What exactly is 'automatically climate control'? - Chevy Impala Forums
 2Likes
post #1 of (permalink) Old 10-18-2018 Thread Starter
rhemabound's Avatar
Quoted: 5 Post(s)
Hi all - I am replacing a blower motor resistor ....the parts store is asking if it is 'automatic climate control'. I guess the part says that in the description. The site does say it fits my car ...2010 Chevy Impala LT 3.5. The temp is controlled by slide levers ....it's not digital. Not sure what they mean by automatic climate control. Parts guy couldn't determine that either......hmmmmm. Here is pic of dash controls....if that helps....Any help would be much appreciated!!
rhemabound is offline
post #2 of (permalink) Old 10-18-2018
Quoted: 220 Post(s)
You do not have automatic climate control. You have a dual-zone HVAC system.
Any GM dealer can determine the correct part for your car based upon its VIN. Clearly the parts store employee was unable to give you an explanation or determine the correct part.
Good luck.
plano-doug and Fred9505 like this.
post #3 of (permalink) Old 10-18-2018 Thread Starter
rhemabound's Avatar
Quoted: 5 Post(s)
Thanks! ....I did call and the dealer service guy said he didn't think it was automatic climate control - transferred me to the parts guy - got his voice mail. Will call in morn. I guess I'm glad I didn't try to install the other one with the automatic climate control. I dunno - maybe wouldn't have hurt? .....but maybe! I was gettin some pressure from people - 'well it looks the same - it'll work', .....um, ....not my m.o. lol. Also, I read about alot of installations where the resistor didn't work - or went bad pretty quick. I wonder. .......I'm all about gettin right and movin on.....ha! .....thanks again!
post #4 of (permalink) Old 10-18-2018
Quoted: 380 Post(s)
I would imagine, with or without climate control, both units, for the same model year, will use the same fan speed control circuitry.
From a parts sourcing perspective, the design engineers are expected to (re-)use the same parts whenever possible. Both A/C control units need to control a fan, presumably the same fan, hence with the same fan speed control module (aka "resistor").
A simple check is the cable to the speed control unit - if the connector mates up, I'd bet a paycheck that it's the correct unit. Common practice is to use different connectors for different units so that the wrong one can't be hooked up. But sometimes the bean counters will pull rank on the components engineers
Anyway, as long as you're not suffering, it makes good sense to take your time and be sure you have the correct part.
2009 Impala Climate Control Lights not working jaymesdriver Audio, Video, and Electronics 3 02-05-2019 03:16 PM
climate control, cruise control, overhead display '03LS Chevy Impala 7th Gen Discussion 4 07-19-2018 06:14 PM
Auto start climate control not working unless key is put in to start Outlaw1969 Chevy Impala 9th Gen Discussion 2 06-01-2018 08:40 PM
removed/installed climate control, no cold air now fathead7466 Chevy Impala 7th Gen Discussion 0 05-29-2018 11:56 AM
Climate control issues on cold stats. Shaggszgn Chevy Impala 9th Gen Discussion 5 03-21-2018 06:22 AM
