2018 Impala LT Wiring - Chevy Impala Forums
 2Likes
  • 1 Post By 04Imp38
  • 1 Post By plano-doug
post #1 of (permalink) Old 05-23-2019 Thread Starter
CtCarGuy22@!'s Avatar
I need to connect a trailer plug but cannot figure which wire is which? Anyone have a diagram?Thanks
post #2 of (permalink) Old 05-23-2019
04Imp38's Avatar
Quoted: 241 Post(s)
Canít help you with a wiring diagram, but try etrailer.com, they may have a plug and play harness for it. I know they do for my 04.
~Joe~
04 Impala LS
Engine: ZZP PCM, ZZP Downpipe, Xcelerator Resonator, Dual Xcelerator Mufflers, 4" Stainless tips, 180į t-stat, Shorter Dogbones, Mount Spacers, Optima Red Top Battery
Interior:
04Imp38 is offline
post #3 of (permalink) Old 05-23-2019 Thread Starter
I wish there was a plug but I have not seen one.
post #4 of (permalink) Old 05-23-2019
Quoted: 380 Post(s)
Per 04Imp38's input, I went to the etrailer.com site. They show several options for wiring harnesses.
https://www.etrailer.com/t1-2018_Chevrolet_Impala.htm
This one appears to plug into existing connectors:
https://www.etrailer.com/Custom-Fit-...leID=201816739
This one also appears to plug into existing connectors _and_ it uses its own power for the trailer lights so it doesn't load the existing tail light circuits. Sometimes the added loads can cause issues with the vehicle's lights such as rapid flashing.
https://www.etrailer.com/Custom-Fit-...leID=201817725
I couldn't find any schematics for 2018 Impalas. The newest drawings I found were for 2015. But they should be the same. Also, any instructions from etrailer.com will specify the wires to connect to.
For now, here's what I found for 2015:
right turn/brake
- brown/green
left turn/brake
- yel/blu
right park
- gray/brown
left park
- violet/gray
gnd
- black
You will note there are two separate running (park) lights wires - one for left, one for right. With typical trailer wiring you would have to pick one of these to connect to the trailer for _both_ its running lights, which (again) may possibly add enough load to cause some issues.
If the car has incandescent bulbs, and the trailer does, too, you may see rapid flashing. OTOH, if the car has incandescent bulbs, and the trailer has LEDs, it probably won't cause any problems.
If you use a unit that supplies its own power (as linked above) then that should avoid any rapid flashing issues.
post #5 of (permalink) Old 05-25-2019 Thread Starter
I will check my wires. Along that line, how do you remove the trunk panel on the left side? I pulled out the buttons but I can barely get my hands in to feel for the bulb and cannot see all the wires. That panel is stiff!
2018 Chevrolet Impala LT RSS Bot eBay Cars For Sale: Impala 0 02-03-2019 11:20 AM
2018 Chevrolet Impala 4dr Sedan LT w/1LT RSS Bot eBay Cars For Sale: Impala 0 12-05-2018 10:50 AM
2018 Chevrolet Impala LT RSS Bot eBay Cars For Sale: Impala 0 05-01-2018 02:20 PM
2018 Chevrolet Impala LT RSS Bot eBay Cars For Sale: Impala 0 09-02-2017 02:10 PM
2018 Chevrolet Impala 4dr Sedan LT w/1LT RSS Bot eBay Cars For Sale: Impala 0 08-30-2017 12:20 PM
