Ac not blowing cold - Page 3 - Chevy Impala Forums
 12Likes
post #31 of (permalink) Old 06-04-2019
Quoted: 232 Post(s)
Would definitely take Doug's advice and take a look through the glove box and see if you can get to it. No way I would pay a dealer for a job like this.
No idea how similar the glovebox and dash are to the 8th gens and how tight it is to get to the actuators. I have had to replace one actuator in our 2012. I could see 2 of the other actuators, luckily the one I had to replace was the easiest one to get to, but I am sure I could get to the other 2 if I have to. It is tight, especially for someone with larger than average hands, but in our 8th gen(2012) I did not see where anything had to be removed.
post #32 of (permalink) Old 06-04-2019 Thread Starter
Pete Christ's Avatar
Quoted: 13 Post(s)
It blew out normal most of the drive this morning then went to itís blowing but not blowing mode! Car got warm so I turned fan up and temp down and heard fan spinning faster but no air coming out. Need to dig into that actuator.
Pete Christ is offline
post #33 of (permalink) Old 06-04-2019 Thread Starter
Quoted: 13 Post(s)
Ac not blowing cold
I see a few actuators listed. I am assuming they are on passenger side of car #15 & 16
post #34 of (permalink) Old 06-04-2019
Quoted: 354 Post(s)
Originally Posted by Pete Christ View Post
<snip pic>
Note there are two number 15's, one each side. Those are the hot/cold blend actuators.
Number 16 is the vent selector, the one you want, and it's above 15 on the right.
Also note number 14. I believe that is the recirc actuator. On the gen8's, it's the same part as number 15. Not sure about the gen9 cars. It's behind the glove box on gen8's, and appears to be there in the gen9 pic.
sheila and 12 lt like this.
plano-doug is online now
post #35 of (permalink) Old 06-05-2019 Thread Starter
Quoted: 13 Post(s)
So today the compressor must not be kicking on because the temp coming out is the same on low as on 70. Ugh so tired of this crap!
post #36 of (permalink) Old 06-05-2019 Thread Starter
Quoted: 13 Post(s)
Rolled the windows down and the compressor kicked on and cold air now
post #37 of (permalink) Old 06-07-2019
sidemouse's Avatar
Quoted: 14 Post(s)
K will remember that, but still need to figure out why it’s not always cold even when turned to lowest setting!
Well, maybe your a/c wasn't on...
I just found out this little GM hinky behavior on my Sierra 1500, haven't really checked the pala but I'm assuming they work the same...
I mean the dashboards are almost identical, and I haven't found any difference in the climate control functions between the two.
So here's the deal:
If I turn the system to RECIRCULATE the A/C comes ON regardless (although I believe I can turn it off but must do so manually and it may go to fresh air if I do?).
But if I turn it to fresh air IF I didn't have teh A/C on before it may actually be what turns it off...
So there's some kind of default behavior going on in there, between fresh air and recirculate.
Recirculate = Automatic A/C ON
Fresh Air = Turns it off if it was off before going to recirculate (I believe).
With fresh air mode:
I have to push the round blower fan speed button IN until that orange light comes on, shouldn't take much but if that little LED-like orange blip isn't lit then the A/C is off ...
If the A/C was ON before switching to recirc then it should still be ON when I come back to fresh air...
But if it wasn't ON then recirc will force it ON but coming back to fresh air turns it OFF.
Found that out the other day, I wondered same as you why is it blowing hot air?
sidemouse is offline
2015 impala LS blowing cold air help please! dlowe1415 Chevy Impala 9th Gen Discussion 4 01-05-2019 06:12 AM
So AC Problems - when it is needed most RShea Chevy Impala 8th Gen Discussion 0 09-14-2018 11:23 AM
AC blowing warm air dcooper323 Chevy Impala 8th Gen Discussion 21 12-08-2017 03:55 PM
A/C sometimes does not blow cold LGarcia Chevy Impala 7th Gen Discussion 3 10-02-2017 08:48 AM
AC not too cold rob1437ert Chevy Impala 8th Gen Discussion 5 07-24-2017 04:35 PM
