key will not work - Chevy Impala Forums
 10Likes
post #1 of (permalink) Old 11-15-2016 Thread Starter
landon's Avatar
Quoted: 4 Post(s)
Thumbs down key will not work
I lost my extra key to my 2009 chevy impala. I purchased a blank on ebay and had it cut. The key will unlock the door but will not switch on the ignition. It will go into the switch but will not turn. Every thing that I have looked said turn on the ignition after programing.
If you need more info to help me solve this please let me know.
This is what I have tried:
1. Insert an existing programmed working key into the ignition cylinder.
2. Turn ignition to the ON position for 5 seconds, then back to OFF position.
3. Remove the existing key and within 5 seconds insert new key and turn
it to the ON position for 5 seconds.
4. Turn key OFF then back to ON. The key is now programmed.
Start vehicle to test key.
Notice item 3 says turn the ignition on with the new key....that is where I am having a problem. All instructions I have seen has this step.
landon is offline
post #2 of (permalink) Old 11-15-2016
Quoted: 373 Post(s)
To be clear, you still have one key which works? From which the new copy was made?
post #3 of (permalink) Old 11-15-2016 Thread Starter
landon's Avatar
Quoted: 4 Post(s)
Yes I used a working key that came with the car.
landon is offline
post #4 of (permalink) Old 11-16-2016
Quoted: 254 Post(s)
are you sure the key you bought has a chip in it? i went to ace hardware and had a key cut to just open the doors but it didn't have a chip in it.
post #5 of (permalink) Old 11-16-2016
Quoted: 373 Post(s)
I would get a new key cut. I'm thinking you got a bad cut when the last key was made. The door locks use fewer of the teeth on the key, so that's why the key works in the door, but won't turn the ignition. The bad tooth isn't being tested by the door lock.
As for there being a chip in the key, I can't say. But it should turn the ignition cylinder. If the car is expecting a chip and you don't have it, the key should still turn, I think, but the motor won't crank.
I know on the gen7's, there was no chip in the key. But I'm not sure about your gen8.
hatzie and 12 lt like this.
post #6 of (permalink) Old 11-16-2016 Thread Starter
landon's Avatar
Quoted: 4 Post(s)
This is the key I purchased:
New Replacement Car Key Transponder Chip 46 Circle Plus for Impala Silverado
Order status: Paid Paid $5.50 with PAYPAL on Oct 27, 2016 10:57 PDT Estimated delivery: Wed. Nov. 2
landon is offline
post #7 of (permalink) Old 11-18-2016
dtnel's Avatar
Quoted: 13 Post(s)
Have the cut checked by whoever cut it. Any good key cutting shop such as ACE Hardware will recheck it for proper cut.
Sent from my SM-G900V using Tapatalk
12 lt likes this.
dtnel is offline
post #8 of (permalink) Old 11-18-2016
dtnel's Avatar
Quoted: 13 Post(s)
Other thing is check seller feedback of seller on eBay. May be a no good knock off part. Most key places have a deal you can wave your key in front of and it'll tell you if you have a chip key of not. If it turns out the case they sold you the wrong one and don't want to make it right then report it to eBay.
12 lt likes this.
dtnel is offline
post #9 of (permalink) Old 11-18-2016
sonjaab's Avatar
Quoted: 21 Post(s)
A "chipped" RFID key will have a circle with a cross stamped on the shank below the
head.
(note the pic in post 6)
If it doesn't have that stamp/imprint its NOT a "chipped" key !
If the key is NOT turning in the lock then its because it was cut wrong!
sonjaab is offline
post #10 of (permalink) Old 06-14-2019
PatrickCollins's Avatar
Question Different key issue
Greetings, I'm new here. I don't want to hijack the thread, but I have a copied key that will work in the ignition, but not the door lock. This was copied from a key that works in both. Suggestions?
Oh, Mine's a 2011 LT
PatrickCollins is offline
post #11 of (permalink) Old 06-15-2019
Quoted: 373 Post(s)
Try turning the key over and see if that helps. You probably have one tooth cut a tad off that's causing the problem.
Both the ignition cylinder and the door lock only use one side of the key, so it may work in one orientation and not the other, in both the door and the ignition.
The two locks do not necessarily use the same teeth, either. So the bad tooth may only be affecting one lock and not the other, altho I would expect the ignition to fail before the door lock since the ignition uses more of the teeth than the door lock does.
Also, since it gets used more, the ignition may be more worn than the door lock and hence more tolerant of a bad tooth. My 1997 F150 ignition cylinder is so worn, I can just about start it with a screw driver
If none of this helps, try getting another key cut from the original good key, if you still have it.
Always follow the Mechanocratic oath: "First, don't break anything."
post #12 of (permalink) Old 06-17-2019
hatzie's Avatar
Quoted: 157 Post(s)
You don't need to buy circle plus transponder keys online. These aren't sidewinder keys.
Any real old fashioned hardware store that cuts keys will usually have Circle Plus blanks. I believe some of the Borg big box retailers have em. I bought a spare key at Rands hardware in Plymouth. I had to do a security learn but that's not the end of the world.
If you want GM or the Chevy Bowtie or the Pontiac symbol or the Cadillac symbol or the Buick symbol then buy em online.
2009 Impala SS
hatzie is offline
post #13 of (permalink) Old 06-17-2019
Quoted: 373 Post(s)
One other thought on this, my old brain just remembered, on my 2007, I too have dealt with a key that was difficult in the door but worked fine in the ignition. I blamed the door lock, not the key. In this case, I couldn't even get the key into the hole.
So, I shot some graphite into the lock, and then kept working the key in and out, and finally got it in all the way.
In your case, you might try putting some graphite into the lock, slide the key in an out a few times to help distribute the graphite, then try rotating it left and right, maybe wiggling it some as you go. Also, repeat this with the key flipped over 180.
In my case, I attributed the lock problem to disuse, due to the fact that the fob does 99.999% of the unlocking. Yours may be the same case.
post #14 of (permalink) Old 06-17-2019
Quoted: 183 Post(s)
^+1 with Doug! Very common for door locks to seize up due to lack of use. Everyone always uses their fob, power lock/unlock buttons or external keypad instead of the 'ol key-in-the-door-hatch-trunk method. Fwiw, I've had locksmiths tell me to shy away from graphite, liquid or powder, to free up locks. They claim it'll eventually gunk them up and make matters worse. Wd-40 is their go-to for cleaning/unbinding locks.
post #15 of (permalink) Old 06-18-2019
hatzie's Avatar
Quoted: 157 Post(s)
WD-40 to un-bind and rinse the garbage out.
WURTH HHS to lube em so it doesn't happen again.
2009 Impala SS
hatzie is offline
07 LS completely dead with key stuck in ignition- Please Help! kumiko26 Chevy Impala 9th Gen Discussion 1 06-21-2019 08:58 PM
Question on adding new key 2016 LT rockfan4 Chevy Impala 9th Gen Discussion 5 08-31-2018 08:22 AM
2007 Impala LS Key Fob Issues nolanapeters Chevy Impala 8th Gen Discussion 7 06-23-2018 01:55 PM
08 Impala key fob and manual key won't work SoniaGodspell Chevy Impala 8th Gen Discussion 4 12-15-2017 09:29 AM
Need Help! Auction Car, No Key, Now No Start! smriddlert Chevy Impala 7th Gen Discussion 1 10-05-2017 07:29 PM
