2014 LTZ squeaky steering - Chevy Impala Forums
 5Likes
  • 2 Post By jtrosky
  • 3 Post By Stano516
post #1 of (permalink) Old 01-04-2019 Thread Starter
JaelenK's Avatar
Quoted: 26 Post(s)
I am experiencing squeaky steering and found this bulletin
https://gm.oemdtc.com/6707/pi0659e-g...uick-chevrolet
I was hoping someone had some more info on this, it would be much appreciated. Thanks!
JaelenK is offline
post #2 of (permalink) Old 01-07-2019
Stano516's Avatar
I'm having this issue with my 2014 LT. It happens only in the cold weather and is a very loud squeaking noise when turning the wheel both ways. Brought it in 2 different times and they're never able to reproduce the issue. I will be bringing the vehicle in a third time very soon since it's cold out and leave it overnight. It should squeak real loud the following morning when starting the car.
I didn't know there was a bulletin for this issue; I will be bringing it with me. Thanks for the info!
Any updates regarding the issue with your car?
Stano516 is offline
post #3 of (permalink) Old 01-07-2019 Thread Starter
JaelenK's Avatar
Quoted: 26 Post(s)
I do not have any additional info, i was hoping someone would chime in, like Doug. Very knowledgeable. Mine squeaks when cranking to the right, and as you mentioned it's only when my vehicle is cold. When it warms up it goes away.
JaelenK is offline
post #4 of (permalink) Old 01-08-2019
Keller's Avatar
Wow, same problem with my 2016 Impala LTZ. Thanks for posting this!
Keller is offline
post #5 of (permalink) Old 01-08-2019
Quoted: 299 Post(s)
I've worked on both ends of the steering column - I've disconnected it at the rack, and pulled the wheel off at the other end. Other than installing a blinker switch, I haven't really gotten very far into one.
That said, if I was chasing a squeak, I'd try to get under there when it's doing it, and see if the source location can be pinpointed. After that, it's either a matter of applying lube, or slightly repositioning that object that's rubbing.
I've actually encountered some squeaking before, but it never bothered me enough to pursue it
Anyway, the key is getting your head down there to pinpoint the spot. And that means sliding the seat all the way back and crawling under the dash. It's a pain, and you need to be limber
BTW, thanks for the compliment
post #6 of (permalink) Old 01-08-2019
Quoted: 299 Post(s)
BTW, there are some really sharp folks who post here from time to time who know way more about Chevys than I do. And they have also been very helpful to me as well.
When they post, I usually hit like, and then bow in their general direction
post #7 of (permalink) Old 01-08-2019 Thread Starter
JaelenK's Avatar
Quoted: 26 Post(s)
When they post, I usually hit like, and then bow in their general direction [IMG class=inlineimg]/images/ImpalaForums_toucan/smilies/tango_face_smile.png[/IMG]
Ill look into my car when i get time and update the thread for anyone else curious. It seems to be loudest just above the airbox(passenger side). Thanks Doug, the input is very much appreciated. You just seem to be the most active here giving input on multiple threads that seem to be very insightful. Ill update sometime when i get to it!
JaelenK is offline
post #8 of (permalink) Old 01-08-2019
Quoted: 299 Post(s)
You hear the noise when you turn the wheel, but it's not coming from the steering column? I missed that.
You think it's coming from outside the passenger compartment? I'm wondering if it's something in the rack or inner tie rods.
Does this car have electric power steering? If so, there's a motor on the rack that could be a factor in the noise.
If the noise is in the engine compartment, identifying it will be a bit tougher, as in maybe needing to be under the car when it's squeaking. But you can start with opening the hood and listening near the firewall for the squeak.
post #9 of (permalink) Old 01-08-2019
Quoted: 893 Post(s)
Yes, Doug is definitely one of our most valuable members. I hope he keeps an Impala for a long time to come! :-)
post #10 of (permalink) Old 01-08-2019 Thread Starter
JaelenK's Avatar
Quoted: 26 Post(s)
Here is a picture to better explain. When i have someone crank the wheel to the right this seems to be where i hear the most noise from outside the vehicle, yet i can still hear it inside turning the wheel myself. The sound is more of like a stretching rubber sound if that helps narrow a bit. And yes it is electronic power steering. It is a 2014 2ltz. Thanks!
JaelenK is offline
post #11 of (permalink) Old 01-08-2019 Thread Starter
JaelenK's Avatar
Quoted: 26 Post(s)
Certainly very, very helpful information. This is my very first car so I'm still learning about it!
JaelenK is offline
post #12 of (permalink) Old 01-08-2019
Quoted: 299 Post(s)
Here is a picture to better explain. When i have someone crank the wheel to the right this seems to be where i hear the most noise from outside the vehicle, yet i can still hear it inside turning the wheel myself. And yes it is electronic power steering. It is a 2014 2ltz. Thanks!
If it's coming from where your finger is resting, that's the upper strut mount. It has a bearing in it that allows the strut to turn smoothly with the steering.
How many miles do you have on the car?
You might can lube it. but even that may require removing the strut from the car - I'm not sure.
The strut mount may need replacing, or at least the bearing in it. That requires removing the strut and partially disassembling it.
I poked around on Rockauto. They have pretty slim pickings for front strut mounts for this car. If you order one, be sure it includes the bearing. I suggest looking around several auto parts websites to see what's out there. In doing so, from the various pics that come up, you'll get a pretty good idea of what all is in the strut stack.
post #13 of (permalink) Old 01-08-2019 Thread Starter
JaelenK's Avatar
Quoted: 26 Post(s)
Sounds too sophisticated to me lol. I'll see what the dealership will get into it for. My car now has about 64k on it and my powertrain warranty expires in a couple weeks, no bumper to bumper 😕
JaelenK is offline
post #14 of (permalink) Old 03-14-2019
Stano516's Avatar
Interesting that Doug says the strut mount has a bearing which moves with the steering. My 14 Impala 2LT is currently at the dealer for this exact issue. In very cold weather, the steering creaks and groans through the full turn whether the car is stopped or not.
They told me the upper strut mount needs replacing as well as the steering shaft seal. I brought the car to them before my CPO bumper-to-bumper expired but they couldn't reproduce the issue. Now that I'm 3 months past the bumper-to-bumper, they are trying to charge me almost $1,000 for the fix. I'm fighting it and they said the request was sent to the district office to see if it can be covered.
I have no idea why this wouldn't be covered since it's been an issue brought up before my bumper-to-bumper expired.
Stano516 is offline
post #15 of (permalink) Old 3 Weeks Ago
Stano516's Avatar
UPDATE: So the car came back from the dealership. They replaced the steering shaft seal and the upper strut mounts. Chevy covered the repair but I had to pay a $200 deductible.
The mechanic said he heard the grinding noise from the upper strut mounts and the steering shaft seal was also causing the grinding noise. It's been warm here so I have no idea if it's truly fixed. I guess I'll find out next winter
Stano516 is offline
2014 Impala Loss Power Steering impala2lt Automotive Discussion 5 01-18-2019 08:39 AM
2014 LTZ Wheel Hub Replacement apguy Chevy Impala 9th Gen Discussion 14 01-05-2019 01:17 PM
Brakes on 2014 Limited LTZ 2014LTDLTZ Chevy Impala 8th Gen Discussion 2 10-19-2018 03:23 AM
2014 LTZ Stock 20s largest tire profile? Ulrict Chevy Impala 9th Gen Discussion 0 10-28-2017 01:42 AM
Are There Any Designer Lights (head or tail) For The 2014 Impala LTZ? Konpachi Appearance 6 07-25-2017 11:17 AM
