ok to use wrong lug nuts? - Chevy Impala Forums
 3Likes
  • 1 Post By Joes74challenger
  • 2 Post By hatzie
post #1 of (permalink) Old 03-31-2019 Thread Starter
luckydriver's Avatar
Quoted: 85 Post(s)
the guy at napa let me try one on before i bought them. but only when i got home did i discover its not 7/8 and id have to carry my 4 way wrench in the car. is it safe to use a smaller lug like this? 14 x 1.5 is whats on the invoice
luckydriver is offline
post #2 of (permalink) Old 03-31-2019
Quoted: 232 Post(s)
So long as the nut has enough lip to secure the rim, they should be fine, the size of the socket to tighten them is not really significant so long as you and whoever else takes them off knows it is not the standard. Assuming the thread was ok. Would be sure to torque them down good and while I usually don't use a torque wrench on my lugs I probably would in this case and recheck them a few days after running them.
post #3 of (permalink) Old 04-01-2019 Thread Starter
Quoted: 85 Post(s)
i would hope any mechanic would realize its different and not strip them. i have an impact wrench with 100 torque stick i use when i rotate myself and complete set of sockets so would just have to change it out when i do stuff on the rear. may as well put all 10 on the 2 fronts. unsure id wanna spend another 30 bucks to put these on the rear though. unless the old ones expand too. the lip looked good to me but maybe someday ill put one on and post the pic
i guess i could also see online if theres a 7/8 solid one as well. unsure napa would take old back after a month though.
post #4 of (permalink) Old 04-01-2019
Quoted: 251 Post(s)
the concern i'd have is if your car ended up at a shop the "mechanic" (i used quotes because that term seems to have a loose meaning depending no the shop you're at) working on your car wouldn't notice two sets of different lug nuts and used the wrong socket on the fronts vs rear. if they're all the same size then it takes the guess work out of it.
also as long as the lug nuts have a good amount of shoulder holding the wheel on you should be ok i'd think. once you get one one and torqued down i'd probably do a drive around and check for movement during your test drive.
12 lt likes this.
Joes74challenger is offline
post #5 of (permalink) Old 04-01-2019
Quoted: 353 Post(s)
14x1.5 sounds like the stud diameter and thread pitch (in mm) and not the wrench size. If the new nut screws on without binding and has the proper cone shape on the end, it should work just fine.
That said, maybe just use it as a temporary fix and keep looking around for an exact match. Maybe take off a stock nut and go to the salvage yard to get one that matches, or go to the dealer.
The point is, use the new one for now, but eventually swap it out for one that matches exactly. That way you don't have to worry about some guy at the tire store putting an impact on the new one and rounding it off. Or you doing it accidentally.
post #6 of (permalink) Old 04-02-2019 Thread Starter
Quoted: 85 Post(s)
why would i want to buy the original lugs only to repeat this issue again? i thought the idea of buying solid ones would resolve this issue given i was told the originals expand when water gets in them . which i truly never knew was a thing.
post #7 of (permalink) Old 04-02-2019
Quoted: 232 Post(s)
Think they would be fine, like Joe mentions just match them all up so as to not confuse the master mechanics at the shops.
post #8 of (permalink) Old 04-02-2019
hatzie's Avatar
Quoted: 149 Post(s)
Supposedly the Epsilon body Impala uses popup head acorn lugs nuts with 14mm x 1.5mm threads and a 22mm hex.
22mm is 0.8661" and 7/8" is 0.8750". That's a difference of 0.0089".
That doesn't sound like much til one gets stuck hard... put enough force on the wrench with a slightly too big socket and you could crack even a good socket and round off the corners of the hex. 12point sockets are really bad about this. Even tho you can likely get away with using a 6-point 7/8" socket I would not recommend it. The additional space puts stress on the socket and the nut.
The thread diameter and pitch match. As long as the conical face mates with the wheel properly they will hold the wheels on the car.
You didn't say if you got all 20 lugs or just a few. Personally I don't like having two different "socket size" lug nuts on my vehicles. If you don't have all 20 I'd go back and buy enough to make up a full set. And for goodness sakes find out what size the hex is on those new lug nuts and buy a Metric 6-point socket that fits them properly.
2009 Impala SS
hatzie is offline
post #9 of (permalink) Old 3 Weeks Ago Thread Starter
Quoted: 85 Post(s)
since i rotated my tires i compared new and old (if you recall i actually did physically try one in the NAPA lot to make sure it screwed on but i didnt analyze the dimension)
since they look so different im thinking i hope napa takes them back
post #10 of (permalink) Old 3 Weeks Ago
hatzie's Avatar
Quoted: 149 Post(s)
Since they look so different I'm thinking i hope NAPA takes them back
The taper doesn't look that different in the pictures. That's the part that actually holds the wheel on.
As long as the taper on the new lugs covers the area of the cone that the old lugs hit you're good to go.
The NAPA lug is longer... Too short is bad. Longer is just fine. The length of the acorn is non critical as long as there's enough room for the wheel stud inside the acorn with the lug nut bottomed against the wheel lug taper seat.
Again... I'd make sure all 20 lugs are one or the other. I wouldn't mix em.
2009 Impala SS
hatzie is offline
(2) Lug Nuts and (1) Stud jonathanafox Wheels and Tires 3 04-18-2019 07:58 AM
20pc Chrome Bulge Acorn Lug Nuts M12x1.5 Chrome Lug Nuts RSS Bot Impala Diecast Toys Cars on eBay 0 08-20-2018 07:30 PM
9594683 Lug Nuts 20-Pack New OEM GM Cruze Impala Sonic Malibu w/External Threads RSS Bot Impala Diecast Toys Cars on eBay 0 05-31-2018 09:30 AM
20pc Chrome Bulge Acorn Lug Nuts M12x1.5 Chrome Lug Nuts RSS Bot Impala Diecast Toys Cars on eBay 0 01-19-2018 09:51 PM
Set of 20 lug nuts 12x1.5 Chrome Acorn Bulge m12x1.5 thread Steel lug nut RSS Bot Impala Diecast Toys Cars on eBay 0 11-22-2017 05:50 AM
