A/C blows warm air sometimes? - Chevy Impala Forums
 5Likes
  • 1 Post By luckydriver
  • 1 Post By impaler
  • 2 Post By Bowtie396
A Sonny's Avatar
Hello everyone,
Happy to have joined and come across this forum.
Hoping to get some advice from you all.
I have recently acquired a 2015 Impala LTZ.
The air conditioner works a charm for the most part except when sometimes while driving or even when the car is idle,it starts blowing warm air, almost as if the AC has switched to fan. I suspect it has something to do with the compressor? (I am not confusing this with the Bluetooth call feature that reduces fan speed, but am talking about the actual cooling effect itself.)
Dealer said everything checks out and no issues. Strange.
Another issue is that my front left door speaker has blown and I am looking for the replacement number for the part. (Bose System)
Any info and tips would be much appreciated along with any routine issues and snags to watch out for!
Thank you all.
A Sonny is offline
tjhenry77's Avatar
Quoted: 50 Post(s)
I’d take ur car to a shop and get the ac freon recharges probably low.
As far as the door speaker, hit up a junk yard you’ll probably have some luck in that dept. not sure the part #
I do know it is a 6x9 in the door
Car audio specialist.
tjhenry77 is offline
post #3 of (permalink) Old 1 Week Ago
jayawest's Avatar
Quoted: 7 Post(s)
Originally Posted by A Sonny View Post
Hello everyone,
Thank you all.
My A/C had to be recharged when my air was blowing out hot.
jayawest is offline
luckydriver's Avatar
Quoted: 85 Post(s)
i doubt this is your issue but did you know after over 170k on the car if you dont change your cabin filter you wont get much cold air
ask me how i know.
cant hurt to check it since takes 5 minutes. i'm actually too cold now and carry an electric blanket to plug into the rear receptacle........
luckydriver is offline
post #5 of (permalink) Old 1 Week Ago
Quoted: 85 Post(s)
also the car does have strange fan ups and downs. dont ever use AUTO if you dont like that kind of thing. but even yesterday just driving down the road the fan noise changed on me. i just accept tis a strange car .
wait till you find out how the trans shifts. thats fun! thankfully the new one i got at 140K resolved the issues
post #6 of (permalink) Old 1 Week Ago
Quoted: 193 Post(s)
The 2015 Impala does not use Freon as a refrigerant.
The OP stated the a/c “works a charm” - so the system could not be low on refrigerant if it works fine most of the time. It is possible the system is overcharged, causing high refrigerant pressures and the compressor to be turned off intermittently as a result.
post #7 of (permalink) Old 1 Week Ago
Quoted: 193 Post(s)
Here is an excellent link, with pictures, on how to change the cab air filter on the 9th generation Impala: https://www.impalaforums.com/diy-how...placement.html
post #8 of (permalink) Old 6 Days Ago
impaler's Avatar
Quoted: 216 Post(s)
One thing I can add about the filter change is you might want to slide a piece of paper or thin cardboard underneath the filter before removing it. That way if any junk falls off the filter when removing it, it won't fall down into the blower fan which can and will cause noise.
I recently changed the filter on my 15 Sierra and I didn't use anything under the filter, just pulled it out. When I was done I turned the truck on and the ac on and was greeted with the sound of an airplane taking off. It was a stupid single leaf that had fell off the filter. Luckily the shop vac was able to blow it back out.
I made sure I used a piece of cardboard for the Impala when I changed it's cabin filter next.
2015 2LT
Convenience pkg
Advanced Safety pkg
Sunroof
Suntek CXP 50/35 tint
impaler is online now
post #9 of (permalink) Old 6 Days Ago
Quoted: 193 Post(s)
Excellent advice.
I also found that when replacing the HVAC air filter on my 2014 Impala 2LTZ, the filter is a tight-fit.
To make the installation of the filter easier, I use both thumbs to push the left and right edge of the filter into the housing. If you push in the middle of the edge of the filter (with one finger or thumb), the end buckles somewhat and causes the filter to bind.
post #10 of (permalink) Old 6 Days Ago
mdubyk's Avatar
Quoted: 17 Post(s)
"The 2015 Impala does not use Freon as a refrigerant."
R-134a is presently the only EPA approved refrigerant for automotive use.*If R-134a is not Freon, what is it?
mdubyk is offline
post #11 of (permalink) Old 6 Days Ago
Bowtie396's Avatar
Freon is a trade name for the refrigerants R-12, R-13B1, R-22, R-410A, R-502, and R-503
The Trade Names for R-134a are, Forane 134a, Genetron 134a, Florasol 134a, Suva 134a, or HFC-134a,, the names just never caught on with the public.
R-134A is not the only EPA approved refrigerant, there is also the new R-1234yf, Trade Name Opteon YF by Chemours and as Solstice YF by Honeywell. This is already being used in newer cars, R134A is slowly being phased out just as R-12 was.
Bowtie396 is offline
The Following User Says Thank You to Bowtie396 For This Useful Post:
1999 White C5 Coupe (6 Days Ago)
post #12 of (permalink) Old 6 Days Ago
Quoted: 193 Post(s)
I attempted to add a “Thanks” to your post, but although I was logged-in, the site issued a warning that I do not have permission to access the page.
Strange - this site is still being poorly managed. Edit: After I added this I post, the “Thank you” appeared under your post.
So - Thank you.
