Tail/Brake Light Question - Chevy Impala Forums
  • 1 Post By 37865835235
post #1 of (permalink) Old 03-24-2019 Thread Starter
jcombs65's Avatar
OK, I replaced the bulbs with LED's I used
JDM ASTAR 1260 Lumens 7440 7441 7443 7444 Red Brake LED Bulbs with these
HUIQIAODS 7440 T20 W21W 50W 6Ohm LED Light Load Resistor Fixed LED Headlight Bulb Fog Light Fast Super Flash Turn Signal Flashing Light Error Code Canbus Resistor Decoder 2PCS
But they wont light up as tail lights, I tried flipping the bulbs and putting and old bulb in, and then they will come one once then I shut them off and turn them back on and they only work as brake lights,, I know I am not crazy, the outside lights should be on as a tail light and then get brighter as a brake light, right??.. are the bulbs that I have not the right bulbs?? description says for turn signal, brake and tail light, brake light and turn signals work but not tail light,, any suggestions??
Thanks,,
jcombs65 is offline
post #2 of (permalink) Old 03-24-2019
37865835235's Avatar
Quoted: 18 Post(s)
Did you install the resistors correctly? You need to tap into the red and thin black wires.
ICUBB likes this.
37865835235 is offline
post #3 of (permalink) Old 03-25-2019 Thread Starter
jcombs65's Avatar
they were the plug n play type. plugs into the old socket.. I did not try to rotate the resistor plugs only the bulbs. I will try that next..
jcombs65 is offline
post #4 of (permalink) Old 03-25-2019
ICUBB's Avatar
Quoted: 108 Post(s)
If rotating the plugs on the pigtail does not work it is also possible that the pig tails are the improper size as some manufacturers consider 7440 and 7443 the same even though they are not.
Just a resident noob.
ICUBB is offline
post #5 of (permalink) Old 03-26-2019 Thread Starter
jcombs65's Avatar
Wife had the car so I was not able to rotate them,, and I was thinking the resistor only has 2 wires but the original plug has 3 1 for turn 1 for brake and the ground. I am assuming I need one for the 7443? maybe I will just pull these and just add a jumper type resistor. I believe it goes on the yellow and black wire..sound right.. I appreciate the help. didnt know changing a light bulb could be so complicated ..
jcombs65 is offline
2007 Impala SS Service battery charging system light 07impalaSS07 Chevy Impala Discussion 3 09-12-2018 04:36 AM
License Plate Light Connectors/Extenders? (Electrical) j00f00999 Chevy Impala 8th Gen Discussion 0 01-28-2018 12:18 PM
Problem with left rear signal light brake light tommydavis1966 Chevy Impala Discussion 1 09-14-2017 08:37 AM
Third Brake light wont work scatgo Mechanical and Electrical Problems 2 09-12-2017 08:04 PM
2Pack LED Light Bar Slide Mount Base Bracket for Curved LED Light Bar work light RSS Bot Impala Diecast Toys Cars on eBay 0 07-26-2017 02:40 PM
