START also sends +12V to the yellow wire which goes to the PCM.
ACC and ON both send +12V to the brown wire, which goes to the BCM.
(Keep in mind, these connections are sending signals as much as they are sending power.)
START and ON go to the PCM via 3 different wires, but ACC only goes to the BCM. So, for ACC to cause the fuel pump to run, the BCM would have to signal the PCM over the serial link to turn the fuel pump relay on.
So it takes a very roundabout path, which leaves me shaking my head on this one
Bill58 and Nacho like this.
post #6 of (permalink) Old 10-03-2019 Thread Starter
Nacho's Avatar
Thanks Doug, sounds like whenever the BCM gets power from the ignition switch either through ACC or ON, BCM will signal PCM to prime fuel pump, yeah an unusual design that had me confuse.
Nacho is offline
