2007 Impala SS Service battery charging system light - Chevy Impala Forums
post #1 of (permalink) Old 07-04-2018 Thread Starter
07impalaSS07's Avatar
Exclamation 2007 Impala SS Service battery charging system light
I obtained an 07 Impala SS with a couple of issues. So far all the issues have been fixed except for one. The charging system. At this point I am completely lost and any help would be greatly appreciated. When I got the car the alternator did not charge at all, so i replaced it. It kind of fixed the problem. The battery light would go on and off. Funny thing is, when the battery light would come on, i'd give the car a little bit of gas and it would go away for a couple minutes then return. Also, sitting at a stop light the light would come on then go away on it's own after 5 seconds or so. I replaced the alternator a second time hoping that was my issue. It was not. It still charges at about 13.5 volts. Battery holds a charge just fine. Has no trouble starting at all. Today I replaced battery current sensor, hoping it was that. Again, it was not. I do not know where to go now from here.
07impalaSS07 is offline
post #2 of (permalink) Old 07-04-2018
Quoted: 927 Post(s)
If you've replaced the alternator and battery, the only thing left is the wiring. I'm guessing that you already checked it, but it sure seems like there has to be a wiring issue somewhere.
Sent from my ASUS Chromebook Flip C302 using Tapatalk
post #3 of (permalink) Old 07-05-2018 Thread Starter
I did quickly check wiring for anything obvious. All i found was a red wire hanging out that looks like it use to be a sub wire. I assume wire integrity is good because the battery is being charged.
post #4 of (permalink) Old 09-12-2018
86zboss's Avatar
Make sure everything is properly grounded and no damaged, exposed or corroded wires.
Check the voltage of battery while running and if everything checks out its probably you battery current sensor.
GL
86zboss is offline
Buick Lucerne Super FE4 Struts on Impala SS and other suspension mods. hatzie 8th Gen Suspension 8 06-12-2019 07:19 AM
2006 Impala, battery icon is lit up and display reads Service battery charging system joe77 Chevy Impala Discussion 2 05-08-2019 08:06 AM
1964 Impala SS Parts Lots of little Parts Charles K Private For Sale Classifieds 0 03-21-2019 02:17 PM
2007 Impala SS Trouble Changing Gears Tame Impala Mechanical and Electrical Problems 7 02-21-2019 04:40 PM
6 Year Review of a 143,000 Mile 2008 Chevrolet Impala SS SuperSportNick 2006-2013 Impala Reviews 0 01-27-2019 11:27 AM
