2014 Impala LTZ - Chevy Impala Forums
 2Likes
post #1 of (permalink) Old 07-09-2019 Thread Starter
Ltzimpala14's Avatar
2014 Impala LTZ
Hello, I recently purchased a 2014 Impala LTZ. I read about the leaky trunk and checked mine and sure enough I’m a winner. I dried it out all the way and I have ran water on the tail lights and no water gets in, also washed the car and still dry. Are there drains in the trunk that may be clogged or any other place I can look? Also my mirrors do not work at all...nothing. I have checked all fuses and all are good. Any suggestions what I should do next? Does anyone’s front end smoke after washing it? Is there a good place to look for diagrams like the sunroof, how to remove and replace the paper backing on the moon roof shade etc. things like that, Clogged moon roof drain? Been searching for answers and these have piled up on me but Any suggestions are very much appreciated Thank you
Ltzimpala14 is offline
post #2 of (permalink) Old 07-09-2019
jmaotto's Avatar
I also have a 2014 LTZ. I drilled a 5/16 hole in the low point under the spare tire. I moved my jack and put it in the foam storage area behind the tire.
jmaotto is offline
post #3 of (permalink) Old 07-09-2019 Thread Starter
Thanks That should would help. I just remembered when I noticed the water I felt around way in the back against the seats and I believe somewhere back there is where it’s coming from. I’m still not sure what that could be though?
post #4 of (permalink) Old 07-09-2019
USN24's Avatar
Quoted: 34 Post(s)
So sorry this happening to your Impala. Have not found any water in my 2014 LTZ and certainly hope it stays that way but further information would be good just in case!!!
Ed
USN24 is offline
post #5 of (permalink) Old 07-09-2019
Quoted: 211 Post(s)
Originally Posted by Ltzimpala14 View Post
Hello, I recently purchased a 2014 Impala LTZ. I read about the leaky trunk and checked mine and sure enough Iím a winner. I dried it out all the way and I have ran water on the tail lights and no water gets in, also washed the car and still dry. Are there drains in the trunk that may be clogged or any other place I can look? Also my mirrors do not work at all...nothing. I have checked all fuses and all are good. Any suggestions what I should do next? Does anyoneís front end smoke after washing it? Is there a good place to look for diagrams like the sunroof, how to remove and replace the paper backing on the moon roof shade etc. things like that, Clogged moon roof drain? Been searching for answers and these have piled up on me but Any suggestions are very much appreciated Thank you
There was a TSB regarding the steam that comes from the front of the car, when it is warmed-up and then washed (or taken through a car wash). The TSB involved removing some front-end stuff and adding a baffle and weatherstripping, to prevent cool water from spilling onto the radiator and causing steam (not smoke). It was NOT a recall or campaign, and would only be performed under the warranty if the owner complained.
There was also a TSB regarding wear on the sunroof shade, which involved replacing it (again - no recall, just instructions on how to repair it). Here is a link for the sunshade / sunroof TSB; https://static.nhtsa.gov/odi/tsbs/20...70905-9133.pdf
I would research the tail light gasket issue (many posts about it here) and replace the tail light gaskets with the updated ones. The old ones WILL leak again. Here is a link regarding the tail light gaskets, with color pictures: https://static.nhtsa.gov/odi/tsbs/20...92869-0335.pdf
Note that part of each side of the rear bumper fascia must be removed to replace the tail light gaskets, but it is an easy repair for anyone with basic mechanical skills.
I own a 2014 Impala 2LTZ, purchased new.
plano-doug and USN24 like this.
post #6 of (permalink) Old 07-09-2019
wiz-car's Avatar
Quoted: 9 Post(s)
I've seen non-Impala's that have had the trunk seal damaged or pulled out of position by presumably heavy items removed from the trunk. Just wanted to mention the common issues I've seen besides the TSB.
wiz-car is offline
post #7 of (permalink) Old 07-09-2019 Thread Starter
Wow! You guys are Awesome! Those are a huge help thank you very much. The sun shade job seems a little intimidating but maybe getting into might help. I am lost as to where to find any of these help guides for it. Is there a site that has them for different parts of the car?
post #8 of (permalink) Old 07-09-2019 Thread Starter
Oh and any ideas for where to go next with the mirrors? All the fuses are good checked those they just don’t move at all
post #9 of (permalink) Old 07-11-2019
1954 Chevy's Avatar
Quoted: 18 Post(s)
Maybe try removing the mirror or door panel to see if you're getting voltage to it when you try adjusting it. Also make sure the wiring harness is plugged in.
1954 Chevy is offline
post #10 of (permalink) Old 07-11-2019
Quoted: 211 Post(s)
Oh and any ideas for where to go next with the mirrors? All the fuses are good checked those they just donít move at all
Since neither mirror moves, I would suspect a defective switch.
The mirrors on the LTZ model are also electrically heated (via the rear defrost switch). Do you live where there is dew or high humidity overnight, where you could leave it outside and see if the heated portion of the glass functions (to remove dew or moisture)? If so, Iíd really suspect the mirror switch.
post #11 of (permalink) Old 07-14-2019 Thread Starter
This is really great stuff guys! I really do greatly appreciate all the information. I’m sorry it took a little bit to get back on just been heading to my next job. It may be a couple months before I get a chance to get back home and try all this but I can’t wait. There is a lot of great stuff on here. Have you guys heard of or tried doing a tune on the newer Impala’s? (2014 or newer) Before I got on this site I was home for a couple days and it’s probably been almost 3 months that I hadn’t started it. It had a rough start kind of shaky and the engine light was blinking on and off for a min or 2 minutes. After that it drove pretty good. But since I’ve bought this Impala I’ve always felt it has a loss of power somewhere just can’t figure out what to do. I know these cars have power, I rented a newer premier from enterprise and it drove really well. I’m wondering if my Impala is needing a tune? Is a tune a tune up? It has just under 49k miles on it. It did have a crack in the air duct tube i didn’t see it right away, so not sure how long it was like that but I’m wondering if a lot of dirt may have got in the system? Just a thought
