Need help, I'm baffled - Chevy Impala Forums
  • 1 Post By sheila
post #1 of (permalink) Old 03-21-2019 Thread Starter
Corbo's Avatar
The background: I bought the car about a year ago. It had bad hubs so I replaced them and the rotors.
A few days ago I noticed a horrible grinding sound while driving and noticed the rotor was being eaten up where the pad/bracket it. So I change the pads and rotors again. The pads that I replaced didn't look worn.
Needless to say I back out of the garage last night and am experiencing the same issue.
When I pulled it back and put it on the jack I could put the car in drive and get no grinding noise. But when it's back on the ground it starts up again.
Any thoughts or prayers are appreciated lol but for real I need HELP.
Thanks in advance
Corbo is offline
post #2 of (permalink) Old 03-21-2019
Quoted: 228 Post(s)
Hubs on these cars are prone to failure, especially those that are not oem quality. If you hit any potholes or used a lower grade assembly it or they definitely could be worn again. With the grinding noise on the ground, sounds like it is putting just enough pressure on the hub to cause the rotor to have contact with the pads.
Next time you get the wheel up with the car on a jack and secured safely, rock the wheel and feel for any give. Be sure not to rock it side to side, but instead from top and bottom of the tire. To me it is easier to check the hubs with the tire off the car and feeling for any give by grasping the rotor.
12 lt is online now
post #3 of (permalink) Old 03-21-2019 Thread Starter
Corbo's Avatar
Okay I just did that I got rocking across the horizontal axis, so from top to bottom.
I also have some play left to right?
Thanks for your reply
Corbo is offline
post #4 of (permalink) Old 03-21-2019
Quoted: 157 Post(s)
Also, make sure the dust shield is not bent and rubbing the back of the rotor.
Joes74challenger likes this.
post #5 of (permalink) Old 03-21-2019
Quoted: 228 Post(s)
Left to right play may be in the ball joints or steering. Up and down play would be in the hub bearings indicating a bad bearing. Just be careful not to have your hand in a position under the wheel unless you have the car very secure.
12 lt is online now
