2010 Impala Running Hot - Chevy Impala Forums
post #1 of (permalink) Old 03-30-2018 Thread Starter
thegovernor68's Avatar
So I bought this car brand new and up until a few months ago the temp gauge ran exactly in the middle-all of the time. But now it seems the temp gauge is running up to the next line past half way. It doesn't matter if it is cold out or if I am running down hill. It eventually goes back down to half way, especially if I turn on the heater. I took the car in the other day thinking the thermostat was bad but they ran it through 5 cycles and all they could find was the upper radiator hose was a little loose. Well, its still running what I consider to be hot. I put new Dexcool in a few months ago and the car has about 282,000 miles on it. The radiator is about 2 years old as well. Any ideas on what could be making it run warm like that? They told me the normal operating temp is about 217 degrees and that is what they measured as well. Thanks!
2nd place means you're the 1st loser.
thegovernor68 is offline
post #2 of (permalink) Old 03-30-2018
TeeRev's Avatar
Quoted: 124 Post(s)
So the heater core works like a small radiator, which is why it cools when you have your heat on.
My first instinct is thermostat stuck closed, preventing flow of hot coolant to the radiator. But you say the shop tested it and there was no issue.
Since you say it doesn't matter whether you're running downhill or not, that can most likely rule out your radiator fans not coming on, but I'd check just to be safe.
Moving on, is your water pump okay? Are there any leaks? Did you bleed out the system when you filled the radiator? Air bubbles can get trapped near the water pump, causing it to cavitate and basically be useless. Thus, instead of flowing coolant through your radiator, the coolant becomes static.
217 degrees sounds about right. Was the gauge reading high (i.e., overheating) when they measured it? If it was, it could simply be a gauge or coolant temperature sensor problem.
Hope this points you in the right direction
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
LED headlights / fog lights
Stant locking gas cap
GM molded splash guards
McGard locks
TeeRev is offline
'04 Impala LS running cool goochlove Chevy Impala 7th Gen Discussion 15 01-11-2018 03:02 AM
Engine Hot A/C Off - 2010 Impala conservance 8th Gen Engine Performance 1 11-21-2017 03:24 PM
15 Impala Ltz Daytime Running Lights problem Kmsyr13212 Mechanical and Electrical Problems 5 11-03-2017 09:22 AM
2010 Impala -- Line output converter producing loud signal after key is turned off? Captain McFunk Audio, Video, and Electronics 2 10-07-2017 06:33 AM
2010 Chevy Impala LT/Loud clicking noise Jimarie Chevy Impala 8th Gen Discussion 1 07-16-2017 02:07 PM
